1/4" or 9/32"?
Michael Wilde | 09/02/2011 22:42:26 |
![]() 25 forum posts 16 photos | I've just received a Bernard 4 jaw chuck that I bought on ebay, minus a chuck key. Its the '34m' 6" model that has the words "made especially for the Myford Ml7 lathe." I've used a piece of 1/4" square bar to remove the jaws and give it a good clean, polish and lube. The square bar was quite a sloppy fit in the square hole and, on measuring it, found it to be 0.280". This works out at 9/32", is this the right size as it seems a bit of an 'odd-ball' size? or is the sloppy fit on the 1/4" bar right? If anybody has this same chuck and wouldn't mind giving their chuck key a quick measure I'd greatly appreciate it! I'm just trying to see if its worth buying one on ebay (1/4") or making an 'odd-ball' size. Also, what to make it from? I can get off-cuts of quite tuff stuff from work (we call it durehete, used a lot in the power generation industry). Thanks in advance Mike Edited By Michael Wilde on 09/02/2011 23:00:20 |
David Clark 1 | 10/02/2011 08:02:57 |
![]() 3357 forum posts 112 photos 10 articles | Hi There
Buy a 5/16 or 3/8 in. one from Ebay, Five minutes on the grinder and you have a 9/32 one.
regards David
Dave Tointon | 10/02/2011 10:13:26 |
49 forum posts | Michael,
I'd suggest you just turn one up!!! Must be one of the easiest turning jobs with a tee handle to suit. I made one out of mild steel and it has lasted years.
Dave Tointon
NJH | 10/02/2011 11:05:44 |
![]() 2314 forum posts 139 photos | Hi Mike
I've just checked my Myford 6" PB 4 jaw. The socket measures 7.74mm and the key. which is a loose fit in the socket, is 7mm AF. Both chuck and key are in as new condition.
Norman
Gordon W | 10/02/2011 14:19:13 |
2011 forum posts | As mentioned before, a good source of square bar, in seemingly good quality, is old door locks, varies between 5/16" and 8mm, can beefiled to suit if needed. |
