fizzy | 20/10/2012 21:07:20 |
![]() 1860 forum posts 121 photos | The last 2 inches of my regulater connecting rod are 5/32 square section. I cant make it any bigger or it will foul the valve link arms. Ive only got steel or brass, cant use steel in boiler (wont last long at that thickness) so question is, will brass be strong enough? I inted to fit travel stops on the regulator arm so it wont be possible to put lots of torque into it, I just dont want it twisting/shearing off!! |
FMES | 20/10/2012 21:31:14 |
608 forum posts 2 photos | Why not stainless steel? |
Steambuff | 20/10/2012 21:41:43 |
![]() 544 forum posts 8 photos | Since it is inside the boiler I would use either Bronze or Stainless Steel. (Copper is the only other material I would use inside a boiler but is not strong enough in this case) Dave |
fizzy | 21/10/2012 01:16:52 |
![]() 1860 forum posts 121 photos | no one makes stainless in this size!
JasonB | 21/10/2012 07:45:53 |
![]() 25215 forum posts 3105 photos 1 articles | What length do you need? 4mm stainless keysteel is available but in 300mm lengths. Kwil on here was after some a while ago and I put him onto my local Stainless stockholder but I think he may have had to settle on a 3m length of 5mm in the end. Can you not mill down the next available size? |
mick | 21/10/2012 08:16:50 |
421 forum posts 49 photos | Why not use free cutting Bronze, have a word with Viv at Milton Keynes Metals |
JasonB | 21/10/2012 08:26:20 |
![]() 25215 forum posts 3105 photos 1 articles | Just another though what about silver soldering square ends onto a 5/32" round rod? |
Michael Gilligan | 21/10/2012 09:07:01 |
![]() 23121 forum posts 1360 photos | fizzy, You could comfortably mill, or file, 5/32" square; from a short length of 6mm diameter Stainless. ... That shouldn't be difficult to find. MichaelG.
fizzy | 21/10/2012 18:31:05 |
![]() 1860 forum posts 121 photos | I went down the route of milling a square end on the 1/4 shaft - got a bit of help as my mill is rubbish!
KWIL | 21/10/2012 18:54:11 |
3681 forum posts 70 photos | Yes it was 5mm square stainless. Not really a problem, just mill it down. Had to make some 4mm square brass the other day for a small job, no point in buying it. |
