Sealing between skirting and floorboards
JimmieS11/07/2023 20:24:32
310 forum posts
Any advice on a suitable flexible mastic suitable for sealing between the skirting and floor. A few years I used ? which has gone brittle and now is falling apart. Was thinking of Soudal Acryrub but can't get locally (N Ireland) and p&p is telephone numbers. Many thanks.
Jim
Dave Halford12/07/2023 00:01:02
2536 forum posts
24 photos
You may have to use wooden beading. All the acrylic that I have ever used has continued to dry and shrink.
Paul Lousick12/07/2023 06:30:42
2276 forum posts
801 photos
Expanding insulation foam. Available in a spray can at your hardware store.
Mask the skirting board and floor with tape and squirt into the gap with the tube/nozzle supplied with the can. Then trim excess after it has expanded and set with a knife and remove tape.
Edited By Paul Lousick on 12/07/2023 06:35:36
Robert Atkinson 212/07/2023 07:52:27
1891 forum posts
37 photos
Sikaflex EBT+ in white or clear. Can be over painted.
Robert.
John McNamara12/07/2023 08:38:29
1377 forum posts
133 photos
Sikaflex for sure it also sticks very well if the surface is clean, contact the local supplier. Never silicone, it is not nearly as durable, and forget expanding foam for detail work.
For a nice job mask both sides with tape. apply the Sikaflex to the slot then spray on a little soapy water (if needed) then smooth with a wet finger. finally remove the masking tape straight away while the Sikaflex is still wet. Finally! try not to improve and fiddle with it unless really necessary.
That's how the professional Caulkers do it.
Oh! Sikaflex is available in colours.
Edited By John McNamara on 12/07/2023 08:48:12
DC31k12/07/2023 15:43:26
1186 forum posts
11 photos
Posted by John McNamara on 12/07/2023 08:38:29:
...then smooth with a wet finger.
That's how the professional caulkers do it.
Those two statements contradict each other.
No professional uses digital smoothing.
For domestic use, Fugi tools or clones are more suitable.
JimmieS13/07/2023 18:06:45
310 forum posts
Many thanks for all replies which are greatly received. Jim
Bazyle13/07/2023 23:26:34
6956 forum posts
229 photos
Foam carpet underlay.
phillip gardiner13/07/2023 23:56:59
22 forum posts
Selleys butyl mastic skins but remains flexible for years,.
