Eric Cox | 26/06/2023 15:27:10 |
![]() 557 forum posts 38 photos | I've just blown the fuse on the front panel of my conquest super lathe. I can see the fuse is F rated but can't read the current. Does any know what size fuse is required. Edited By Eric Cox on 26/06/2023 15:28:04 |
Oldiron | 26/06/2023 16:11:50 |
1193 forum posts 59 photos | The manual shows 10 amp. Manual ITTH regards |
Eric Cox | 26/06/2023 20:04:22 |
![]() 557 forum posts 38 photos | That's for the mains plug
not done it yet | 27/06/2023 03:43:34 |
7517 forum posts 20 photos | Personally, I think a phone call to Chester should get the required info, but maybe this thread on a similar(?) machine might help. https://www.model-engineer.co.uk/forums/postings.asp?th=67351&p=2 |
Nicholas Farr | 27/06/2023 06:53:17 |
![]() 3988 forum posts 1799 photos | Hi Eric, you should have a ratings plate somewhere, which should tell you the amps that it takes. I have the standard Conquest lathe, and the ratings plate on mine is on the motor cover at the back of the machine. I think these machines are very similar, and mine has a 5 amp fuse fitted. Regards Nick. |
Michael Gilligan | 27/06/2023 08:13:17 |
![]() 23121 forum posts 1360 photos | That all seems very logical 1.6A < 5A < 10A … in all the right places. https://uk.rs-online.com/web/p/cartridge-fuses/5413108 MichaelG. |
Nicholas Farr | 27/06/2023 08:57:38 |
![]() 3988 forum posts 1799 photos | Hi MichaelG, I suppose I should have said it is a F5/250V 6 x 30mm (1/4" x 1-1/4" Regards Nick. |
Ady1 | 27/06/2023 09:17:40 |
![]() 6137 forum posts 893 photos | You can get 500 5A fuses for a few quid on ebay They'll be carrying you out in a box before you get through them I use a cartridge fuse plug on my old blows-more-often AEI motor Means you stress a 10p part instead of £100 of gear Edited By Ady1 on 27/06/2023 09:21:31 |
Michael Gilligan | 27/06/2023 10:22:38 |
![]() 23121 forum posts 1360 photos | Posted by Nicholas Farr on 27/06/2023 08:57:38:
Hi MichaelG, I suppose I should have said it is a F5/250V 6 x 30mm (1/4" x 1-1/4" Regards Nick. . Fine, Nick … I only posted that particular link because it properly described the electrical characteristics. MichaelG. |
Eric Cox | 27/06/2023 10:52:25 |
![]() 557 forum posts 38 photos | I've just called Chester and they said a 13amp fuse would be ok. seems a bit high as the motor on my WM14 mill is protected with a 2amp fuse. not done it yet, the link you posted was to this forum posting. |
Howard Lewis | 27/06/2023 11:23:54 |
7227 forum posts 21 photos | Arc Euro sell fuses dor the C2 and C3 lathes (Which is what your Chester Conquest is; a Sieg ) They shpuld be able to advise you, and supply what you meed. For a motor that is reported to draw 1.6 Amps, a 2 Amp might not withstand the start up surge, but asl Ian or Ketan at Arc. Howard, |
Michael Gilligan | 27/06/2023 12:58:35 |
![]() 23121 forum posts 1360 photos | Posted by Eric Cox on 27/06/2023 10:52:25:
I've just called Chester and they said a 13amp fuse would be ok. .
Michael Gilligan | 27/06/2023 13:03:52 |
. not done it yet, the link you posted was to this forum posting. . I think you need to take another look, Eric The URL posted by NDIY links to page 2 of an earlier thread … we are currently still on page 1 of this thread. MichaelG. |
