Geoff Theasby | 20/08/2009 16:33:48 |
615 forum posts 21 photos | I have made a mistake in a block of aluminium, after filing to shape and drilling.
Is there a product which I can obtain to fill a hole and redrill and tap the correct size? It is only a small block, not under any strain.
I'm sure I have seen mention of this is ME, but can't recall which issue.
Geoff |
The Harper | 20/08/2009 16:56:54 |
18 forum posts 12 photos | Hi,
Is it possible to drill / ream the hole out bigger and press a new piece of aluminium into the hole and remachine it? Or you could tap the increased hole and fit a larger aluminium threaded insert and secure it with something like Loctite Retainer 638 and then remachine your hole. Believe me Loctite Retainer will work wonders especially if the part is not under any strain.
Just an idea and most probably cheaper and more successful for you, plus Retainer has a very good shelf life once opened. (I don't work for Loctite, I just use a few of their products in my day job!).
Paul |
JasonB | 20/08/2009 17:20:10 |
![]() 25215 forum posts 3105 photos 1 articles | Isopon make an epoxy filler called "Plastic Metal" which is a bit like car body filler, and Unibond do one called "repair metal"
If it's going to be subject to ant high temps then JB Weld is another epoxy but a little runnier, you can pick up a small pack on e-bay for about £5 inc postage
Both can be machined when set
Jason Edited By JasonB on 20/08/2009 17:20:34 |
mgj | 20/08/2009 17:39:02 |
1017 forum posts 14 photos | There is and I can't remember the name. We used to use it racing to repair cylinder blocks. , especially where the water exiting the water pump used to gouge out a big cavern in hte base metal. Very tough, and machinable and threadable, being a metal loaded epoxy. It is properly mixed (loaded) with ali, or steel depending on the type. Grey box red band, quite firm - unusual cream coloured catalyst. Sod to mix up - brilliant result. Anyone remember it ? |
Geoff Theasby | 20/08/2009 18:40:06 |
615 forum posts 21 photos | Thanks all,
there is a motorists supermarket up the road, I will ask for Plastic Metal.
Failing that the Unibond product sounds interesting.
It is only for a pair of dividers, no high temperatures will be involved.
Geoff |
Ian Abbott | 20/08/2009 19:21:46 |
![]() 279 forum posts 21 photos | JB Weld is the best that I've used. We've build up aluminium castings such as carb flanges and they've held. Also useful to level a warped surface on a cast part. It'll machine and take a thread.
One really handy technique for a stripped out thread, is to use a release agent on a bolt thread then build up in the hole around it, or fill the hole and push the coated bolt in, then when it's cured, the screw backs out, leaving a nice thread. A quick file to level the surface and it's as good as new. I'm not sure about the maximum temperature it will take, but certainly anything on an i/c engine other than the exhaust.
Ian |
Ian Abbott | 20/08/2009 19:22:06 |
![]() 279 forum posts 21 photos | JB Weld is the best that I've used. We've built up aluminium castings such as carb flanges and they've held. Also useful to level a warped surface on a cast part. It'll machine and take a thread.
Ian |
ChrisH | 20/08/2009 23:03:20 |
1023 forum posts 30 photos | I have used JB Weld too and found it very good but it does need support while it sets ( quite a few hours I found) otherwise it runs and sags away. When set it can be machined and filed and gives a good finish
However, when I was at sea we used an epoxy steel made by Devcon which was excellent and standard issue on the ships! They also do an aluminium version - Devcon Aluminium Putty - which I have not used myself but of which I have heard good reports; it is designed to fill holes in aluminium castings etc. If it is as good as the epoxy steel it will be very good indeed. Look at http://www.itw-devcon.co.uk for more info on all their products. Was this the product you were thinking of Meyrick?
Needless to say I have no interest in either the Devcon or JB Weld companies!
Good luck,
ChrisH |
mgj | 21/08/2009 18:00:18 |
1017 forum posts 14 photos | Devcon Chris - that's the stuff. Exactly that. I used the Ali loaded stuff and its really good. Doesn't slump either - you can pack a hole or build up an edge and it stays put. Like all ali work, it benefits from a good preparation - a good scrub with a CLEAN stainless steel wire brush as soon as possible before application. But thats true of doing anything with ali to beat the speed of oxidation. Thanks also too to Buddy who pm'ed me with the name Devcon too. He mentioned that it's aircraft grade, which I didn't know, but says something for its quality. Edited By meyrick griffith-jones on 21/08/2009 18:03:55 |
Circlip | 21/08/2009 19:48:17 |
1723 forum posts | Wasn't Devcon originally invented to repair the dotted "Tear here" arc across the drilling tables of all school and Night school pillar and bench drills???
Regards Ian. |
JohnF | 30/08/2009 10:33:06 |
![]() 1243 forum posts 202 photos | Depends on the size of hole etc but try Lumiweld allumininum solder --I've use thie to repair al kindes of ally products and it works well.
Alternative ly the suggestion of drilling out to alarger size and fitting a plug [with say loctite] then reworking to your requierments may be best..
Edited By Stephen John Fawcett on 30/08/2009 10:33:59 |
Geoff Theasby | 30/08/2009 16:17:38 |
615 forum posts 21 photos | Thanks for all the advice, guys.
I got some of the Plastic Padding Chemical Metal, which has done the job.
The hole was too small to fit a plug and re-tap.
Geoff |
