Stub Mandrel | 24/02/2010 22:00:35 |
![]() 4318 forum posts 291 photos 1 articles | Oops... I finally got around to making the jacking screw for a little machinist jack tonight. I found some free cutting stainless steel that comes up to a bright polish and thought it would make a good contrast to an oil blacked base. Well it cut wonderfully, creating long single curls of swarf, nice surface finish, with a 20 thou (0.5mm cut). But could I get an HSS M6 die to cut it? Barely. I took off a 5 thou to ease things for the die and it got worse, I had obviously really badly workhardened the surface. So I switched over to some tougher steel, EN24T at a guess. the surface finish was awful, so I thought I'd better sharpen the tool - that's when I noticed it was a flat topped tool for brass with zero rake. No wonder it workhardened the stainless! Moral - don't assume you have the right tool in the toolpost , even idf it looks right at a glance! Neil |
Circlip | 25/02/2010 07:42:05 |
1723 forum posts | Key word there Neil, ASSUME???????
Regards Ian. |
Ian S C | 25/02/2010 08:12:46 |
![]() 7468 forum posts 230 photos | Hi Neil,been there done that, thought that seeing stainless is so tough I'd take the thread down in stages with a die, first cut OK, second cut? nothing came off. Cut the threaded bit off, set the die to full depth, good thread, cut once you don't get a second go.Ian S C |
DMB | 25/02/2010 08:25:12 |
1585 forum posts 1 photos | Hi Neil,
May I suggest that any tools to cut Brass, you clour witha dab of yellow paint?
I use those small pen type touch-in paints sold for cars and colour-code an awful lot of things, e.g., caphead screws and the fitting Allen key as I always seem to pick up the wrong size. I also dont believe in complete sets of spanners on walls like some "show - workshops" seen in the mags. I find it much more convenient to have `dedicated` spanners in a box/rack special for the mill or for the lathe. Even these I colour one end so if they end up on the bench, I know instantly where they belong when I have a clear-up.
John. |
Stub Mandrel | 26/02/2010 21:28:26 |
![]() 4318 forum posts 291 photos 1 articles | Posted by Circlip on 25/02/2010 07:42:05: Key word there Neil, ASSUME??????? Regards Ian. You know, my wife keeps saying just that! dab of yellow paint? Good idea, I'll do something like that. I also try to keep some 'favourite' tools to fit the various machine tools. But the little men keep hiding them under the bench! Neil |
