R Smith 1 | 21/06/2023 07:44:39 |
12 forum posts | Hello All. I would be grateful for some advice on the best tools & equipment for making fine cuts in sheet metal. I am a long time woodworker, but when it comes to any metals, I'm pretty hopeless and clueless, so apologies for daft questions. I am looking to experiment with making some accordion reeds, which involves cutting reed tongue blanks out of ~0.6 sheet spring steel. Ideally, the cuts shall be reasonably accurate (say, within 0.5-1.0 mm) and they shall not bend & deform the sheet steel. A simple example would be to start with a strip of 8mm-wide spring steel, and then, along the first 40mm of the strip, cut a 1-2mm off from both edges, without making a pig's ear of the remaining ~4-mm wide strip in the middle. It seems that bog standard tin snips are unable to make such cuts without severely bending & deforming the blank. Would something like a manual sheet nibbler work well? Some special shears perhaps?
Thank you. |
DC31k | 21/06/2023 15:37:24 |
1186 forum posts 11 photos | If the maximum you want to remove from each side is 2mm, use a file. Specifically, use a coarse file for the first 1.5mm and a fine file for the remainder. Clamp the spring steel between two larger, stiffer pieces of metal with the line to which you will file a tiny bit (the thickness of a sheet of paper) above the clamping metal. If you are confident, use a disk or belt sander. Glue the steel to a block of wood to make it easier to hold. Be careful not to overheat it. |
An Other | 21/06/2023 15:41:52 |
327 forum posts 1 photos | I wouldn't claim to be an expert, but I have made some very thin spring plate valves for a ramjet - round about 0.5mm thickness. I found the best way to cut them was to use a thin cutting wheel in a Dremel-type tool - when I bought the tool, it came with thin brown cutting wheels about 1" diameter. It was a little difficult, since I was cutting free-hand to a stencilled pattern shaped like a daisy, but I am assuming your accordion reeds are straight, so it may be a little easier. I would suggest that perhaps you could make a small jig to clamp the steel and hold it, then cut up to the jig to get the size correct and constant ? I found almost any type of blade cutter (snips, etc), tended to leave a very slight 'tipped-up' edge on my valve springs - my problem was that the heat of the ramjet motor heated these edges very quickly, and then they burnt away - shouldn't be a problem in an accordion, I guess, unless you are a demon player
Dave Halford | 21/06/2023 17:26:01 |
2536 forum posts 24 photos | If you know someone with a Plasma cutter he can help. |
Clive Steer | 21/06/2023 18:01:31 |
227 forum posts 4 photos | One way to make small thin parts is to coat the thin material with beeswax , scribe the outline of the reed and then acid etch. Laser or plasma cutting may produce hardened edges if the reeds are steel. Water jet cutting works on most materials but cannot be done at home. I believe the rate of etching can be increased electrically. CS |
martin haysom | 21/06/2023 18:08:42 |
![]() 165 forum posts | Posted by R Smith 1 on 21/06/2023 07:44:39:
Hello All. . It seems that bog standard tin snips are unable to make such cuts without severely bending & deforming the blank.
Thank you. if used correctly all the distortion will be on the off cut and the job remains flat |
Ady1 | 21/06/2023 18:12:15 |
![]() 6137 forum posts 893 photos | Plasma and laser messes up the edges and you need good edges A decent guillotine would do it for really good cuts you probably need to make a special jig that holds the reed part between vice type jaws, wood or metal, and the protuding part is cut off with a guillotine or dremel or a decent small grinder with a 1mm disc So a bench vice and a dremel/grinder and some practice would get you a few one offs If you want no bends and very close cuts then sandwich the sheet between two pieces of sacrificial wood in the bench vice and use a good hacksaw blade. Move the arrangement as you cut each slot for maximum support for each cut. Edited By Ady1 on 21/06/2023 18:24:17 |
R Smith 1 | 21/06/2023 18:22:19 |
12 forum posts | Thank you very much.
Must have mentioned - I just want to hog off the material before I start fine-fitting with a file. Filing has so far been the option that I tried, and it seems to take a lot of time, hence me looking for some way to cut. Sanding, dremel, etc - I will probably overheat the metal and harden it. Don't have a CNC laser or plasma cutter. I'm using CS95 steel for the prototype, because that's what I had kicking about the workshop. |
DC31k | 21/06/2023 18:44:18 |
1186 forum posts 11 photos | Posted by R Smith 1 on 21/06/2023 18:22:19:
Sanding, dremel, etc - I will probably overheat the metal and harden it. Do you have a Tormek in your woodworking kit? That would do the trick. Sanding would work with care. Apply to the disk for maybe one second and then dip in some water. |
Speedy Builder5 | 21/06/2023 18:45:04 |
2878 forum posts 248 photos | Easy peasy - follow this link. There may be a couple of advert videos before you get to "How to do it" bit. |
R Smith 1 | 21/06/2023 19:54:29 |
12 forum posts | No tormek - I'm an old school bugger. A piece of glass & abrasive paper to keep the edges razor sharp.
Thank you Speedy - I guess that can be the solution to mass-etch them once I've prototyped the sizes. |
Ady1 | 21/06/2023 19:59:08 |
![]() 6137 forum posts 893 photos | Awesome link I wonder if he's the same pulse jet guy who was asked by the NZ government to stop giving info out on how to make your own V1 type unit |
An Other | 21/06/2023 22:10:08 |
327 forum posts 1 photos | Link Some more data - lots more available online. Love to have watched them plasma-cutting a hundred years ago |
R Smith 1 | 21/06/2023 22:23:05 |
12 forum posts | Ironically, a plasma cutter will set you back less than a clicker press with a set of custom dies... |
Kiwi Bloke | 21/06/2023 23:14:56 |
912 forum posts 3 photos | Ady1 - yes he is (and I don't know him, officer). A national treasure! |
Kiwi Bloke | 21/06/2023 23:24:06 |
912 forum posts 3 photos | R Smith 1 - There are, or used to be, people in Italy who spent their working lives making reeds. It's a specialised craft, and no doubt some of the techniques were kept pretty secret. However, videos are around that show a little of the process. You've probably already discovered that, apart from the profile of the reed having to be accurate enough to fit the aperture in the reed plate with minimal clearance, the reeds can vary in thickness along their length. And then, for bass reeds, have lumps of brass soldered to their tips. Complicated things! I'd imagine that the blanks were guillotined and then fettled by belt sander and file - a finniky and slow job... Good luck. I also have an accordion I'm (occasionally and very slowly) rebuilding. |
Kiwi Bloke | 22/06/2023 03:41:48 |
912 forum posts 3 photos | Another thought. Beware, abrasive cutting may heat the reed enough to change its temper. |
bernard towers | 22/06/2023 11:22:15 |
1221 forum posts 161 photos | can you not sandwich the spring steel between two 4mm strips of steel and mill with carbide cutter. if stacked they will come out very clean |
R Smith 1 | 22/06/2023 11:25:03 |
12 forum posts | Thanks. I should have mentioned that I've been building guitars and mandolins for a decade, so not new to creating things that make noise The secret knowledge bit is overrated - most things are straightforward, but one needs to be able to separate disinformation from various forum "gurus", out-of-date books and traditions from things that actually matter to making a good instrument. A lot of the time, things are done in a traditional way without anyone ever questioning why everyone's doing it that way... Complex - yes. But it doesn't need to be more complex that it is. I'm a lot more concerned about my ability to cut accurate slots in alloy and then fine-fitting the reeds. So this will probably be a fail, but hey, it's better than wasting your time watching tv, right? In most cases you can find all the solutions yourself by experimenting. |
R Smith 1 | 22/06/2023 11:28:14 |
12 forum posts | bernard - thank you for the suggestion. I've been looking for an excuse to buy a milling machine for a few years now, and that's an option. I haven't thought about the sandwich thing though. |
