2MT Test Bar
Anthony Spencer 126/01/2010 18:56:37
19 forum posts
Does anyone know where I can purchase a No2 MT Test bar as used in the Rebuild of a Super 7 in MEW 139
Thank you
wheeltapper26/01/2010 19:00:33
424 forum posts
98 photos
Hi
just had a quick look and Arc-Euro trade have one here.
I'll have another look.
Roy
edit
Chronos have some here.
Edited By David Clark 1 on 27/01/2010 08:19:36
Peter Gain26/01/2010 23:28:52
103 forum posts
Be very careful when purchasing test equipment. I bought a test bar from a well known advertizer, it was so inacurate as to be unusable. In fairness, he did give a refund without a quible.
Be sure to get an assurance that the item is manufactured in the UK, Western Europe, or USA. Other sources may be OK but are questionable.
Try Arrand, The Forge, Knossington, Nr Oakham, Leicestershire, LE15 8LN. 01664 454566. I have dealt with this British firm & found them helpful & their products good.
Peter Gain.
Niloch26/01/2010 23:40:20
371 forum posts
How do you test a test bar?
Rob Manley26/01/2010 23:46:11
71 forum posts
14 photos
Between centres?
wheeltapper27/01/2010 11:33:04
424 forum posts
98 photos
Hi
David, I see you changed my links, if you tell me how you did it I'll change any future ones.
cheers
Roy
David Clark 127/01/2010 12:20:44
3357 forum posts
112 photos
10 articles
Hi Wheltapper
There is a 3 link chain in the edit box.
This is to set links up.
Select the word you want to link,
click on the chain, insert link and select open in new window.
If an email link you can change type to mailto.
regards Davdi
wheeltapper27/01/2010 12:35:12
424 forum posts
98 photos
Thanks David.
copied and saved for future reference.
Roy
Anthony Spencer 127/01/2010 12:42:17
19 forum posts
Thanks to all
I have ordered one from RDG
But I will get a friend to run it between centres to sest for accuracy
Laurence B02/02/2010 12:09:38
58 forum posts
As Peter Gain says-you won't go far wrong buying from Arrand Engineering.I have bought a few things from them.Ok they're not cheap but you get is quality,unlike some imported items which sometimes leave a little to be desired.
Brian Wood22/02/2010 10:50:57
2742 forum posts
39 photos
I bought Arrand test bars some years ago, they come with statements of surface finish, roundness, run out and so on. Testing these needs specialised equipment certified to at least 10x better accuracy than the spec which the bar meets. Testing  between centres will simply not be good enough.
Trust the manufacturer in this case, I can vouch for their quality.
Brian Wood
KWIL22/02/2010 11:56:17
3681 forum posts
70 photos
I agree entirely that Arrand kit is Quality.
Edited By KWIL on 22/02/2010 11:56:42
Laurence B25/02/2010 11:49:43
58 forum posts
I've bought a few items from Arrand Engineering including a test bar,and would recommend them too.The quality is far better than some of this cheap imported stuff.
