Where are my online posts?
David-Clark 1 | 17/09/2023 10:17:00 |
![]() 271 forum posts 5 photos | Hi All. How do I search albums on this forum, posts as well. I did quite a few post's, photos and articles many years ago but can’t see how to find them. One of interest is the article I wrote about fitting a chuck to a backplate.
My user name back then was David Clark 1 but I don’t have access to the hobby store email for that account so can’t log in. Suggestions are welcome.
Stuart Smith 5 | 17/09/2023 10:22:25 |
349 forum posts 61 photos | David Is the article on the backplate? I did a search using the search box near the bottom of the home page. I searched for ‘David Clark 1 backplate’ and this came up. or this one: ‘David Clark 1 album’ https://www.model-engineer.co.uk/albums/member_albums.asp?c=42726
Stuart Edited By Stuart Smith 5 on 17/09/2023 10:26:39 |
Ady1 | 17/09/2023 10:33:50 |
![]() 6137 forum posts 893 photos | It can be a bit convoluted in here I try and find specifics via google on the ME home page and use any thread post for posts and piccies Edited By Ady1 on 17/09/2023 10:38:17 |
David-Clark 1 | 17/09/2023 10:50:12 |
![]() 271 forum posts 5 photos | Thank you Stuart, that is the one I was looking for. |
David-Clark 1 | 17/09/2023 10:54:47 |
![]() 271 forum posts 5 photos | Actually, there should be an article on drilling 24 holes in the face of the backplate, I could do with a copy of this article. I think it had a listing of the program I used. I could do with this listing for my new (to me) CNC mill. |
David-Clark 1 | 17/09/2023 11:07:29 |
![]() 271 forum posts 5 photos | Hi Stuart I searched using the google search at the top of the home page but nothing was found. I can’t see a search box lower down the page. |
SillyOldDuffer | 17/09/2023 11:16:51 |
10668 forum posts 2415 photos | The forum doesn't help much with searching. The 'Search This Site' box top-right looks for basic word matches in Post Titles. Not wonderful. Much better is the Google Search hidden away half-way down the home page. Also possible to to search the forum directly with advanced search syntax in your browser. For example: SillyOldDuffer site:model-engineer.co.uk causes your internet search engine to only return hits from model-engineer.co.uk The syntax is standard, works for me with DuckDuckGo, should also be good with Google, Bing and the other usual suspects. By default albums are created 'Public', and there's no need to login to explore them. Be quick! The forum is about to be replaced, maybe next month. Images in an album that aren't referenced by a post will be lost. Dave
Stuart Smith 5 | 17/09/2023 11:44:53 |
349 forum posts 61 photos | David The Google search box is near the bottom of the home page Stuart |
David-Clark 1 | 17/09/2023 11:59:47 |
![]() 271 forum posts 5 photos | Thank you Stuart, I found it now. I was not on the home page. Silly old differ. “Be quick! The forum is about to be replaced, maybe next month. Images in an album that aren't referenced by a post will be lost.”
Is the forum being replaced completely? It has always been quirky, probably because it was custom built.
It would be a shame to lose all this knowledge, almost 20 years with. I hope it will be accesible in the future, to valuable to be lost. I found the CNC drilling article I wanted. Thank you all for your help.
JasonB | 17/09/2023 13:02:45 |
![]() 25215 forum posts 3105 photos 1 articles | All old posts will be brough forward, just new software and format |
Ady1 | 17/09/2023 13:13:26 |
![]() 6137 forum posts 893 photos | Posted by David-Clark 1 on 17/09/2023 11:59:47:
The Yahoo farce lost millions of hours of useful human knowledge, this place is just a blip in comparison Once they trash Wikipedia there won't be a decent useful repository of human knowledge on the entire internet Times they are a-changing |
David-Clark 1 | 17/09/2023 13:17:44 |
![]() 271 forum posts 5 photos | OK, I hope it works OK, I have reservations. |
JasonB | 17/09/2023 13:18:53 |
![]() 25215 forum posts 3105 photos 1 articles | You are not alone |
David-Clark 1 | 17/09/2023 13:26:06 |
![]() 271 forum posts 5 photos | I had reservations back when the forum was started. I believe as editor of the magazines I was the first member other than the site designer. He built the whole thing from scratch, hence the difficulty of not being able to modify it to overcome problems. |
Martin Connelly | 17/09/2023 15:48:24 |
![]() 2549 forum posts 235 photos | If I was going to drill 24 holes in the face of a backplate I would set the x and y zero on the centre of the backplate then after drilling the first hole use G68 to rotate the coordinate system 15°, drill the next hole, rotate another 15° and repeat until 24 holes have been drilled. (set up for first hole) (code to drill hole) G68 A0 B0 R15 (code to drill hole) G68 A0 B0 R30 (code to drill hole) etc
Martin C |
JasonB | 17/09/2023 16:20:53 |
![]() 25215 forum posts 3105 photos 1 articles | I'd just let F360 write the code after clicking one hole. But it all comes down to what you have so marking out using a Myford Bull gear and compromised indent may have to do. |
Neil Wyatt | 19/09/2023 21:57:49 |
![]() 19226 forum posts 749 photos 86 articles | The new forum software works, but there are still lots of wrinkles to iron out... Neil |
David-Clark 1 | 19/09/2023 22:14:43 |
![]() 271 forum posts 5 photos | Hi Neil
Jason, I think a Myford Bull wheel is 65 teeth. Not ideal for dividing. |
JasonB | 20/09/2023 07:03:49 |
![]() 25215 forum posts 3105 photos 1 articles | Some are 60 depending on the model I believe, if not stick a change wheel on the far end of the spindle. Not sure about wrinkles, more like hills and valleys |
