Milly S | 15/06/2023 20:52:32 |
42 forum posts 9 photos | Hello all I bought some thread gauges at boot sale numbers & letters on ie 13g & some just have numbers are the ones with numbers for thread pitch thanks Steve |
not done it yet | 15/06/2023 21:30:37 |
7517 forum posts 20 photos | Posted by Milly S on 15/06/2023 20:52:32:
Hello all I bought some thread gauges at boot sale numbers & letters on ie 13g & some just have numbers are the ones with numbers for thread pitch thanks Steve Measure and work out the pitch to see if that is what they indicate? From the net: “What are the different types of thread gauges? Thread gages can be one of any number of types of gages. These in clued plug, ring, 3-wire, micrometer, tri-roll comparator, measuring wire, screw thread insert (STI), and thread gaging roll thread gages. What type are yours?” |
Michael Gilligan | 15/06/2023 22:01:11 |
![]() 23121 forum posts 1360 photos | The German word for ‘thread pitch’ is: Gewindesteigung MichaelG. |
Georgineer | 15/06/2023 22:03:20 |
652 forum posts 33 photos | A bit more detail would help people to help you, but 13g could possibly be "13 gauge" which would be the thread on the end of a particular diameter of wheel spoke. My 1938 tandem used 13g spokes. George |
Frances IoM | 15/06/2023 22:24:54 |
1395 forum posts 30 photos | assuming you have the common arrangement of two sets of blades sandwiched between two plates - then these plates usually have whit or metric or both stamped on them - on those under the whit heading they are marked in tpi turns per inch and under the metric the thread in mm - should be fairly obvious 'g' is used on german or european origin for tpi - there are funnies available eg BA threads but 99.9% are combi Whit + metric |
Hopper | 15/06/2023 22:31:27 |
![]() 7881 forum posts 397 photos | 13G usually means 13 threads per inch. It is the metric way of describing TPI without referring to the verboten inch. As MG says, it stands for the German word for thread pitch. Older imperial thread gauges just have the number, indicating TPI. |
Steviegtr | 15/06/2023 22:40:21 |
![]() 2668 forum posts 352 photos | I am glad someone asked this question as I have some the same & had no idea what it meant. Steve. |
Nicholas Farr | 15/06/2023 22:42:26 |
![]() 3988 forum posts 1799 photos | H Milly S, this 13G? thread may also have answers for you. Regards Nick. |
Milly S | 16/06/2023 07:53:21 |
42 forum posts 9 photos | Good morning all i would just like to say thanks for all your advice i now know what the G is for & I hope it’s helped others cheers steve |
