Bazyle | 18/07/2023 10:08:36 |
![]() 6956 forum posts 229 photos | I'm looking at a 1972 4hp B&S where the previous owner has diagnosed 'no spark' and got a replacement magneto coil, and the old one is still attached by a black wire. I found a really good strip down video on youtube which shows me I am missing at least the speed control vanes in the airflow. |
Speedy Builder5 | 18/07/2023 10:46:41 |
2878 forum posts 248 photos | Is one wire the alternator wire for those engines that have a battery / electric starter ?? |
Ady1 | 18/07/2023 11:04:29 |
![]() 6137 forum posts 893 photos | On old Ford escorts the coil is active until the points open The points open and as the magnetic field collapses it induces a high voltage which travels through the insulated lead into and across the spark plug gap You probbly know this but I'm just saying |
noel shelley | 18/07/2023 11:05:05 |
2308 forum posts 33 photos | Are you sure its 4Hp not 3.5Hp ? The modern ie 80s onwards models had a electronic ignition and NO points. They were interchangeable ! one wire went to ground the other to the stop button/control. I dont think the points version has been available for decades. There were many models the numbers were stamped on the air duct over the head. If you need more info I will find my briggs manual ? Noel. Edited By noel shelley on 18/07/2023 11:09:49 |
Ady1 | 18/07/2023 11:07:10 |
![]() 6137 forum posts 893 photos | Electronic ignition is a massive improvement if you can fit it |
Bazyle | 18/07/2023 11:29:53 |
![]() 6956 forum posts 229 photos | Thanks. It is '72 as the serial number is date specific. The machine it is from was advertised as 4hp. I'll check the model no later. |
Tony Pratt 1 | 18/07/2023 11:33:31 |
2319 forum posts 13 photos | I too have a manual but will need full details to get any further, also B & S spares suppliers have full diagrams of engine/ignition components. Tony |
Jeff Dayman | 18/07/2023 14:04:45 |
2356 forum posts 47 photos | The loose wire is likely to a kill switch that shorts the coil primary to shut off the engine. |
not done it yet | 18/07/2023 15:29:18 |
7517 forum posts 20 photos | It might say 4HP but B&S rated their engines on a ‘flash’ basis, not what the engine would provide when running continuously under power. They continued in that way until people noticed that a 3HP engine from Honda out-performed a 5HP `B&S. |
Robert Butler | 18/07/2023 17:53:43 |
511 forum posts 6 photos | Bazyl All genuine Briggs & Stratton ignition/carburation parts come with fitting instructions. The points system has been obsolete for years. The replacement converts the old points system to electronic ignition with minimal fuss. The spare lead is for the sop start or emergency stop start. I note the cost has risen significantly since replacing the ignition for a friend a few years ago. However, much like Myford who else would be supporting 40 - 50 year old machnes or engines. If you require fitting instructions send me a PM with your email address and I can forward a copy to you. Robert Butler Edited By Robert Butler on 18/07/2023 17:54:37 |
Bazyle | 18/07/2023 22:40:22 |
![]() 6956 forum posts 229 photos | It does make sense that the spare wire is for a stop switch though I have not seen this mentioned on other sources wrt the engine so well done this forum. The model number is 100232-0036-01 and they seem to be quite common. The go-to engine before Honda appeared on the scene. |
noel shelley | 19/07/2023 00:15:24 |
2308 forum posts 33 photos | If the coil is of the points type there will be a gap both sides between the coil and the laminations ! If it's electronic there will only be a gap on one side. it is switched by the action of the flywheel magnet. To set it up put 2 or 3 sheets of paper between the magnet and the laminations, this will pull the mag onto the flywheel and then do up the 2 small fixing bolts and remove the paper. That will set the air gap. IF electronic you DO NOT need the points - remove them. Do NOT loose the flywheel key ! It is aluminium do not use a steel one ! If the key has even the smallest step in it replace it. Noel. |
larry phelan 1 | 19/07/2023 08:07:42 |
1346 forum posts 15 photos | Ah, the Dreaded Honda !, seems to have put the skids under many an engine. |
