Stewart Hart | 04/01/2012 09:08:29 |
![]() 674 forum posts 357 photos |
The prototype for this engine was first shown at the great exhibition of 1853 only two were ever made but details of the second are vertualy none existant.
It has a novel rotary cylinder the best way I can descibe it is that it looks like a captive eccentric.
The model will have a 30mm bore with a 100mm dia fly wheel i've more or less got all the material together and I hope to start cutting metal soon.
I'll keep you posted on progress
Edited By Stewart Hart on 04/01/2012 09:12:05 |
Stub Mandrel | 05/01/2012 20:45:15 |
![]() 4318 forum posts 291 photos 1 articles | This is the one with a piston that's a cylinder lying on its side? I think Tubal Cain may have built one and described it in EIM, but I stand to be corrected. The challenge is getting the 'piston' a good seal at both ends as well as the sides. I look forward to hearing more about progress. Neil |
JasonB | 05/01/2012 20:49:00 |
![]() 25215 forum posts 3105 photos 1 articles | Stub, You may be thinking of the one Anthony Mount did.
Stew when I saw this post yesterday I thought it would be to say it was finished as you posted that drawing elsewhere a week or two ago
![]() J Edited By JasonB on 05/01/2012 20:49:37 |
Stewart Hart | 05/01/2012 22:31:55 |
![]() 674 forum posts 357 photos | This site does my head in
This is the fourth time I've tried replying to this thread.
Lets try again
Neil Antony Mount did a very nice model of this engine that you can buy a casting kit for from polly models.
As I'm a tight wad I'm going to use bar stock.
I've just bought some PTFE for the piston I'm hoping I can get the fit close enough to give a good seal failing that I'll use steel with a groove arround the rim of the piston filled with o ring cord or graphite packing, I'll just have to see how it goes.
I'm not that quick Jason
![]() Today I got the cylinder squared up, and I';; start to chew the rest of it out tomorrow not quite sure how but these things have an habbit to sort themselves out once you start.
Cheers
Stew
Stewart Hart | 26/01/2012 15:43:08 |
![]() 674 forum posts 357 photos | Made some progress got the cylinder and covers done along with the steam chest and some of the links.
Stewart Hart | 23/02/2012 07:21:41 |
![]() 674 forum posts 357 photos | A bit more progress Steam Chest and Valve linkage Piston, Cranks and Con Rods Eccentric Strap
Stew |
Stewart Hart | 25/02/2012 09:14:01 |
![]() 674 forum posts 357 photos | Completed the eccentric and did a trail assembly
Stew |
NJH | 25/02/2012 10:48:57 |
![]() 2314 forum posts 139 photos | Stew You make it all look so easy! Lovely stuff - please keep it coming. Regards Norman |
Stewart Hart | 26/02/2012 07:10:27 |
![]() 674 forum posts 357 photos | Hi Norman Thanks for your interest and kind comment. Stew |
David Clark 1 | 26/12/2015 16:53:36 |
![]() 3357 forum posts 112 photos 10 articles | Hi Stewart, what happened to the photo? Not showing on an IPad. |
Richard Marks | 26/12/2015 17:17:47 |
218 forum posts 8 photos | Nor on my computer.
John Hinkley | 26/12/2015 19:28:19 |
![]() 1545 forum posts 484 photos | If you look through Stew's albums, there are three pictures of the finished article, posted in May 2012. It would seem that the originally posted pictures have been removed for some reason. John |
