Homemade Manometer Ideas
Dark Knight | 10/08/2023 07:58:18 |
7 forum posts 3 photos | Hello, Im building small steam engine on my lathe and I have come to a point where i need manometer on my boiler. Im looking for ideas how to build it. My own first idea was making small cilinder with a piston that has piston rod spring loaded. Then i would make vertical dial on cilinder, calculate spring elastic energy and calculate distance for each bar then i drill small hole on proper calculated distance for each bar. (max3). Sorry if my english is bad, Im not from UK, Any other ideas appreciated. Martin |
Paul Lousick | 10/08/2023 11:12:14 |
2276 forum posts 801 photos | Hello Martin. Do you mean a manometer or a pressure gauge ? A manometer is a U shaped tube, used for measuring small pressure. Steam boilers usually have a pressure gauge. Small pressure gauges are available from model supply stores. Do a google search for pressure gauge construction if you want to build your own. (not an easy project if you only have basic tooling) Paul Edited By Paul Lousick on 10/08/2023 11:16:08 |
Samsaranda | 10/08/2023 11:21:35 |
![]() 1688 forum posts 16 photos | A manometer would not be any use in the situation of measuring steam pressures as it consists of a tube that is open to atmosphere at one end, you definitely need a pressure gauge, please be aware of the correct way to connect the gauge to your boiler system. Dave W |
not done it yet | 10/08/2023 11:32:57 |
7517 forum posts 20 photos | Yep, as above (for most measurements). One Bar would equate to ~760mm of mercury, or approx 10m of water! Most manometers for low pressure differences are filled with oil of less than unity density (specific gravity) unless of a temporary nature.🙂 |
Martin Connelly | 10/08/2023 11:55:45 |
![]() 2549 forum posts 235 photos | Paul, sorry but I am going for the pedant role here Tubes for manometers are not always U shaped. I went to a museum at Farnborough where they had test equipment used in the investigations into flight and the design of aerofoils. Their manometers were V shaped with one leg vertical and the other sloping at about 30° from the horizontal in order to make the difference in levels more readable. Additionally at work we hade low pressure differential transmitters by Rosemount that were referred to as manometers even though there was no tube of any shape containing liquid. Martin C |
SillyOldDuffer | 10/08/2023 12:31:06 |
10668 forum posts 2415 photos | Welcome to the forum Martin I guess you want a pressure gauge rather than a manometer. A manometer is a particular form of pressure gauge, and the type isn't really suitable for a steam engine. (The range of pressure they can measure is small, they're physically big, and don't like vibration.) Your piston and spring would work. As would weights holding a V shaped piston down like a safety-valve. The problem with both is stopping the piston from leaking. Mr Bourdon came up with a good answer in 1849 and this type of gauge is very common today. They're cheap, reliable and cover most ranges needed. Bourdon bent a flattened tube into a curve, which is also a spring. No leaks because the tube is sealed at the far end. When the springy tube is pressured, it straightens out in proportion to the pressure. The resulting small movement is used to drive a needle through an amplifying step-up lever and gears. Rarely home-made these days because commercial gauges are so cheap and come calibrated and ready to go. Though I've never seen a published design people occasionally make their own: I gather the tube is the main problem. Usually Brass, it has to be springy enough to provide the wanted pressure range - not too stiff, or too light. Springiness depends on the type of Brass, how hard it is, the diameter of the tube, and the thickness of the walls. The radius of the tube matters too, and it can be coiled. The tube is flattened so that it opens out in one direction: round tubes move sideways as well as out. Gauge manufacturers have all the information needed, but I don't think it's been made public. Therefore, a home-builder has to experiment. Great fun, but far quicker to buy one rather than build it. There are other possibilities: if electronics are allowed, a strain-gauge could substitute for the needle, gear and lever assembly, and the range covered is decided by an amplifier. Electronic pressure gauges are available but ones that work at high temperature and pressure are expensive. Worth it for logging data or informing an engine management unit, but a pricey fuss if all that's wanted is a visual indication of boiler pressure. Please report back. Be really good is someone built a Bourdon Gauge and explained how they did it. Dave
Martin Johnson 1 | 10/08/2023 12:41:44 |
320 forum posts 1 photos | There is another type of gauge which would be closer to the OP's original idea. A description of the diapragm gauge can be found here: https://instrumentationtools.com/diaphragms/
However, if the OP could give more detail of their project and thei country, we might be able to recommend an off the shelf solution. Martin |
Dark Knight | 10/08/2023 12:55:59 |
7 forum posts 3 photos | . Edited By Dark Knight on 10/08/2023 13:10:02 |
Dark Knight | 10/08/2023 12:56:00 |
Martin from Slovenia
Edited By Dark Knight on 10/08/2023 13:17:37 |
duncan webster | 10/08/2023 14:25:26 |
5307 forum posts 83 photos | Your idea will work to an extent, but friction in the seal will cause a lot of hysteresis, so when pressure is rising it will read low, and when it's falling it will read high. Because of stick slip you might find it changes in jerks. If you could find a metal bellows it would be better, but a difficult search Edited By duncan webster on 10/08/2023 14:29:13 |
Howard Lewis | 10/08/2023 15:09:01 |
7227 forum posts 21 photos | In Uk, and in many nbother countries, a manometer is, as said, often a U tube filled with a fluid. The pressure is measured as the difference in height between the two columns The largest that I ever used was to mesure boost pressures of the orfer of 1.7 m of Mercury. For lesser pressures our manometers were of a different, proprietary for, but still using Mrcury as the fluid. For small pressures, water or light oil can be used. To measure boiler pressures, what you need is a Bourdon tube type pressure gauge, as previously illustrated. They should be available from model engineering suppliers, in Uk, such as Reeves. Howard |
Speedy Builder5 | 10/08/2023 15:52:03 |
2878 forum posts 248 photos | A similar but more "sophisticated" oil pressure button was used on early Austin 7 cars however the engine pressure rarely rose above 20psi and normal running was probably 5psi. |
Jeff Dayman | 10/08/2023 16:45:30 |
2356 forum posts 47 photos | When one can buy a well made and fairly accurate bourdon type pressure gauge for around 8 US dollars (or your local equivalent) why are we discussing ways for the OP make an inferior alternate? See link to e b ay example candidate below. https://www.ebay.ca/b/Air-Pressure-Gauges/183985/bn_1519221 |
noel shelley | 10/08/2023 18:13:01 |
2308 forum posts 33 photos | There was I'm sure an article about making pressure gauges in ME awhile ago. Remember if you buy one to allow 150 or 200% over reading. Noel |
Michael Gilligan | 10/08/2023 20:02:01 |
![]() 23121 forum posts 1360 photos | Posted by Jeff Dayman on 10/08/2023 16:45:30:
When one can buy a well made and fairly accurate bourdon type pressure gauge for around 8 US dollars (or your local equivalent) why are we discussing ways for the OP make an inferior alternate? […] . As a disinterested and uninterested observer … I would guess it’s something to do with Model Engineering vs playing with trains. MichaelG. |
Simon Williams 3 | 10/08/2023 21:26:15 |
728 forum posts 90 photos | Dunno nuffing about the rules in Slovenia, but in the UK one of the fundamental requirements under the Pressure System Regulations is to have a calibrated and reliable means of indicating the pressure in a pressure vessel at all times. I don't believe (though I'm ready to be corrected) that this requirement is relaxed for a vessel below the relevant bar-volume exemption for low pressure/low volume systems. A simple risk assessment indicates that a pressure gauge is necessary. If I was the insurer I'd want to see such a safety critical feature of the system present and demonstrably correct. <Edited for minor typo> Edited By Simon Williams 3 on 10/08/2023 21:27:38 |
Nigel Graham 2 | 10/08/2023 21:28:17 |
3293 forum posts 112 photos | I'm a bit puzzled by the small holes in the side of the cylinder in the sketch. They make the device look more like a simple pressure-regulator. I can understand a piston-type gauge working by graduations on the rod protruding from the top though. However, it is normal practice to give the gauge or sensor some protection from the hot steam by a U-bend in the tube from boiler to gauge. Often called a "syphon" though it is not really a syphon, it becomes partly filled with water so the gauge feels only air at the boiler pressure. |
Dark Knight | 11/08/2023 08:45:58 |
7 forum posts 3 photos | | Posted by Nigel Graham 2 on 10/08/2023 21:28:17: I'm a bit puzzled by the small holes in the side of the cylinder in the sketch. They make the device look more like a simple pressure-regulator. I can understand a piston-type gauge working by graduations on the rod protruding from the top though. However, it is normal practice to give the gauge or sensor some protection from the hot steam by a U-bend in the tube from boiler to gauge. Often called a "syphon" though it is not really a syphon, it becomes partly filled with water so the gauge feels only air at the boiler pressure. ---------------------------------------------------------------------------------------------------------------------- Maybe i should remove O-Ring on piston and put inside cilinder Φ6mm transparent pneumatic tube and this would seal piston from leaking and the piston position on holes would still be clearly seen becouse of transparent pneumatic tube.
Edited By Dark Knight on 11/08/2023 08:52:30 |
Nigel Graham 2 | 11/08/2023 08:51:45 |
3293 forum posts 112 photos | You could make a gauge like that, with a scale along the side of the tube, but you'd certainly need protect the tube from the heat of the boiler. Or use boiler gauge-glass tube. |
Dark Knight | 11/08/2023 09:02:09 |
7 forum posts 3 photos | Posted by Nigel Graham 2 on 11/08/2023 08:51:45:
You could make a gauge like that, with a scale along the side of the tube, but you'd certainly need protect the tube from the heat of the boiler. Or use boiler gauge-glass tube. I can make U-tube bend from copper like you said, maybe I should check tables for different types of plasic and their temperature points to see at what temperature range it softens. Also is this gauge-glass tube purchasable, i have never seen it, maybe i could cut glass test tube. |
