See photo
Milly S | 27/09/2023 18:59:03 |
42 forum posts 9 photos | Hi all does anyone on this forum have a Chipmaster please reply thanks steve |
Ady1 | 27/09/2023 19:31:07 |
![]() 6137 forum posts 893 photos | If you say what the issue is and expand with a picture or two the guys in here are pretty good Edited By Ady1 on 27/09/2023 20:05:46 |
Milly S | 27/09/2023 19:51:45 |
42 forum posts 9 photos | Hi ady I posted a picture a few days back got no reply so I thought I would try again this time just asking for Chipmaster owners in the photo I posted it showed 2 holes 1 in headstock & 1 just behind chuck These were in the machine when I bought it a couple of month back I was wondering if they had a specific use or if someone had tried to add something they both have grub screws in just wondering if any other chipmastes have these holes in as this is the 1st time I’ve bought a Chipmaster thanks for replying regards steve |
Pete Rimmer | 28/09/2023 08:04:03 |
1486 forum posts 105 photos | Lathes are full of random tapped holes, have you checked out your cross slide I bet it also has a good few holes drilled and tapped and plugged with grub screws. Have a look here for manuals and brochures. It might not answer yuor question but it'll give you a lot of good info about the chippy.
https://passion-usinages.forumgratuit.org/t1576-colchester-chipmaster |
Daggers | 28/09/2023 09:12:45 |
52 forum posts | I have looked at the headstock drawing and it shows the hole in the headstock fitted with two grub screws for retaining the headstock oil channel. The other hole seems to show an oil nipple fitted, presumably for lubrication. |
Milly S | 28/09/2023 18:35:11 |
42 forum posts 9 photos | Hi daggers thanks for info on headstock the hole in the headstock has got 2 grub screws in the same hole in relation to each other thanks steve |
Milly S | 28/09/2023 18:37:49 |
42 forum posts 9 photos | Hi Pete thanks for your reply haven’t had a chance to download web site you posted I’ll try to get to it tonight’ cheers steve |
Daggers | 28/09/2023 18:50:09 |
52 forum posts | Steve, it does not show fitting. My guess is that the first grub screw is used to tighten on to the oil gallery, this looks like a tube with a number of cut outs. And when this tube is locked the second grub screw is run down to the first grub screw to lock it in position, just as you would use a lock nut. john |
DC31k | 28/09/2023 19:02:12 |
1186 forum posts 11 photos | Posted by Daggers on 28/09/2023 09:12:45:
The other hole seems to show an oil nipple fitted, presumably for lubrication. You are right about it being the "other hole" because the one to which you refer is in an-other part altogether. The oil nipple is in the clutch housing. The grub screw to which the OP refers is in the front spindle bearing cover. In a later manual (from SER 3311, diagrams CHIP-01-70 and CHIP-02-70) the longer grub screw goes into the headstock casting first. The shorter one on top of it is presumably to act as a lock bolt so the one below does not back out due to vibration. The front bearing cover in the manual shows no grubscrew, but the item 1146, labelled 'peg' looks too coincidently to be in the same general location as the grubscrew for them not to be related. In every Chipmaster I have seen, in both locations, the factory paint has been applied over the grubscrews. |
Milly S | 28/09/2023 21:38:24 |
42 forum posts 9 photos | Hi all I’d just like to say thanks for your help As always everyone is very helpful I just hope i can return the favour one day cheers steve |
Emgee | 28/09/2023 22:25:16 |
2610 forum posts 312 photos | Hi Steve Could be helpful for you to join the Colchester group at iO Groups, there are likely Chipmaster owners there who may be able to answer any future questions, join at this link: Emgee |
Milly S | 01/10/2023 20:11:16 |
42 forum posts 9 photos | Hi emgee thanks for the link cheers steve |
