colin hamilton | 26/08/2023 07:53:21 |
186 forum posts 94 photos | Help identifying these would be appreciated. They are thread m10 on the end
Thanks Colin
Peter Krogh | 26/08/2023 08:30:07 |
![]() 228 forum posts 20 photos | Special made internal wrenches, but I can't imagine what for! Pete |
HOWARDT | 26/08/2023 08:38:35 |
1081 forum posts 39 photos | Thread insert tools? Can’t quite work out with the numbers on the one I can see, first ought they may be insert tools or tang break off but the length doesn’t equate or the long grooves on the diameter. |
Andy_G | 26/08/2023 09:20:30 |
![]() 260 forum posts | Internally threaded router bits. Like these |
SillyOldDuffer | 26/08/2023 11:04:53 |
10668 forum posts 2415 photos | Posted by Andy_G on 26/08/2023 09:20:30:
Internally threaded router bits. Like these I thought 'chipboard' straight away. Then wood work. |
Mark Easingwood | 26/08/2023 12:19:59 |
![]() 53 forum posts 16 photos | Hello, Not sure they are router cutters, but they might well be "slot mortise bits," generally used in the furniture making industry, as opposed to the Joinery manufacturing industry. I think the KITY range had a slot mortise attachment. Mark.
HOWARDT | 26/08/2023 12:42:16 |
1081 forum posts 39 photos | The one in you hand has M10 on it, are they threaded for mounting? |
Andy_G | 26/08/2023 18:49:35 |
![]() 260 forum posts | Posted by Mark Easingwood on 26/08/2023 12:19:59:
Not sure they are router cutters, but they might well be "slot mortise bits," generally used in the furniture making industry, as opposed to the Joinery manufacturing industry. They could probably be either, but those don't look (to me) like they have end cutting ability that I think a slot morticer would need (but there are probably more types than I know about). M10 internal seems to be used on all sorts of industrial routers (hand or bench), morticers, etc.. Seems common for automated routers for PVC window frame construction. Have a look for 'Rotox' cutters: (Example ) (Other makes using the same fixing are available).
colin hamilton | 27/08/2023 13:47:55 |
186 forum posts 94 photos | Thanks everyone. So it looks like they are for wood working. I'll stick them on a shelf somewhere and forget that I have them!! |
colin hamilton | 27/08/2023 13:48:06 |
