Warco KF-VO-A2F Milling Machine
Deltic007 | 05/11/2011 14:28:15 |
![]() 131 forum posts 12 photos | Hi all,
Could do with some help with my new machine.
1. Where do i get a manual for this machine?
2. Has anyone any idea what BS colour code is closest to Warrco's machine green?
3. The machine i have is 3 phase run off a rotary converter,When i use LOW it is OK but when i switch to HIGH it won't work and the motor just buzzes,Any idea whats up with it?
Thats all for now and any help would be most appreciated
Mike Hirst
JasonB | 05/11/2011 14:35:30 |
![]() 25215 forum posts 3105 photos 1 articles | What machine is it??
I'll assume its a Warco of some Sort, you may be able to get one from them but if its one of teh far eastern ones made sold by others you could possibly find a better online manual such as Grizley's.
I'll have a look at my tin of touch up as see if there is anything on it but don't hold your breath.
J
Edit just seen the model in the sub title, this is not the usual Warco code, can you add a picture. Edited By JasonB on 05/11/2011 14:36:38 |
Deltic007 | 05/11/2011 14:37:46 |
![]() 131 forum posts 12 photos | Hi mate
Plate says KF-VO-A2F
I need to blast and respray the coolant tray and i have access to paint at work so ideally a BS number or some sort of code would be smashing.
thanks
JasonB | 05/11/2011 14:54:34 |
![]() 25215 forum posts 3105 photos 1 articles | This looks like it may be a similar mill, manual in pdf format.
Have not got a full BS chart but if you can convert Dulux Colour Dimension it looks quite close to 4020-G30Y. Nothing on my tin.
You can but the paint here Edited By JasonB on 05/11/2011 14:58:51 |
Deltic007 | 05/11/2011 15:24:03 |
![]() 131 forum posts 12 photos | Pics now in my profile |
jason udall | 05/11/2011 18:20:58 |
2032 forum posts 41 photos | Re: "buzzing" in HI...in low machine wired in 'star' and in high wired in 'delta' this means machine uses the motor wiring differently in the two cases...fault might be in switch gear...may be one connection off in the delta mode. |
Deltic007 | 05/11/2011 19:06:09 |
![]() 131 forum posts 12 photos | Your right,i stripped the cover off the switch and one of the contacts was broken.Currently trying to source another.
Nicholas Farr | 05/11/2011 22:55:33 |
![]() 3988 forum posts 1799 photos | |
Springbok | 06/11/2011 03:55:04 |
![]() 879 forum posts 34 photos | Hi
Try
look at pics select the one that looks like yours and download a
manual not in chingalees.
hope this helps
Also what part of the world are you in I may be able to point you to the correct
source
Bob Edited By Springbok on 06/11/2011 03:59:33 |
Terryd | 06/11/2011 04:39:14 |
![]() 1946 forum posts 179 photos | Posted by Hirstyboy on 05/11/2011 14:28:15: Hi all, Could do with some help with my new machine. 1. Where do i get a manual for this machine? 2. Has anyone any idea what BS colour code is closest to Warrco's machine green? 3. The machine i have is 3 phase run off a rotary converter,When i use LOW it is OK but when i switch to HIGH it won't work and the motor just buzzes,Any idea whats up with it? Thats all for now and any help would be most appreciated Mike Hirst Hi Mike, I believe that Warco green is in fact 'Reseda Green' which is a RAL colour - RAL 6011. There is a RAL colour chart here. If you can take a small painted part such as a cover to a local paint factor, I use a local Johnsons trade centre, they will analyse the paint optically and get the exact colour match. It only need one square inch of flat surface. Best regards Terry |
Deltic007 | 06/11/2011 09:18:14 |
![]() 131 forum posts 12 photos | Thanks everyone,I am new to this site but i have to say how impressed i am with the amount of people willing to help......Thanks
Bluntdrill | 06/11/2011 11:32:14 |
1 forum posts | Hi There
Your mill is the same as a Myford VMF which I have, it was also sold by Elliot and it seems Warco. I have a manual which I managed to get from Myford, it is not the best in the world but is in decent english. It is 18 pages and has scematic wiring diagram and exploded views of the main componants. I have just noticed that it is listed inside the manual by the same No as yours KF-VO-A2F.
I think I can get the manual copied if you are interested send me personal message to arrange details.
Regards Jim. Edited By Bluntdrill on 06/11/2011 11:36:09 |
