Bodmer’s Sliding Cylinder Engine
Dave R14/05/2010 10:42:49
2 forum posts
I have just got the castings and drawings for the above, has anyone else tried this one?
JasonB14/05/2010 13:23:58
Not tried it but its a nice looking engine. If you don't have the original build series articles they are reprinted in his book and worth having.
If its of any help this homepage of a german builder has a lot of pictures of constrution if you click the "zum bauburicht" link at the bottom of this page, the other link takes you to photos of the finished engine and a video of it running
Jason
Dave R17/05/2010 14:19:00
2 forum posts
thanks very much, there is nothing like some pictures to follow, the words are less important. Thanks for the reply
JasonB17/05/2010 14:23:29
Just put the web page into a translator like Babblefish, it comes out quite well but a few of the technical terms can be a bit amusing
Jason
tony bastick29/04/2012 23:00:15
15 forum posts
Hi,iv just started the restoration and overhall on one of these engines, does anybody know how to set the valve timing? Tony
NJH30/04/2012 10:37:02
2314 forum posts
139 photos
Hi Tony
Anthony Mount gives details of the valve settings in his book "Historic Engines Worth Modelling : Volume 2 " - click here for info. He usually exhibits at the Bristol Exhibition in August and I'm sure he would be willing to advise you.
Dave I too am attracted to this engine although the practicallity of a design which moves a heavy cylinder rather than a realtively light piston is questionable! Anyway I must first finish some of my outstanding ( or maybe that should be longstanding!! ) projects!
The finish achieved on the example in Jason's link is quite exceptional.
Norman
Ian S C30/04/2012 11:59:27
7468 forum posts
230 photos
I wonder if the idea of moving the cylinder was to use gravity to supply the power on the down stroke? Ian S C
NJH30/04/2012 12:17:24
2314 forum posts
139 photos
Hi Ian
I understand that the steam is fed down the ( hollow) cenral column and directed by a piston valve in the cylinder to either the top chamber or bottom chamber of the cylinder which has a fixed "piston" at its centre. The exhaust is similarly directed to the bottom of the central column.
Norman
