Armando Meneses | 03/10/2011 18:22:32 |
31 forum posts 2 photos | Hello In the frame I'm building, use different sizes of Revit. When I bought the snaps, as I have not seen anything like doll, for example buy two snaps 1 / 8 ", one to hold the head has formed and the other to form the head opposite, in middle leaving the parts want to fix. What happens is that the head of revit not equal with the concave hole of the snap. Someone help me? Armando |
JasonB | 03/10/2011 18:59:53 |
![]() 25215 forum posts 3105 photos 1 articles | Can you confirm that the Snaps are 1/8" and the rivits you are using are 1/8"
Can you say what country you are from as if not in the UK you may possibly have got 3mm rivits instead of 1/8". In the UK all rivits should be made to the correct British Standard which sets out specific sizes for the head.
This chart shows the correct sizes
J |
Steambuff | 03/10/2011 19:28:08 |
![]() 544 forum posts 8 photos | Jason,
Thanks for that ... tell's me what I wanted to know as well (Setting allowance)
JasonB | 03/10/2011 19:32:30 |
![]() 25215 forum posts 3105 photos 1 articles | Use it as a starting point, you may need a little more or a little less.
J |
Clive Hartland | 03/10/2011 19:32:42 |
![]() 2929 forum posts 41 photos | Rivets should be cut to a certain length for decent head forming.
Try some sample rivetting and adjust the length to see which is best.
Are you sure that you need a domed head on both sides as most of my rivetting is domed one side and hammered into a countersunk hole on the other?
Clive |
Springbok | 04/10/2011 05:56:36 |
![]() 879 forum posts 34 photos | Hi Armando,
The dolly is just another snap the other side, I do not know what machirery you have but I tend to make my own dolly to suit the job in hand. If you have a mill fanrastic use a bit of scrap steel from scrap box and using a ball cutter make your dolly firmly fix into your large vice on bench. Arrand tools do a very decent rivet cutter also great for bolts, wel you name it. but you need a decent size vice. As jasonb says are your rivet metric or imperial would make a difference as you may get a not perfect dome. Would as suggested before get some scrap sheet and practise.
Please keep asking as we all start somewhere
Bob |
Terryd | 04/10/2011 09:07:25 |
![]() 1946 forum posts 179 photos | Hi Armando,
I hope that I'm not 'teaching granny to suck eggs' but are you 'rough shaping' the rivet before you use the snap (dolly or set)? The way to fit rivets is to first close the parts you are fixing,
then firmly tap the cut end of the rivet with the flat of the hammer to 'spread' it into the hole (fixes the parts together). Then roughly shape the new rivet head with the 'ball peen' of an
engineers hammer with light taps and then the second dolly is used to
give the final neat shape to the head. There is a excellent article on riveting in ME 4412 (9-22 October) page 347 by Terence Holland explaining most of what you will need to know about using solid rivets (even making your own rivet snaps (dolly or set) If you don't have access to the magazine send a private message and I can let you have a copy of the relevant page. To start you off I got this picture from Wikipedia, it might give you an idea of the process. Edited By Terryd on 04/10/2011 09:08:38 |
Armando Meneses | 04/10/2011 11:10:32 |
31 forum posts 2 photos | Hello. Bought the rivets and snaps at Reeves. and my confusion is that I bought three sizes, none of the rivet head fits properly in the domes of the snaps. Thus I can not begin to practice making my first rebitsello. The rivets are in imperial measurements. Armando |
Armando Meneses | 04/10/2011 11:19:22 |
31 forum posts 2 photos | JasonB, I'm from Portugal. Armando |
Armando Meneses | 07/10/2011 11:26:20 |
31 forum posts 2 photos | Hello. The head diameter measures 7 / 32 and the diameter of Shank measures 1 / 8. If I put the head of the snap dome is big, if I put the dome on the shank, the shank is a little smaller (enters the dome). Sorry I keep pushing this issue. How is the head to hold two shares I understand, have to try, but the snaps and rivets I do not understand the differences. Armando |
dcosta | 07/10/2011 14:04:27 |
496 forum posts 207 photos | Hello Mr. A. Meneses! I am Portuguese and have a friend who used many rivets in two locomotives and a traction engine he built. If you want I can ask him your question about rivets to him in Your behalf. Maybe we understand better using our mother language for this particular subject. Dias Costa Edited By Dias Costa on 07/10/2011 14:06:57 |
JasonB | 07/10/2011 16:42:36 |
![]() 25215 forum posts 3105 photos 1 articles | "The head diameter measures 7 / 32 and the diameter of Shank measures 1 / 8."
That means the rivits have the correct size head so the problem must be with the snaps. Probably best to take up Dias's kind offer as it will be easier in your own language.
J |
Armando Meneses | 06/06/2012 11:36:17 |
Hello |
Ady1 | 06/06/2012 11:56:01 |
![]() 6137 forum posts 893 photos | Ebay can be useful Search for "Hand Press for rivets" or "Hand Press for eyelets" Edited By Ady1 on 06/06/2012 11:58:12 |
JasonB | 06/06/2012 12:26:04 |
![]() 25215 forum posts 3105 photos 1 articles | An arbor press or fly press will do those sort of sizes of rivits quite easily but you will have to make your own Sanp & dolly. You alsoi need to ensure the snap is held vertically above the rivit otherwise you can bend the rivit so there is no gain. Bruce engineering do the hand presses but I've not tried one myself J |
dcosta | 06/06/2012 12:51:24 |
496 forum posts 207 photos | Hello Armando Meneses! You can find in Portugal under the brand Optimum three sizes of arbor press. You can find their catalog here page 209. I have the 1 ton model and I used it when replacing the bearings in my BF20 milling Without it i couldn't do the job. With a press like this You can press rivets and more...
Best regards
Dias Costa
Edited By dcosta on 06/06/2012 13:05:45 |
Armando Meneses | 02/11/2012 14:53:13 |
Which of the two options is the best? Casting - Gunmetal or Cast iron. Or is preferable bronze?
Thank you
Armando Meneses |
