Polishing cast iron
Dismaldunc03/01/2011 12:19:36
91 forum posts
8 photos
   Hi again folks, Well I have completed my stuart 10V as my first ever project and it runs! (ok it did take a replacement cylinder and 3 attempts at making the crankshaft) But although I am happy with the machined finish on the cast iron ( i did iddy-biddy tiny finishing cuts) It still looks dull, now piccys I've seen online are so shiny they look almost chrome plated.
How is this acheived ???  is it real or is it photo-shop ?
once again thanks in advance for your time
Duncan
Nicholas Farr03/01/2011 12:26:17
3988 forum posts
1799 photos
Hi Duncan, fine grade wet-n-dry will bring cast to a shine, and then finish with a metal polish.
Regards Nick.
Edited By Nicholas Farr on 03/01/2011 12:26:54
Dismaldunc03/01/2011 12:56:06
91 forum posts
8 photos
blummin heck.. thanks Nick I though there would be some high tech trickery to this, right then, Where is that pre-war tin of brasso ?
Dunc
JasonB03/01/2011 13:27:15
Just work through finer abrasives, better to use oil with the Wet and dry than water but I find you don't really need it wet.
Jason
Ian S C04/01/2011 04:25:21
7468 forum posts
230 photos
And before you go inside from the workshop, wash your hands.  The black leaves a mess everywear.  ian S C
Stub Mandrel07/01/2011 20:02:33
4318 forum posts
291 photos
Is that all - I still manage to screw up crankshafts after several engines!!! Though I must confess I managed the cylinder first time!
Dismaldunc07/01/2011 20:51:58
91 forum posts
8 photos
Hi Neil, Yup I was really miffed, bored out the cylinder spot on, faced the ends just loverly, drilled the exhust hole spot on plus one of the steam ways. Then managed to drill through into the correct place on the second steamway but gave it a bit more stright into the other port bummer !
Ian S C08/01/2011 10:53:22
7468 forum posts
230 photos
    Anothere thing you can polish with is toothpaste,  have used it for polishing samples of steel and cast iron for study under the microscope.  The stuff I'v got is those little tubes you get along with a brush on airlines--tastes awful. Ian S C
Nicholas Farr08/01/2011 11:05:10
3988 forum posts
1799 photos
Hi Ian, sounds logical, as I beleive one ingreedient of toothpaste is sand, milled into a fine powder.
Perhaps its the best use for your supply, being as it is in bad taste.
Regards Nick.
