Here is a list of all the postings methusala has made in our forums. Click on a thread name to jump to the thread.
Thread: How often do you use the morse taper in your lathe headstock? |
13/12/2015 11:15:01 |
I have a warco 918 lathe,and have an er25 collet chuck, I also have m3 x3/4collet. one day when using m3 collet , I for some reason (tried) to put the face plate on the lathe. I found that it wouldnt screw on, but on removing the collet it went on with ease. Now every time I use m/t collets I screw the face plate on to stop any distortion of the thread. I should imagine this could be a problem with other similar lathes. |
Thread: Cutting shapes in sheet brass. |
23/10/2013 21:36:50 |
When I need to cut 16 &18 gauge material on the bandsaw, I put double sided tape on to scrap pieces of 6mm mdf board or plywood and stick the material to that. It works a treat. |
Thread: Tiny Boring Bar |
06/06/2013 09:12:32 |
Hi Neil, Have you tried j.b. cutting tools., I bought some small i.e. .110 dia shank and.156 to tool tip boring bars from them in the past. you would have to make a special holder for them as they have a near eliptical shaped end on them. Total lenght of bar is just over 1.125 with the working lenght being .625. Edited By methusala on 06/06/2013 09:16:35 |
Thread: Machining Titanium |
24/06/2012 21:42:48 |
Ian, Way back in the eighties I worked for a firm that produced components for the oil industry. These were manufactured from titanium and had numerous tapped holes ranging from m3 to m6, and as you can imagine we had a heck of a job tapping them. The firm got a rep in from a specialist firm for advice, and he reccomended the two stage taps. It was still a "cork in the bottom " job to tap them, especially the m3 but it was definitely a lot easier. Colin |
23/06/2012 20:16:47 |
Alf, I agree with Graeme on the size of the tapping drill i.e 5.2mm, if you have difficulty tapping titanium you could try using 2 stage taps. As an aside you can also electron beam weld titanium, but it would be very expensive Colin. |
Thread: shop4metal |
16/04/2012 13:18:34 |
Hi All, I have just come across a metal finishing and processing company based in Camberley, Surrey. they will do work for the general public and more importantly supply material with no minimum order. I have no connection with this company, and hav'nt done any business with them (yet) their web address is www.shop4metal.com Colin. P.S. sorry for the double spacing ,the computer is having a bad day.
16/04/2012 13:18:31 |
Thread: Pickle |
13/03/2012 09:00:43 |
Before I retired my work involved a lot of siler soldering, we used sodium bi sulphate (sodium hydrogen sulphate) as a pickle. It would start to dissolve the tops of screw threads if left in the pickle tank for a few days, but as most jobs took only 20-30 mins to pickle this wasnt a problem. the mix ratio we used 28g to 100g of water, but found that this ratio wasnt critical. as you say the chemical is used for lowering the ph in swimming pools the ph plus dosnt work so well. Im sorry but i cant explain why the pickle reacts with the plastic pipe.
hope this helps, Colin. Edited By Colin Stewart on 13/03/2012 09:01:54 |
Thread: Starrett micrometer identity |
26/02/2012 17:18:51 |
Hi All, I have a micrometer that I modified for measuring undercuts on turned components . I m/cnd a 1/16 flat on the anvil, and ground the spindle end to 1/16 dia. x 3/16 long. maybe the above mic was modified for this reason!
hope this helps ,Colin. |
Thread: Small Power Hacksaw |
11/02/2012 16:44:10 |
Hi Wolfie, in the camden book news there is an instruction book titled " building a power hacksaw and vice" by Vince Gingery, priced £7.75. It is built from raw material i.e. no castings are required. The Camden books website is www.camdenmin.co.uk my book list is spring 2011, Hope this is what you are looking for. Colin. |
Thread: Manky External Threads |
26/01/2012 10:06:38 |
Hi Alan, Have you tried reducing the o.d of the rod by two or three thou, as this can help in getting a decent thread in harder materials. It wont lead to a sloppy thread, as the flanks on the thread will still be be in contact, but should ease the pressure on the die. Hope this helps. Colin. |
Thread: Milling a curved end |
18/01/2012 16:26:39 |
Hi wolfie, Sorry I forgot to say click the "site map" first then that will bring up the "alpha index" then scroll down to item 416. Colin. |
18/01/2012 10:06:27 |
Hi Wolfie, Have a look at the" model engine news" web site, then go to the "alpha index " located on the side panel and scroll down to item no. 416. there you will find all the information that you require, plus a whole lot more besides . The site is a mine of information albeit about model aero engines but still applicable to most model engineering projects . hope this helps. Colin. |
Thread: Screws!!!! |
16/01/2012 14:35:37 |
Hi Stuart, I dont know what part of the country you are based in, but AHC in Camberley Surrey, ( also at farnham surrey,) sell individual nuts, bolts, washers etc. hope this helps Colin. |
Thread: Mill/drill return spring |
22/11/2011 08:16:46 |
Hi, I am not familiar with the chester mill, so I don't know how much room you have around your spring. If there is plenty of room you could try placing thick washers in the coils to lengthen the spring until it slips onto the post. This is an old dodge and I hope it is of use to you. Colin. |
Thread: Gauge 3 Dee |
29/10/2011 23:23:52 |
Hello Eric, I have the gauge one dee book, and the dimensions for the buffer & drag beams are 625. If you multiply this by the factor of 1.35 you get .84375, therefore the .750 dimension must be wrong . As for the by-pass screw, In the gauge one book all it says is , and I quote "remove hatched area from right hand bracket to allow passage of by-pass screw." So it would appear that the dim is not critical as long as there is room for the screw. I hope the above is of use to you. If you wish you could purchase the dee book from gauge one association, their website is www. gaugeone.org colin Edited By Colin Stewart on 29/10/2011 23:24:57 |
Thread: 5 CC CI engine (and a bit of a Grump) |
26/10/2011 20:55:09 |
I'm sorry Ramon I didn't mean to offend you, Please accept my apologies, No you are not alone, I know that I do the same sort of thing on a regular basis , and I'm sure others do as well. |
26/10/2011 10:37:36 |
Hi Ramon, Hmmm, I've only just realised that I drew them with three teeth and made them with five. ![]() ![]() |
Thread: Vol 172 |
26/10/2011 10:13:43 |
Hi Bill, I remember the series of small fabricated engines serialised in m.e in the 1990s' and all the flywheels were the same size, 2 3/4" dia as Weary has stated above. Colin. |
Thread: Scriber |
14/10/2011 09:25:54 |
Hi Wolvie, Another type of scriber you can make for scribing around the profile of a component is to make the scriber as described above, then file a flat about 3/8 to 1/2 long from the point, and to the centre of the point .This will ensure that the point of the scriber is close to the edge of the job you are scribing around. hope the above makes sense to you. Colin. |
