Vertical milling slide
Vertical milling slide for Sieg C1 lathe
John Exley07/02/2011 12:16:07
10 forum posts
I would like to purchase a vertical milling slide for the above lathe and wondered what different makes would fit it as there are so many different makes out there can anyone help?
thanks John
The Merry Miller07/02/2011 16:03:42
484 forum posts
97 photos
It would help to know what the lathe is first John!!
Keith Long07/02/2011 16:23:12
883 forum posts
11 photos
Since both Axminster and ArcEuro list vertical slides as accessories for the C1 - and they look identical in the catalogues - even the colour - I would think that would be a reasonable starting point. I think you'll find quite a limited choice that will fit the C1. Most vertical slides on offer are for lathes of about 3 1/2 inch centre height such as the various offerings from Myford, Boxford etc. Provided that the vertical slide you fancy is of a size suitable for your lathe, then the only question will be how to mount it and adaptor plates are easy enough to design and make.
Keith
Peter G. Shaw07/02/2011 16:24:59
1531 forum posts
44 photos
John,
Since no-one else has bothered replying, try Arc Euro Trade. They advertise one at £60. Probably plus all the usual addons.
You could also try the other importers to see if they sell the same or similar lathe, eg Warco, Chester, Amadeal, Axminster (£74.50) etc.
Peter G. Shaw
Edited By Peter G. Shaw on 07/02/2011 16:28:04
The Merry Miller07/02/2011 17:01:58
484 forum posts
97 photos
Posted by The Merry Miller on 07/02/2011 16:03:42:
Sorry about that John, it's my eyes you see.
John Exley08/02/2011 10:48:14
10 forum posts
Thanks for the reply lads will have a look at arco eurotrade Peter.
by the way Merry Miller the lathe type was shown as the thread title have you ant ideas
Cheers John
Ian S C08/02/2011 12:16:34
7468 forum posts
230 photos
If the ones available don't suit, you could build your own, keep it in the correct propportion for your lathe. Ian S C
The Merry Miller08/02/2011 16:53:50
484 forum posts
97 photos
I'd have thought that the vertical slide from Arc Euro at £60 was a good buy john.
