Thread Dial Indicator positions
Stuart Davies 330/05/2012 09:37:08
16 forum posts
Hi all,
Does anyone know if there is a thread dial indicator position chart somewhere for downloading? tired of waiting for '1' to come around all the time.
many thanks
mick30/05/2012 09:50:59
421 forum posts
49 photos
You can engage on any whole number, the half divisions are for threads with say sixteen and a half TPI
Nobby30/05/2012 10:08:25
587 forum posts
113 photos
Hi Stuart
Micks correct also another trick is to leave the half nut closed . withdraw tool after reaching the end of thread you want to cut & reverse the lathes back to start postion until the thread is finished . Handy when cutting metric on an imperial lathe
Nobby
Russell Eberhardt30/05/2012 10:50:16
2785 forum posts
87 photos
Assuming you have a lathe with an *8 tpi leadscrew and a 16 tooth pinion on the indicator, the indicator is likely to be marked with four numbered lines and possibly an intermediate division between each whole number. For any even numbered pitch you can engage on any whole number. For odd numbered pitches engage on opposide numbers, ie., 1 and 3 or 2 and 4. If you are cutting a threadwith half pitches such as 12.5 tpi you must always engage on the same number.
The half divisions can be used be used if the pitch is divisible by four but I rarely (never?) bother with them.
Hope that helps.
Russell.
Stuart Davies 330/05/2012 21:36:32
16 forum posts
Thanks folks, I have made a small table and put it above the lathe for reference. It is a Raglan 5" and the leadscrew is 8tpi and the dial cog has 16 teeth so i'm sure the comments above will apply. The indicator has 4 main positions (although 0deg and 180deg are confusingly stamped 1 and 2), and 4 half positions. The halfnuts can be engaged inbetween these divisions also, giving 16 positions in total that the halfnuts can be engaged, although i'll think i'll stick to the 8marked positions.
Nobby30/05/2012 22:03:52
587 forum posts
113 photos
Hi Stuart & Guys
If in any doubt close on the same No each time.
You may have seen my dog clutch on this forum . It lets the gear train to be in constant mesh Similar to the Exe lathe I used to have . Its fitted to my flat bed drummond I have refined it now with a lever it works fine
Nobby
Tel01/06/2012 00:23:55
157 forum posts
28 photos
Or you could build John (Bogstandard) Moore's ingenius swing up toolholder and forget about disengaging OR winding the tool back.
Here's my version
Nobby01/06/2012 11:10:08
587 forum posts
113 photos
Hi Tel
What a brilliant bit of kit . I will have a go at making one of these. It would make this a lot easyer
Nobby
travelling steady
Nobby01/06/2012 11:14:28
587 forum posts
113 photos
Hi Guys
As anybody sussed out Tels last picture yet. Due to elf a saftey I cant say whay us kids done with somethin like this?
Nobby
John McNamara01/06/2012 14:48:59
1377 forum posts
133 photos
Hi Nobby
Its not a very big one..... When the Elves weren't watching and when I was a kid there was a concrete practise cricket pitch in the middle of the school oval. when we made em we left the heads on the bolts. Can you still buy matches !!
Cheers
Edited By John McNamara on 01/06/2012 14:49:40
Nobby01/06/2012 15:45:27
587 forum posts
113 photos
Hi
My spelling is awful enit . John Swan rings a bell ?
Nobby
Tel01/06/2012 22:45:56
157 forum posts
28 photos
smiley Good try Nobby, but it's not one of 'those' - tho I have made 'em in the past.
Nobby02/06/2012 10:41:37
587 forum posts
113 photos
Hi Tel
This thread is about closing half nuts etc . Could it be a half nut ? I'm of down the shed to do a bit of turning
Nobby
Tel02/06/2012 13:33:11
157 forum posts
28 photos
Nope, it's a full, unmodified commercial 1/2" BSW nut on a screwcut thread that stops short of either end of the bar.
Stub Mandrel02/06/2012 20:49:12
4318 forum posts
291 photos
Ho ho, I see what you are suggesting Nobby
Let us in on the secret Tel!
Jens Eirik Skogstad02/06/2012 20:59:39
400 forum posts
22 photos
Tel, i can think the first bar was treaded and the nut was screwed into. Then the second bar was fastened to the first bar and treaded on the rest of the second bar. All work done on the lathe. Right?
Les Jones 102/06/2012 20:59:40
2292 forum posts
159 photos
Hi All,
I suspect that the right hand end is a piece of brass bar tapped and screwed onto the thread which goes all the way to the right hand end of the left hand piece. I think it was then turned down until its diameter is just larger than the crest diameter of the thread.
Les.
Nobby02/06/2012 22:14:29
587 forum posts
113 photos
Hi Les & Guys
Les did you put lock tight on the the small thread on the R/H diameter before screwing it on ?
Just fihing ?
Nobby
Tel02/06/2012 22:30:30
157 forum posts
28 photos
blush I went a bit mad when I first made the swing up tool holder!
The 'secret' is a variation of this
Nobby02/06/2012 22:48:23
587 forum posts
113 photos
Hi Les
Thank you for posting a link. Would this be a thread in a thread ? I may have a puzzle for you ?
Enjoy your srewcutting .
Today I have just been crescoating my shed/ workshop
Nobby
