rotarary vane pumps
what material to use for the vanes
I.M. OUTAHERE21/09/2012 08:50:39
1468 forum posts
Hi all.
Whilst not purely a model engineering question it could have relevance for those who use die grinders or the like .
I am currently building a petrol powered air pump that uses the internals from a 3/4 drive impact wrench as a pump .
Unfortunately the unit i scabbed from the steel bin at work was in pieces and the vanes are missing .
I remember years ago pulling a broken die grinder apart to salvage parts and the vanes looked like some sort of material similar to phenolic circuit boards but maybe with a fibreglass matrix .
This unit will only be used to pump up tyres on a 4wd - so used in short burst and only needs to raise the pressure from 12psi to 32psi max .
Any thoughts on suitable materials would be appreciated and please understand this is only an experiment !
IAN
Michael Gilligan21/09/2012 09:02:53
23121 forum posts
1360 photos
Ian,
That sounds like a very interesting project.
This is only a guess really, but the vanes in your die grinder were probably made from one of the better grades of Tufnol  such as Carp Brand.
Beware: If making something like this [or particularly, gears] you should always work with suitably thick Sheet material, not Rod. .... The rods are made like a roll of fabric at the haberdasher's ... and that puts the strength in all the wrong places.
Edited By Michael Gilligan on 21/09/2012 09:05:46
Edited By Michael Gilligan on 21/09/2012 09:09:22
Michael Gilligan21/09/2012 09:16:04
23121 forum posts
1360 photos
For ease of reference:
Tufnol's advice about machining Gears is here
... Much of this would be relevant to your Vanes.
Edited By Michael Gilligan on 21/09/2012 09:20:09
blowlamp21/09/2012 09:22:48
1885 forum posts
111 photos
Ian.
Any motorised air tools that I've come across have never looked suitable for use as a pump - are you sure your conversion will work?
Martin.
Clive Hartland21/09/2012 10:21:06
2929 forum posts
41 photos
My experience of Tufnol gears is entirely negative as twice I have had tufnol gears lose a tooth,
My Opel Kapitan had this--e larger tufnol timing gear strip a tooth when far out in the wild areas of Africa and the new gear came in aluminium. Later i enquired about tufnol gears and the best idea was to sandwich a sheet of steel between the two layers of tufnol, this being secured by screws through the matrix.
The second time was a small gear driven device with spiral tufnol gears which shed a tooth.
KWIL21/09/2012 11:48:58
3681 forum posts
70 photos
Vane pumps as air compressors, typical example Hydrovane, but these run with the vanes running in oil followed by an air/oil separator. Good compressors Hydrovanes, I have two, one small for spraying and the the other for workshop use. Does anyone have  a copy of theType 5/15 or 501/502 Hydrovane Service Manual?
Edited By KWIL on 21/09/2012 11:50:22
I.M. OUTAHERE21/09/2012 13:20:55
1468 forum posts
Hi all .
Thanks for the replies .
Michael G .
I will have a look at or for some tufnol sheet and check the specs for suitability but this sounds good .
Martin : as from what i have seen with air tools and rotary vane vacuum pumps that i use at work the main difference is the positioning of the exhaust and inlet ports.
For an air tool it is usually at 12o'clock and 6 o'clock from the inlet to exhaust or there abouts and for a vac pump which will also blow pressure the inlet would be at 10 o'clock and the exhaust at 2 o'clock or there abouts .
I plan to plug the exhaust holes that are drilled in the housing and machine a new set at aprrox 3'oclock and re- machine all internal surfaces .
Michael W.
There is no chrome plating on this unit and it was also used to try and stop the chatter effect that vane pumps develop - this was from over reving the pump which caused the vanes to bounce or from sticky vanes - i wish the hardchrome company i worked at 25yrs ago was still going as i could have got mates rates on a chrome bore !
The pump will mount directly to a new 50cc two stroke engine i picked up on E-bay for $75au inc clutch unit .
The bearings will be sealed units and ther will be no oil feed as i don't want oil in my tyres !
The pump will be reving at around 6000rpm for i hope less than 2 -3 min per tyre then back to idle .
There is no metal to metal contact and the only wearing parts are the vanes in which i can make a few sets for spares .
I wish i could go back ten yrs in time as my workplace threw out boxes of spare vanes for vacuum pumps in a workshop clean up disgust .
I always wonderd what they were made of though .
Ian
