Brooks Delta Configuration/Inverter Information
Morgan Sweet08/10/2011 11:55:43
20 forum posts
After helpful advise to my question on diference between a Myford Super 7 and 7B, I have decided to do down the path of a digital phase inverter with VSC, but am a complete novice regarding these electronice devises.
The 3 phase motor is a 370W Brook Crompton Parkinson and has 4 terminals,
A (RED), B (YELLOW), C (BLUE) and N (BROWN, BLACK & WHITE). The diagram on the cover plate has disintegrated and I'm assuming teminals ABC are phase 123 respectively and N has the 3 wires bunched and is in star configuration. There are no straps etc, so I hope to take the N wires off and bunch with the appropriate ABC terminal wires to give me a Delta (240v) configuration. Does anyone know what wire goes with what?
Further if I buy a 1 phase to 3 phase inverter can I use the existing Dewhurst reversing switch etc, or do I have to obtain a control box? Also can I make a control box, is there a wiring diagram, is it just switches with a potentiometer of what value etc. Are these digital inverters compatible with CNC electronic circuitory?
Thanks for any information
Weldsol08/10/2011 13:07:24
74 forum posts
Re your motor wiring you could try MM Engineering as they are Brook, motor specialists 01274 288777
Re the reverse switching you will only be switching the control voltage of the inverter (12 or 24 v) and is normally a two wire connection (well it is on my two inverters) I have mine working through the controls on the machines but they are wired to suit . for the speed control you need to check with the inverter spec to see what value pot is required.
Paul
_Paul_08/10/2011 16:44:00
543 forum posts
31 photos
This is the motor wiring
I wouldnt use the drum switch it may harm you inverter, you will have to construct or buy a control pod to suit you particular inverter lots on Fleabay, look for Drives Direct Dave is very helpful (usual disclaimer).
I made my own pod cost about a tenner took me a while to work out the wiring on my inverter and the component value required:
Paul
Morgan Sweet08/10/2011 17:30:26
20 forum posts
Thanks Paul for the information, is the POT a 10K linear as opposed to Logarithmic?
Thanks
Morgan
_Paul_08/10/2011 19:41:28
543 forum posts
31 photos
Linear from here Farnells
Paul
Morgan Sweet09/10/2011 19:49:54
20 forum posts
Thanks again Paul.
Morgan
Steve Garnett09/10/2011 22:48:52
837 forum posts
27 photos
Posted by Morgan Sweet on 08/10/2011 11:55:43:
You absolutely can't use the Dewhurst switch as it stands! Well, not unless you want to increase the odds of blowing up the inverter by a staggering amount, anyway. But I think that the Dewhurst switch can be rearranged quite simply to work as the 3-way switch shown (which, erm, isn't a Single Pole Single Throw, because it has a centre-off position), and use it to control the inverter instead. Doing this gives you controlled acceleration/deceleration as well, so it's definitely the way to go if you can figure out the connections to it.
I have one of the same inverters that _Paul_ has, and it's really easy to control, as he has demonstrated. There is at least one additional function that it can easily be made to do as well - jog the motor in small increments. Sometimes this can be useful... but they are good inverters, as long as you keep them covered. Unfortunately the microprocessor control section is right at the top, and vulnerable to anything (like oil mist) falling in there. Yes, I found this out the hard way! Fortunately, a quarter of an hour in an ultrasonic cleaner, a rinse down with de-ionised water and an hour in a temperature-controlled oven cured it completely.
Edited By Steve Garnett on 09/10/2011 22:49:55
john fletcher 110/10/2011 10:52:11
893 forum posts
I have 3 pre ownd inverters all different makes and the control circuits are all low voltage so it is easy to make your own remote control box as the earlier diagram shows. One needs a 10K pot for speed control and the other two 5K. A useful thing about inverters you can flick the forward and reversing when screw cutting up to shoulder, the motor slows down and ramps up in the opposite direction.Oh, that's another useful attribute of inverter control ramping up no sudden on.I have noticed that some internal controls are not changable on some ebay advertised inverters. When I bought two of mine from an auto jumble sale I got the manufactures phone number from their web site and gave them a call, they were extremely helpful.Regarding ventilation, I mounted a piece of sheet alumnium with a slightly bent front about 50mm obove my inverters this deflexts any swarf or dust. All 3 were intended to be cabinet/panel mounted,fortunately I had a selection of boxes in which to mount them in (one each) I cut a hole in top and bottom fixed some fine mesh over the holes, then as I said fixed the dust/swarf deflector plate, that was 3or 4 years ago.i hope that gives you some ideas,Ted
