David Bingham | 21/08/2011 01:22:59 |
6 forum posts | I have one of these. A nice machine. Bought second hand and was equipped with a wiper motor to provide X axis feed (required over voltage of around 25v to give decent travel rate).
Tired of reaching up and round to operate the Z axis feed and column lock, I, crudely fitted a Daewou wiper motor and toothed belt drive from a food processor plus a simple lever at the front linked to the rear column lock.
Hardly CNC, but this has saved me suffering " Miller''s elbow" from the awkward position of the top mounted Z axis handwheel and reaching to the rear mounted column lock.
Cost was £5 for the motor from the local scrap yard (sorry, vehicle dismantler and re-cycler!) .
My 25v + power supply is by 2 battery chargers connected in series (12V SIDE ONLY!!!) with a smoothing capacitor paralleled across the output. Speed is controlled by a lamp dimmer switch to supply the battery chargers.
All very crude but I am very pleased with the arrangement.
Ian S C | 21/08/2011 11:30:43 |
![]() 7468 forum posts 230 photos | I think my Rexon mill is a little larger tha yours, I use a lucas wiper motor to drive the bed. I have a 10 tooth sprocket fitted on an extention to the wormwheel shaft, and a 20 tooth sprocket to the lead screw. 18V from my work shop low voltage supply, and this seems adiquate. The thing that interested me was the use of a light dimmer, I tryed that but could not get satisfactory results, so I,v got a series of resistors operated by a rotary switch. Suits me, so I'm not complaining. Ian S C |
David Bingham | 22/08/2011 00:37:42 |
6 forum posts | The dimmer switch needs to be suitable for inductive loads and they can require a minimum load to work. Nonetheless you have come up with a solution that meets your requirements and that's all that matters. Its good to hear from someone else who recognises the capabilities of wiper motors in the workshop. I also built a wiper motor powered hacksaw from a feature in an early Model Engineer's Workshop - not very speedy but beats the drudgery of manual sawing - which I only do when absolutely necessary! Dave. |
ady | 22/08/2011 00:44:37 |
612 forum posts 50 photos | Cost was £5 for the motor from the local scrap yard They won't let us in to buy stuff any more where I'm at. 'elf and safety... |
David Bingham | 22/08/2011 00:55:58 |
6 forum posts | We'll never beat H & S - Too many cushy jobs and big profits for PPE etc. suppliers!!! |
Michael Malleson | 23/08/2011 09:25:28 |
62 forum posts 2 photos | Hi David. My milling machine is the same as yours. How about a short article in ME magazine on how you did your motorised Y-axis. Can you still use it manually ?
Mike. |
mick H | 23/08/2011 12:06:08 |
795 forum posts 34 photos | I second the above post |
David Bingham | 24/08/2011 01:27:51 |
6 forum posts | Hi Mike and Mick. Just to clarify, My machine already came with its X - axis feed. I've added a drive to the down travel only ( have I got mixed up with my Z's and Y's ??).
As I said, my arrangement is pretty crude - for manual downfeed I simply slip off the drive belt. If it is the downfeed which interest you, I could try to post a couple of photos, though this might not be for a couple of weeks. Dave
John Shepherd | 24/08/2011 16:54:47 |
222 forum posts 7 photos | David Can yo tell me where the title for you thread comes from? The reason I ask is that I used to work with a Grayham Butcher and I wondered if it might be the same person. Regards John Shepherd |
David Bingham | 25/08/2011 00:23:30 |
6 forum posts | Hi John, I picked up the thread from Albums page 9. Unfortunately, he has not entered any personal details, so I don't know how you might contact him? Dave. |
Graham Butcher | 01/09/2011 14:39:03 |
21 forum posts 3 photos | John
I have sent you a message
Graham |
