Andy_H | 05/09/2023 11:30:58 |
56 forum posts 4 photos | I've been looking at an electric motor. In the HP section of the motor plate it says "25M" (yes, it is "M" and not "W" Any idea what that really means? Andy |
bernard towers | 05/09/2023 11:59:49 |
1221 forum posts 161 photos | Manufacturer and model plus case size might help |
Andy_H | 05/09/2023 12:31:37 |
56 forum posts 4 photos | This is the label. Not sure it really helps - there's no manufacturer and the model no does not yield anything on Google. I'm wondering if it's an odd decimal notation that signifies 0.025 HP - which would be ~18W |
noel shelley | 05/09/2023 12:44:20 |
2308 forum posts 33 photos | 50Hz 1425 rpm 230v ccw rotation, continous duty cycle.. 0.53a is odd and does not tally with .25Hp ? 180watt would be .25 Hp. Could it be ex military ? Noel. |
Andy_H | 05/09/2023 16:02:15 |
56 forum posts 4 photos | Posted by noel shelley on 05/09/2023 12:44:20:
0.53a is odd and does not tally with .25Hp ? 180watt would be .25 Hp. I agree. And my thought about being notation for 0.025HP doesn't stack up either! Andy |
SillyOldDuffer | 05/09/2023 16:54:06 |
10668 forum posts 2415 photos | Posted by Andy_H on 05/09/2023 16:02:15:
0.53a is odd and does not tally with .25Hp ? 180watt would be .25 Hp. I agree. ...But it's about right for .125 HP (Metric) My guess is a stamping mistake - the plate is missing a decimal point and a 1 I expect an apprentice did it! Dave |
duncan webster | 05/09/2023 17:25:57 |
5307 forum posts 83 photos | Just multiplying volts by amps gives 122W. O. 125hp is 95W.this implies 80%efficiency, which is on the high side for a fhp motor. BUT we've forgotten the power factor, real power isn't volts * amps for a reactive load. I've no idea what 25M means. |
Andy_H | 05/09/2023 21:33:09 |
56 forum posts 4 photos | Posted by duncan webster on 05/09/2023 17:25:57:
Just multiplying volts by amps gives 122W. O. 125hp is 95W.this implies 80%efficiency, which is on the high side for a fhp motor. BUT we've forgotten the power factor, real power isn't volts * amps for a reactive load. I've no idea what 25M means. I think I've worked it out. I believe the "M" denotes metric horsepower. That's the units sussed. As for the value I conclude it must be 0.25 but with the decimal point missing. The quoted voltage and current product is 122W which implies about 66% efficiency. Andy
noel shelley | 05/09/2023 22:24:21 |
2308 forum posts 33 photos | metric Hp is Ps I think ? And a horse is a horse imperial or foreign ! I would fall for 0.125 Hp then the rest is about right. Noel. |
duncan webster | 05/09/2023 22:41:05 |
5307 forum posts 83 photos | Metric hp is only very slightly less than imperial, so this doesn't sound right to me |
Andy_H | 06/09/2023 07:39:44 |
56 forum posts 4 photos | Posted by noel shelley on 05/09/2023 22:24:21:
metric Hp is Ps I think ? And a horse is a horse imperial or foreign ! I would fall for 0.125 Hp then the rest is about right. Noel. I think PS is probably more common but, according to Wikipedia: Metric Horsepower: hp(M) – also PS, KM, cv, hk, pk, ks or ch Andy |
Michael Gilligan | 06/09/2023 08:53:07 |
![]() 23121 forum posts 1360 photos | So we have a 25 Metric Horsepower motor, in a surprisingly compact and efficient package
noel shelley | 06/09/2023 09:40:47 |
2308 forum posts 33 photos | Yes Michael ! And they also manufacture free lunches ! Oh, They also build perpetual motion machines as well. Noel. |
Michael Gilligan | 06/09/2023 10:55:42 |
![]() 23121 forum posts 1360 photos | … which was the point of my |
not done it yet | 06/09/2023 14:16:35 |
7517 forum posts 20 photos | It looks, to me, likely to be a synchronous induction motor of about 90 Watts? Just working on current, assumed power factor of Cos Theta = 0.8 and likely heat losses. A pic of the motor might help. A usual 1/4 horse power induction motor would consume rather more than 1/2 an Amp and not be of fixed rotation. As to the HP - maybe it was supplied by Hewlett Packard? (Joke)
duncan webster | 06/09/2023 15:40:09 |
5307 forum posts 83 photos | Surely a synchronous motor would be 1800/1500 rpm. |
Ian Parkin | 06/09/2023 15:50:49 |
![]() 1174 forum posts 303 photos | The slower speed duncan is because of slip its still a sychnonous motor |
duncan webster | 06/09/2023 16:55:54 |
5307 forum posts 83 photos | Not according to this A synchronous motor has magnets attached to the rotor (typically permanent magnets, but could be electromagnets and slip rings) and runs at some fraction of mains frequency, in this case it would be 1500 rpm. An induction motor by definition cannot be synchronous |
not done it yet | 06/09/2023 17:51:05 |
7517 forum posts 20 photos | Synchronous/asynchronous. Point taken. I meant the type of motor on the typical scavenge pump on a dishwasher/ washing machine. Can’t remember what they are called. Fixed direction, cheap and also found on cooker oven fans. |
duncan webster | 06/09/2023 18:13:54 |
5307 forum posts 83 photos | Main dishwasher pump motor 3000 rpm (nominal) induction motor, I recovered one and used it on a drill grinding thing. Not well guarded, so I had to make up some covers. |
