Johan Crous | 30/09/2012 12:09:26 |
![]() 41 forum posts 1 photos | I am now drawing a proposed Indexing tool for my mini mill, based on the Harold Hall Design, but I will make use of what I have available in my garage: [IMG]http://i798.photobucket.com/albums/yy261/Boerseun1/Workshop/IndexIdea.jpg[/IMG]
Edited By Johan Crous on 30/09/2012 12:10:04 Edited By Johan Crous on 30/09/2012 12:11:24 Edited By Johan Crous on 30/09/2012 12:18:01 |
Clive Hartland | 30/09/2012 13:01:01 |
![]() 2929 forum posts 41 photos | Johan, I cannot get your Photo Bucket link to work? can you not do a direct link ? Clive |
Terryd | 30/09/2012 13:45:48 |
![]() 1946 forum posts 179 photos | Hi Clive, Here is the image, I copied the url between the square brackets at both ends i.e. miss out the [IMG] and [/IMG] when trying to open the link. I hope that Johan does not object to me doing this, if so I apologise.
Best regards Terry |
Clive Hartland | 30/09/2012 15:11:12 |
![]() 2929 forum posts 41 photos | Thanks Terry, all clear now. Clive |
Jeff Dayman | 30/09/2012 15:39:16 |
2356 forum posts 47 photos | Hi Johan, Have a look at www.mcmaster.com and search part 8498a551. Even if this is not the exact type of plunger you want, McMaster has just about every other kind there is, so you can probably find one. Good luck. JD |
NJH | 30/09/2012 15:44:08 |
![]() 2314 forum posts 139 photos | Hi Johan I made a direct dividing attachment some years ago to cut some clock wheels - see my photos album I have shown the plunger of the type I assume you mean. here is an exploded view;- The division plate I purchased ( from Chronos? maybe - I forget) Most of the rest came from the scrap box and the major casting from a skip - one of those things you see and think "That might be useful one day" - and this time it was! The barrel was from a scrap tailstock and, usefully, had a No 2 MT in the nose. It all worked well, cost next to nothing and was made in a short time! Here are some of the wheels cut on it.
If you want further details of the plunger send me a PM and I will do a sketch Regards Norman Edited By NJH on 30/09/2012 15:45:23 Edited By NJH on 30/09/2012 15:46:46 |
Stub Mandrel | 30/09/2012 16:22:33 |
![]() 4318 forum posts 291 photos 1 articles | Hi Johan, I made a similar dividing attachment for my mini lathe. I used a detent which can fit either between two teeth. Obviously you need pin type plunger, but perhaps you could make use of my sprung design which includes a simple way to keep the plunger retracted by pulling it and twisting it . For my small divising head, which uses a plate, I made a pin with a knurled cup fitted to it, this screws onto a hollow tube and the pin enmerges from the end into the dividing plate. Much slower. Neil You could use a spurung arrangement like this - the spring doesn't need to be hugely strong The two slots are for the different plunger positions (i.e. at 90 degrees to each other) if the pin is turned right around, it stays retracted. Edited By Stub Mandrel on 30/09/2012 16:25:44 |
Clive Hartland | 30/09/2012 18:32:55 |
![]() 2929 forum posts 41 photos | You have space at the bottom of the block and base, make a square block and drill right through it for a spindle. Fit this parallel to the main spindle. Make a spindle to fit the hole in the block. Cut a groove in the spindle so it has no sideways movement. Use a screw to fit the groove to hold it in its position, free to rotate but no left or right movement. Make an arm that will fit over the main spindle and fix to the spindle in the lower block, cut a suitable slot along the center of the arm to carry your plunger mechanism. The plunger mechanism like Neils or Normans will do and so it slides along the slot and can be locked in place with a knurled nut. The hole in the arm will keep it lined up and stable in use. Clive |
Harold Hall 1 | 30/09/2012 18:45:09 |
418 forum posts 4 photos | Photo 6 on this page Johan may be of help. See here For anyone interested, the full version of this dividing head can be seen here Harold Edited By Harold Hall 1 on 30/09/2012 18:49:41 |
