Dalboy | 23/08/2023 12:55:23 |
![]() 1009 forum posts 305 photos | Has anyone found a free equivalent to microsoft works, especially Word and Publisher. I do not use them enough to warrent paying for a package that I will only use three or four times a year. If I was to use them a lot of the time then paying would not be a problem |
Steve F | 23/08/2023 13:01:59 |
![]() 101 forum posts 25 photos | Hello I use LibraOffice. You can get it here **LINK** It's free and if you use msoffice you will recognise a lot of the apps. It does word, excel etc regards Steve |
DiogenesII | 23/08/2023 13:31:30 |
859 forum posts 268 photos | ..or Open Office. Used it for several years with no issues either opening or sending.. |
Oldiron | 23/08/2023 13:44:32 |
1193 forum posts 59 photos | Posted by DiogenesII on 23/08/2023 13:31:30:
regards |
ega | 23/08/2023 14:51:40 |
2805 forum posts 219 photos | Plus one for LibreOffice but it will be hard to make a judgment about any program that is used only three or four times a year! |
roy entwistle | 23/08/2023 14:54:08 |
1716 forum posts | Another plus for LibreOffice Roy |
File Handle | 23/08/2023 15:21:22 |
250 forum posts | Another lover of Open Office / Libre Office. |
duncan webster | 23/08/2023 15:27:11 |
5307 forum posts 83 photos | |
Bazyle | 23/08/2023 15:43:21 |
![]() 6956 forum posts 229 photos | Note that Libre uses its own format to save so you have to make a special copy for sending to people who use MS. Not sure what publisher provides but you may need some other program for that. |
SillyOldDuffer | 23/08/2023 16:11:14 |
10668 forum posts 2415 photos | Posted by Bazyle on 23/08/2023 15:43:21:
Note that Libre uses its own format ... Not exactly. Libre outputs Open Document Format, which is non-proprietary. MS-Word should be able to read it. By default MS-Word uses proprietary files, which other software can usually read, but not necessarily perfectly. For ordinary purposes, not doing anything advanced, Libre/Word incompatibility doesn't seem to a major problem. Your mileage may vary!!! Libre (and MS-Word) can both work with a long list of other file formats. Dave |
Dalboy | 23/08/2023 16:15:55 |
![]() 1009 forum posts 305 photos | Thank you all will have a look at those mentioned |
File Handle | 23/08/2023 17:32:57 |
250 forum posts | Posted by SillyOldDuffer on 23/08/2023 16:11:14:
Note that Libre uses its own format ... Not exactly. Libre outputs Open Document Format, which is non-proprietary. MS-Word should be able to read it. By default MS-Word uses proprietary files, which other software can usually read, but not necessarily perfectly. For ordinary purposes, not doing anything advanced, Libre/Word incompatibility doesn't seem to a major problem. Your mileage may vary!!! Libre (and MS-Word) can both work with a long list of other file formats. Dave One advantage of libre that I found when I was teaching, libre will often open Word files that MS word won't, resaving as word files then fixes the issue for Word. |
Vic | 23/08/2023 17:36:01 |
3453 forum posts 23 photos | I found Libre Office can open more old legacy file types than Open Office so I only use LO now. The interface on both is not that good in my opinion but it can be customised to some extent which is well worth doing. |
