Whats that blue stuff called:-)
Dismaldunc | 29/08/2010 12:10:06 |
91 forum posts 8 photos | Hi Folks, many moons ago when I was at school we used some rapid drying blue stuff to mark out on steel etc, I have no idea what it was called and would like to buy some. I tried "micrometer blue" but that stays sticky and smudges (which I now understand is its function). I seem to remember we removed it from the work with meths So your advise/help would be much appreciated Duncan |
Tony Simons | 29/08/2010 12:23:21 |
37 forum posts | Hi
It is called Marking Blue, or layout blue. It is essentially Prussian blue mixed with meths. |
Dismaldunc | 29/08/2010 12:28:51 |
91 forum posts 8 photos | Thanks Tony, shall now go and google for some! |
JasonB | 29/08/2010 12:29:53 |
![]() 25215 forum posts 3105 photos 1 articles | As said and you should be able to get a small bottle from most of the model engineering suppliers.
But make sure you do not buy engineers blue which comes in a small flat tin, this is a thick paste use to test the fit of parts.
A large permanent marker pen can also be used but I find it comes off quicker.
Jason |
Keith Long | 29/08/2010 12:30:51 |
883 forum posts 11 photos | Easiest is a broad felt tip marker, cover the metal and scribe the lines through that. Keith |
Niloch | 29/08/2010 12:51:39 |
371 forum posts | You have already been given the essential information but you may well be interested in this thread which attracted 32 posts from early May until a couple of weeks ago. |
Dismaldunc | 29/08/2010 15:06:05 |
91 forum posts 8 photos | thanks again chaps, the post suggested by Niloch was interesting, think I will give the big fat marker a go |
the artfull-codger | 06/09/2010 22:56:28 |
![]() 304 forum posts 28 photos | there's two types of marking blue [I have both] there's the translucent type for marking bright metals & also the opaque type for marking black bar etc,I like the idea of dipping a felt tip into marking blue, you get the best of both worlds!! |
John Wood1 | 07/09/2010 14:33:01 |
![]() 116 forum posts | Marking out blue or Layout blue is available from (among others) Chronos http://www.chronos.ltd.uk/ It is easily removed with methylated spirit. I put it on with a small brush and a small amount will probably last you for years.
John |
Axel | 08/09/2010 06:58:03 |
126 forum posts 1 photos | Did anyone ever use Copper Sulfate as recomended by L.H. Sparey? |
Ian S C | 08/09/2010 08:09:22 |
![]() 7468 forum posts 230 photos | Axel, look at the other thread mentioned by Nilock. Something aboul boiling cabbages twice. Ian S C |
