Using the Coaxial Indicator to do it, with a taper.
Chris Mate | 29/09/2023 03:03:09 |
325 forum posts 52 photos | For those that know all sort of geometries well, I would like to hear your opinion regarding this idea.
3-Now you drill a very small hole in the bottom centre without removing it from lathe chuck, this is to centre this piece under the spindle using the coaxial indicator with its punch adaptor, this would be like a flat plane start. 4-Now you turn a steep taper of say 15 degrees into this hollowed out bar to near the bottom with concentric hole. The use of the taper would be to "multiply" the effect of it head is out of tram similar to the lenght of bar used with conventional methods for leverage. The taper will give the leverage now, as the coaxcial probe will not run in a perfect circle around the taper if your head is not 100% 90 degrees vertical(Spindle to bed). 5-You can see this as a jig made once to use with the coaxcial indicator to square up the head/spindle to bed(Tram). |
JasonB | 29/09/2023 06:53:51 |
![]() 25215 forum posts 3105 photos 1 articles | If you were to work out the effective major and minor axis of the elliptical shape that teh Coax may follow iff the tram were off by say 0.1mm/100mm it would be such a small difference that you would not be able to measure it with the usual dti scales on these coax indicators You would also need to ensure your piece of bar had the end facing the chuck completely true to the cone, I did not see mention of even facing it. |
JasonB | 29/09/2023 07:36:03 |
![]() 25215 forum posts 3105 photos 1 articles | Just sketched it out in CAD If we assume the widest point of your cone would be 65mm dia then applied the equivelent change in shape corresponding to 0.1mm over 100 of tram error you would be looking for 0.000032mm on the coax. One is easy to read the other you won't read. Given that most would want something like 0-.01mm or better over 100mm then you will never see th eneedle move on the coax I drew it as a cylinder, sliced the top off a 0.1:100 (0.06deg) and then measured the major axis of the elliptical end. You can also see from the Y delta that by measuring over 65mm dia even if done the traditional way your reading will be smaller, half of less of what can usually be swung across a mill table. |
Vic | 29/09/2023 10:50:22 |
3453 forum posts 23 photos | Some years back I saw a redneck mill trimming device. It was a steel bar welded to a car disc brake then accurately turned down to fit a collet in the quill. You can guess how it works. |
Chris Mate | 30/09/2023 17:39:03 |
325 forum posts 52 photos | Ok, thanks for info. This morning I decided to make the "jig" clamped to mill table. Decided to cut the inside to 18 degrees due to height of round block. At the bottom I left material, then drill a small hole which is concentric to the taper. This hole was drilled with the smallest centre drill with short taper for the punch bit from the coaxial indicator. Edited By Chris Mate on 30/09/2023 17:44:10 |
JasonB | 30/09/2023 18:42:56 |
![]() 25215 forum posts 3105 photos 1 articles | Chris, try putting a 0.1mm or 4 thou feeler gauge under one side of your jig and see just bt moving the X and Y you can get the coax to show zero, I think iy will still show zero as the difference between flat and shimmed is 0.000032mm which is 1/3rd of a micron you you will never see with the naked eye |
Greg Webb 1 | 30/09/2023 18:56:11 |
26 forum posts 2 photos | If the jig was a tube without any angle, would finding the centre at the base and then at the top by moving the quill up give a difference if the head was not trammed. |
Pete | 01/10/2023 03:05:01 |
128 forum posts | I have one of the Blake Co-ax indicators, plus a few spare dial indicators and could easily make my own dual indicator tramming tool. I don't use the Blake for setting the head alignment since it's really not quite as accurate as just sweeping the table with a dti. In fact these co-ax tools seem to have at least a bit more hysteresis over what my dti's do. And in hindsight, I've not found much of anything that the Blake can do that in one way or another a dti can't also do, and with in my opinion better accuracy. It just takes slightly longer. With a short length probe, those co-ax tools are a good way to check the lathe tail stock alignment, if it's being used properly, gravity when checking the vertical elevation has little effect compared to doing the same with a dti. And yes I got fooled by that for a few hours until I figured out what was happening. One of the dual indicator tramming tools would get you close a lot faster for the initial alignment if you ever angle the head for certain jobs and then want it back square. But for my mill, then a simple square against the length of the exposed spindle will do that as well. Then it's time to use that dti. A dial indicator and dti has dozens of uses outside of just tramming the head in with a few shop made additions. And no matter how accurately you tram the head in, you will always get a certain amount of back cutting with larger diameter tools. That head alignment is also a static setting. The machine itself starts to deflect outside of where you set it once those cutting loads come into effect. Those are just physics and simply because there's always various amounts of machine and tool deflections under load. And the harder the material, deeper the cut, and/or duller the tool, the more you'll have. But head tramming is just one item that has to be checked as being correct. With a knee mill or dovetail column the head moves on, then just how straight is it in a true vertical alignment over it's full travel distance. For any machine tool slide, there's 6 possible directions or combinations that a slide can vary or be twisted. And those misalignment's may not be constant or can even reverse direction over the travel length. Then how square is the tables Y axis to the X axis. Most assume all that is correct, actually checking might surprise a few. Again a few simple tools most already have and a dti can also do that, although a boring head can be helpful as well for checking those knee or column alignments. Fortunately most of those only have to be verified once and then many years later. |
JasonB | 01/10/2023 07:38:10 |
![]() 25215 forum posts 3105 photos 1 articles | Posted by Greg Webb 1 on 30/09/2023 18:56:11:
If the jig was a tube without any angle, would finding the centre at the base and then at the top by moving the quill up give a difference if the head was not trammed. You then start to get into the realms of which do you tram, usually the spindle axis is trammed to th emill table but there is also colum to table and quill movement to table to be considered which may show* * however it still comes down to showing tiny deviations over a short distance that you would be hard pushed to see. As Pete says even with perfect tram you may get slight back cutting as the front pass may deflect the spindle slightly upwards and also cause minute flex in the machine particularly if your facemill has the blunter inserts which means that as the deflection and movement is removed once the front edge has cleared the work the tool drops down and takes a skim on the trailing edge |
Nealeb | 01/10/2023 07:53:32 |
231 forum posts | Biggest issue with this tramming game I have found, on both a Warco VMC and a Wabeco 1400 which both have variations on swivellling heads, is less about how to measure any errors and more about how to move the head under control to remove them. Usually ends up with soft-faced hammer on a non-critical part of the head, but it's not something I like doing to the machine, especially when there is a DTI in place to show the movement. And then re-clamping without the head moving... |
Chris Mate | 01/10/2023 12:23:32 |
325 forum posts 52 photos | Hi Neabb, I did bolted a long thick aliminium bar to the top of my mill head to assist in moving the head, and it does help a lot making it easier, the leaverage is such I can bump it wih my fist, however I see in future I will make something "fexable" to adjust it accurately with two opposing bolts, like I do with vice and zeroing the X-Axis swivel function, no bumping.
Edited By Chris Mate on 01/10/2023 12:24:52 |
Chris Mate | 01/10/2023 13:15:57 |
325 forum posts 52 photos | 30mm x 90cm aliminium bar bolted to head to make it easier to move, tap with fist. |
Graham Meek | 02/10/2023 10:30:13 |
714 forum posts 414 photos | Whilst the theory may be good, introducing the tapered component also introduces other errors. If the taper is not dead square to the face in contact with the table. This will be a source of error as an elliptical path will be shown straight away. Adjusting the Head to suit this condition will give an error on a true vertical. I am also not keen on the amount of extension being shown on the Quill. The Quill might well show two different conditions as regards vertical due to the amount of Quill engagement in the Head casting. I don't think you can beat the clock on the table, or a known parallel, but again with the minimum of Quill extension. Regards Gray, |
Greg Webb 1 | 02/10/2023 10:43:28 |
26 forum posts 2 photos | I don't think you can beat the clock on the table, or a known parallel, but again with the minimum of Quill extension.
I was always taught to have the quill at full extension for better accuracy. Does anyone have a definitive answer with an explanation or reference to the reason for extended or retracted?
Thanks |
Tony Pratt 1 | 02/10/2023 11:03:55 |
2319 forum posts 13 photos | Posted by Greg Webb 1 on 02/10/2023 10:43:28:
I don't think you can beat the clock on the table, or a known parallel, but again with the minimum of Quill extension. I totally agree that you can't beat the 'clock on the table ,or a known parallel' method of tramming but I was always taught to have the quill fully extended , thinking about it I don't know why so would be best to have it fully retracted. As an aside our Swiss made Genevoise jig borers were serviced once a year and they checked the quill squareness with a long arm at 90 degrees plus DTI straight onto the table, enough said I think! Tony |
Andrew Johnston | 02/10/2023 11:11:18 |
![]() 7061 forum posts 719 photos | For a fixed rotation point of the head and a given angular error with an extended quill the point of rotation of the Dti will be further off true centre, but I am not convinced it makes any difference to the vertical readings fro the DTI. I always have the quill retracted and locked when milling, so it seems reasonable to tram in that position. Andrew |
JasonB | 02/10/2023 11:13:30 |
![]() 25215 forum posts 3105 photos 1 articles | My thinking is that I use the mill with minimal quill extension when cutting so that is the best way to check the tram, as Graham says it may well be different when extended so why test it in that position. Even having the quill free or locked is likely to affect readings, so test it as you are likely to use it would be my way of doing things. |
Greg Webb 1 | 02/10/2023 12:19:35 |
26 forum posts 2 photos | As an aside our Swiss made Genevoise jig borers were serviced once a year and they checked the quill squareness with a long arm at 90 degrees plus DTI straight onto the table, enough said I think! Tony I agree, they see the advantage of measuring far away from the pivot point. Looking at the difference between extended & retracted perhaps reason for extended is that it is a little easier to hit the number you want on the dti. The dti will move the same distance over a longer arc allowing the reading to be less sensitive to linear movement.
Pete | 02/10/2023 13:01:38 |
128 forum posts | With a knee mill or one with a dovetail column the head moves on, it's much better to have that quill fully retracted for some simple reasons. Extending it out transmits much more leverage on the head due to the machining loads trying to move the head back out of tram. Add the vibrations from cutting and the head can still move even when solidly bolted in place. All 4 of the head bolts on mine are torqued to 45 lb. ft. and I've still had the head move on me over some time. A fully retracted quill is also much more rigid the closer you can get the tool tip doing the work to the spindle bearings. So more accurate dimensions on your parts with less taper due to distortion in the head and spindle, plus a bit better surface finishes. An extended quill and the side loads from something like a larger end mill, then that extra leverage increases the loads on the spindle bearings. And the rear dovetail column mills aren't that rigid. Extend the quill and that leverage problem is going start flexing and bending that column. That's one reason something like an ER collet chuck is less capable taking very heavy cuts over a Morse Taper or R8 collet. With those the tool itself is a lot closer to those bearings. Industry almost universally uses ER collet chucks because of those tool changers, Or for real rigidity, hydraulic and shrink fit tool holders. The only time I use the quill on my knee mill is when drilling, tapping, reaming or single point boring. Anything else and the quill is retracted and locked and the knee used for any Z axis moves. That's also imo more accurate for precise elevation changes since gravity is always forcing all that weight of the table and knee fully down against the knees feed screw thread flanks so there's no backlash. The only down side is how many times you have to turn the crank handle. |
Greg Webb 1 | 02/10/2023 13:48:34 |
26 forum posts 2 photos | I use a solid stop system to give a repeatable stop & rigidity to my Bridgeport quill. It eliminates the play in both the nut & the adjusting screw circlip. The videos show the system & the issues with the original setup. Solid stop system. |
