Here is a list of all the postings Chris Goodwill has made in our forums. Click on a thread name to jump to the thread.
Thread: material choice |
28/06/2023 17:10:18 |
OK, so this doesn't need to be case hardened or anything special, just basic mild steel. That will making it a lot easier.. Thanks |
28/06/2023 15:09:37 |
Hi I need to replace a vice handle, the current one is bent, too thin, end caps don't fit well, rusty ect. I have been looking on ebay and stainless steel is cheap. It's going to be 16mm dia about 30cm long. Anybody think of a reason why 304 stainless would be a bad choice for a vice handle? |
Thread: Odd Thread Size |
25/06/2023 20:17:46 |
Thank you everyone The vice is an old record 34 steel and I did wonder about the countersinks as the holes looked a bit odd, been 60 Deg makes a lot more sense |
25/06/2023 19:40:22 |
Just to add this bolt is 7.7mm dia and with my pitch gauge is ithere 26 tpi or 1 mm. I think i will thread a piece of bar M8 X 1 and see if it fits. |
25/06/2023 19:06:58 |
Hi I was Given an old record vice last year and have just got around to looking at it. After drilling out the sloted countersunk screws that hold the jaws on, I am having trouble identifying the thread. They could be a metric M8 x 1 fine thread or a 5/16 26tpi. The only other bolt on it is a 5/16 BSW. I have tried looking up 5/16 26tpi but this seems to refer to a bicycle thread. Anyone know what size these screw are suppose to be? |
Thread: Unknown tooling |
07/03/2023 10:50:09 |
Thanks, I needed some more views, I was thinking training equipment, but wanted to check there was not some odd anti-static / Spark use. When you look at these and see how the system works it is a very clever idea. I will now try and write an ebay advert to see if I can find a collector Thanks Chris. |
05/03/2023 09:55:27 |
I am in the process of clearing my Dad’s house and workshop and came across these two cases. I have seen milling Clarkson chucks before, but never in plastic! One is aluminium and the large cutters attached (one Green) are aluminium. They both have 3 trays of cutters all either 6,8,or 10mm all HSS. Has anybody seen these before? |
