JasonB | 29/06/2011 16:46:32 |
![]() 25215 forum posts 3105 photos 1 articles | Just got in, made myself a cup of tea, sat down to flick through the newly arrived issue 4407 only to find more drawing errors before I'd even got half way through my mug
![]() Great Western 5"
Dimension top right of upper frame drawing 4.531"
Add up the dimensions on the lower drawing and they come to 4.5"
Rider Ericsson
Base plate holes drilled on 33.6PCD
Cylinder holes drilled on 33.5PCD
Water Jacket 33.5mm diameter
Beam bearing plate which has a curve cut out so it fits the jacket, curve given as 38.5 RADIUS
Same error on pump pad, Water Discharge pad & crank bracket.
And where does one get 2.85mm silversteel and a reamer to suit?
Will finish my tea now before having a close look for more errors.
Can someone at ME at least look at the drawings rather than blindly copying or printing them.
Jason
Edited By JasonB on 29/06/2011 16:51:56 |
JasonB | 29/06/2011 16:54:51 |
![]() 25215 forum posts 3105 photos 1 articles | Bracket clock
Fig 14, overall thickness of gear shown as 0.125"
Thinner edge after chamfering 0.165"
J |
KWIL | 29/06/2011 16:57:44 |
3681 forum posts 70 photos | Glad to see someone is awake!! |
JasonB | 29/06/2011 17:04:31 |
![]() 25215 forum posts 3105 photos 1 articles | Darjeeling
Nut bottom right page 15
Shown as 3/16 long
Also says drill and tap 3/16" deep
Leaves nothing to drill teh 3/32" hole into |
JasonB | 29/06/2011 18:16:41 |
![]() 25215 forum posts 3105 photos 1 articles | Rider Ericsson Water jacket again
It Says in the text that the water jacket is a tight press fit over the cylinder liner. But in my book trying to press a 27.65mm dia liner into a 25.5mm hole is just a bit too tight
![]() Could be worse, the lefthand drawing Fig 4 gives the same hole a 22.8mm dia even tighter,
![]() J
JasonB | 29/06/2011 18:39:42 |
![]() 25215 forum posts 3105 photos 1 articles | Ryder fig 7
Profile of curve shown will not allow part to sit in the correct position on the liner
Height given as 14.5 and 14.3 depending where you look
Fig 8
Two intersecting holes drawn at same diameter but annotated 3mm & 5mm
Block drawn as a square but dimensioned 10x13?
Fig 12
8BA thread dimensioned at 3.0mm dia
Edited By JasonB on 29/06/2011 18:49:06 |
JasonB | 29/06/2011 18:47:11 |
![]() 25215 forum posts 3105 photos 1 articles | Ryder Fig 9
Heights don't add up. 1.75 + 7 + 6 + unknown does not equal 13
Fig 10
No height for beam axle hole given
Fig two
Text says holes in baseplate should be aligned to the centre of the baseplate but all holes are dimensioned 0.02mm off centre
Where is Terry
Edited By JasonB on 29/06/2011 18:58:28 |
JasonB | 29/06/2011 19:25:43 |
![]() 25215 forum posts 3105 photos 1 articles | Back to the Great Western
At least 6 dimensions missing, the pairs of arrows are there but numbers are not.
The zero in the 4.093 dimension has not printed as its beyond the fold in the page Edited By JasonB on 29/06/2011 19:28:37 |
Phil P | 29/06/2011 19:37:53 |
851 forum posts 206 photos | Your post reminds me of when I was first trying to decide which model traction engine to build over twenty years ago. All you ever used to read about then were errors in the published designs, and it was obvious that these designs had never actually been built prior to being published. As a mechanical design engineer by profession, that was just not good enough for me and I made the decision to do my own design, drawings and patterns etc of a previously un-published traction engine. That was a Ruston Proctor Class SCD tractor in 3" scale, That way I could only blame myself for any errors encountered. At the same time I cancelled my subscriptions for ALL of the model engineering magazines, as they were not really helping me in any way, and to be honest were just full of adverts and regurgitated rubbish from previous years. Obviously I made a good decision, because it looks like things have gone from bad to worse. I never make anything these days unless I have personally designed it myself, or converted an existing design into a Solidworks 3D design to make sure it is correct. |
, | 29/06/2011 20:07:17 |
41 forum posts 1 photos | Funny how all the exhibitions are full of items made to such awful drawings. Maybe theyre made by craftsmen/women/people. |
JasonB | 29/06/2011 20:20:07 |
![]() 25215 forum posts 3105 photos 1 articles | Are they full of them, I've been going to the ME exhibition for about 30years and the number of models has certainly fallen, a large proportion of those shown are by the author of said articles.
As crafts are no longer taught in schools how can we continue if beginners are not given the correct information to work to. Once they have the experiance then they will be able to use this to acertain what most of there errors should be until then I will continue to point out any errors that I see in the hope that they will be corrected for the benifit of others.
Jason |
David Costello | 29/06/2011 20:35:44 |
79 forum posts 9 photos | Hi Jason
Its wednesday night you should be in the workshop.
![]() Dave. |
JasonB | 29/06/2011 20:44:26 |
![]() 25215 forum posts 3105 photos 1 articles | I know I should and I have not written any more about that hit & miss of mine.
Workshop was a bit too hot tonight anyway so can't finish the drip feed oiler i'm scaling down from a full size, should be fully functioning even though its only 7/16" dia.
J |
, | 29/06/2011 20:45:35 |
41 forum posts 1 photos | 1069 posts - he should be there every night |
Jeff Dayman | 30/06/2011 04:26:07 |
2356 forum posts 47 photos | Place your bets now on how long it takes the editor to offer the standard responses about errors and bad drawings:
"we can only publish what drawings authors send"
"we don't have time to check drawings"
"Looked OK to me"
"our illustrator has too much workload"
"magazine drawings can't be done to industrial standards"
Wait and see....
JD
PS before cutting metal on any published design I repeat/endorse the suggestion above about laying it out yourself on a CAD package. Otherwise you will be scrapping some parts and remaking them due to errors. Some errors and crap drawings have been around (and worked around) for 80 years or so!
As to exhibition models my hat is off to those with skills and patience enough to finish a model with the frustration of erroneous drawings and getting past the remaking of scrap parts.
In my opinion the model press should strive to publish the most correct drawings possible, not sweep crap under the carpet and make excuses.
JasonB | 30/06/2011 07:28:56 |
![]() 25215 forum posts 3105 photos 1 articles | " Place your bets now on how long it takes the editor to offer the standard responses about errors and bad drawings:"
Don't think you will get very good odds on any of them.
Just one thing in my first post I said the jacket was shown as 33.5mm, it should have been 38.5Dia, same problem with the other bits shown as 38.5R, thats what comes with tying to type with a mug of tea in one hand
![]() J Edited By JasonB on 30/06/2011 07:29:10 Edited By JasonB on 30/06/2011 07:29:39 |
KWIL | 30/06/2011 09:16:44 |
3681 forum posts 70 photos | Well Jason, that has been quite a marathon and I do not suppose that is the end. Some time ago I was about to make something as part of a published drawing, "You'll have to watch that "I was told,"drawing's full of error as much as 1/4" out!!". I redrew the parts concerned and far from it being in error to that extent there was in fact 1/32" of total tolerance available on the right side. As others have said in this thread, draw and check, even if not obvious , as Jason's findings are. Edited By KWIL on 30/06/2011 09:19:04 |
John Stevenson | 30/06/2011 09:20:00 |
![]() 5068 forum posts 3 photos | Have you given any thought about putting the mug of tea down ? John S. |
Eric Cox | 30/06/2011 10:11:50 |
![]() 557 forum posts 38 photos | From Jason Fig two
Text says holes in baseplate should be aligned to the centre of the baseplate but all holes are dimensioned 0.02mm off centre That equates to 0.000787 inches ! ! ! |
KWIL | 30/06/2011 10:15:45 |
3681 forum posts 70 photos | An error is an error, whatever the size! |
