Deltic007 | 30/08/2012 09:58:21 |
![]() 131 forum posts 12 photos | Hi all,
Any idea where i can get guage plate to make a motion bracket.
I need 1/8 thick x 2 1/16 wide,everyone i have seen sells eithe 2" or 2 1/2 wide.
Thanks 007 |
David Clark 1 | 30/08/2012 10:06:36 |
![]() 3357 forum posts 112 photos 10 articles | Why don't you buy 2 1/2 inch wide? That is wider than 2 1/16 and will do the job. What is the dimension the other way? regards david
Deltic007 | 30/08/2012 10:33:14 |
![]() 131 forum posts 12 photos | About 1" long thats all Yes i would buy 2 1/2 who would you recommend to use?
007 |
JohnF | 30/08/2012 10:49:45 |
![]() 1243 forum posts 202 photos | Hi Deltic, Any steel supplier will do or your local engineering supply house will probablyhave it available. Try the following links Look for "ground flat stock" If you PM me I might be able to find a small piece for you--I have quite a bit of it around and if you buy it you will have to buy a standard 16" length I think. Regards John |
David Clark 1 | 30/08/2012 10:51:05 |
![]() 3357 forum posts 112 photos 10 articles | Hi There Why don't you buy 1 inch or 1 1/4 inch wide and cut it off 2 1/16 long? Try Blackgates, they might do it. I buy mine from J&L industrial as I have an account but they might be expensive on postage. Do you have a local engineers' supplies? regards David |
DMB | 30/08/2012 16:27:50 |
1585 forum posts 1 photos | Hi Deltic, I dont know your location, but if you live within easy travel distance, try Sussex Tools Ltd, which I have used in the past and found very helpful. The stock Gauge Plate, generally, but if not in stock will get requirement promptly. 203 Tarring Rd, Worthing West Sussex BN11 4HN. T=01903-216666.E= [email protected]
Stub Mandrel | 30/08/2012 19:33:39 |
![]() 4318 forum posts 291 photos 1 articles | Years go I bought some from Chronos, at that time they sold it in 2" by 6" pieces which keeps teh cost down. Neil |
Nicholas Farr | 31/08/2012 06:42:10 |
![]() 3988 forum posts 1799 photos | Hi, you could try Colledge Engineering, see this **LINK** GLR Distrubtors Ltd see this **LINK** also do Gauge plate. Usual disclamers. Regards Nick. |
