Starrett micrometer identity
ian j25/02/2012 14:22:07
337 forum posts
371 photos
Hi . Can any one identify the use for this Starrett micrometer. It has a pointed spindle and a single"V" anvil.
Regards Ian
NJH25/02/2012 14:29:35
2314 forum posts
139 photos
Hi Ian
Screw thread micrometer I think you will find.
Cheers
Norman
ian j25/02/2012 15:20:27
337 forum posts
371 photos
Thanks for that.
I assume its Whitworth as its stamped No. 436-1"
Ian
Richard Parsons25/02/2012 16:22:57
645 forum posts
33 photos
You cannot make the assumption that it is for Whitworth thread forms. There are a set of 60° threads which are also inch standard. These are the ‘Unified’ threads (UNC/NC, UNF/NF/SAE). These are American.
Rdgs
Dick
Nicholas Farr26/02/2012 00:36:26
3988 forum posts
1799 photos
Hi Ian J, your micrometer may be a user modified one, as the 436 series have a flat anvil and spindle. Please see scan below.
Starrett 436 series
Screw thread comparator micrometers are 210 series, and have a conical anvil and spindle. Please see scan below.
Starrett 210 series
Regards Nick.
Ian S C26/02/2012 02:25:32
7468 forum posts
230 photos
Thought it might be used to measure the likes of the wall thickness of tube or similar. Ian S C
ian j26/02/2012 08:21:06
337 forum posts
371 photos
Hi.
Dick. Good point. I've measured the pointed spindle angle and it's 55 degrees.
Nick. I also looked on the Starrett web site & their thread mics have a double "V" on the anvil. The one I have looks to be original not modified.
Ian. Yes I can see how it could be for that.
Regards Ian
Ian S C26/02/2012 08:55:52
7468 forum posts
230 photos
I would have saidas you that the anvil should haveat least a, as you say double"V", the mic must be at right angles, which would mean that the points should not meet, but be half the thread pitch apart sideways, well thats my idea anyway. Ian S C
ian j26/02/2012 09:11:51
337 forum posts
371 photos
Now that I look at the anvil "V" more closely, it's actually flat topped so would not bottom in a thread.
I can see how it would measure tube wall thickness.
Maybe it is a user modified one.
Ian
NJH26/02/2012 13:03:39
2314 forum posts
139 photos
Hi again Ian
A little web search returns this for Starrett screw pitch micrometer. Starrett is an American company hence it uses "real" units of measurement ( inches!) and the 1" refers to the capacity 0 - 1 in. I suspect that the 436 is the range, which appears to be a girder frame type. The one in the link looks like a deluxe version (maybe, using the same reasoning, from  the 575 range?.) There are a few notes in the "product description" which may be of use.
So that's another little task you've set us - aint the web wonderful - so many questions - so many answers!
Norman
Edited By NJH on 26/02/2012 13:06:11
Edited By NJH on 26/02/2012 13:08:26
Edited By NJH on 26/02/2012 13:09:00
ian j26/02/2012 13:45:13
337 forum posts
371 photos
Hi Norman.
Thanks for that information.
The description states:-
"This Micrometer has a pointed spindle and a double V-anvil, both shaped to contact the screw thread. The micrometer reading therefore gives the pitch diameter."
The anvil on mine has a single flat topped "V" which lines up with the point on the spindle.
As MikeW states above that would not measure a thread.
I think I'm going a long the line of thinking it's for measuring tube wall thickness or it's a user modified one, although the spindle & anvil do look to be factory produced.
Regards Ian
NJH26/02/2012 14:21:26
2314 forum posts
139 photos
Well Ian the search continues!
Starrett shows this for measuring tube!
I'm sure you will find a use for it anyway!
Norman
Nicholas Farr26/02/2012 16:22:47
3988 forum posts
1799 photos
Hi, although Starret is an American company, you will find they have factories in many parts of the world, one of which is in Jedburgh Scotland, which is where most Starret tools you find in this country were made, you can find them at www.starrett.co.uk and if you go to the downloads tab and scroll down to precision tools catalogue, you will find a MUL-T-ANVIL mic series 220 which will do tube wall thickness. The 436 series was and still is a standard micrometer, as shown in the scan I put in my previous post.
Regards Nick.
methusala26/02/2012 17:18:51
32 forum posts
Hi All, I have a micrometer that I modified for measuring undercuts on turned
components . I m/cnd a 1/16 flat on the anvil, and ground the spindle end to 1/16 dia. x 3/16
long. maybe the above mic was modified for this reason!
hope this helps ,Colin.
ian j26/02/2012 20:35:04
337 forum posts
371 photos
Hi All.
Just emailed Starrett with the photo & description of my micrometer. Will post you with there reply, if any. ( I find some companies are better than others over such questions)
Ian
ian j27/02/2012 13:42:43
337 forum posts
371 photos
crimp micrometer
Well straight from the horses mouth (Starrett) the mystery is solved.
It's a crimp micrometer.
We can all sleep easy to night now.
Regards Ian
NJH27/02/2012 15:57:36
2314 forum posts
139 photos
Well Ian so there you are - we are all wrong!
Still a very useful item to have in your tool box - just get out at every opportunity and measure a few crimps!
Cheers
Norman
