Puddleglum | 29/05/2023 16:52:00 |
23 forum posts | Hi, |
Pete Rimmer | 29/05/2023 17:11:07 |
1486 forum posts 105 photos | 4mm thick is miles too heavy. My high-level shelving is made from 40x40x1.6mm thick and it spans 2m+. It's loaded up to the nines with no sign of distress. I've even made a rack to hold the working heads from my mill which are up to 50kg each. The rack is just short lengths of this same box section welded to the wall frame one end and they too seem to hold up with no issues. |
Puddleglum | 29/05/2023 17:24:57 |
23 forum posts | Posted by Pete Rimmer on 29/05/2023 17:11:07:
Nicholas Farr | 29/05/2023 17:36:39 |
![]() 3988 forum posts 1799 photos | Hi Puddleglum, 3 metres is quite a wide span for anything without a bit of depth to it, and a beefy bit of box section will be heavy, rust inside would be the least of you problem, but you can put those plastic bungs in the ends which would slow down the process. Lightweight rectangular section, say 80mm deep would be better, but better still would be to have a central support from the roof, if it's strong enough. Bearing in mind that the larger section you have, the more expensive it will be. 40mm x 20mm x 4mm would be OK if you made a Lattice type beam of a suitable deepth. Regards Nick. |
Maurice Taylor | 29/05/2023 17:49:21 |
275 forum posts 39 photos | Hi , I think it would be easier for members to give answers if you put photos of location of shelf on. Maurice |
DiogenesII | 29/05/2023 17:50:49 |
859 forum posts 268 photos | 3m wide, but what's the front-to-back depth of the space? |
Puddleglum | 29/05/2023 17:59:06 |
23 forum posts | Posted by Maurice Taylor on 29/05/2023 17:49:21:
Hi , I think it would be easier for members to give answers if you put photos of location of shelf on. Maurice Not really anything to show - 2 walls, 3m apart. To run a shelf across, will need support "beams" that span the 3m. As they'll only be supported at the ends, worried about deflection \ bending failure. Edited By Puddleglum on 29/05/2023 18:00:26 |
Puddleglum | 29/05/2023 18:00:04 |
23 forum posts | Posted by DiogenesII on 29/05/2023 17:50:49:
3m wide, but what's the front-to-back depth of the space? That's kind of irrelevant... but about 600mm. Edited By Puddleglum on 29/05/2023 18:00:45 |
Puddleglum | 29/05/2023 18:03:03 |
4mm thick is miles too heavy. My high-level shelving is made from 40x40x1.6mm thick and it spans 2m+. It's loaded up to the nines with no sign of distress Does this have supports in the middle, or just the ends? |
Puddleglum | 29/05/2023 18:14:54 |
23 forum posts | Posted by Nicholas Farr on 29/05/2023 17:36:39:
3 metres is quite a wide span for anything without a bit of depth to it Yep - it's a fair span. What got me thinking it might be possible was the pallet racking in warehouses. Like this. Doesn't say what the cross section dimensions are though Edited By Puddleglum on 29/05/2023 18:18:55 |
Pete Rimmer | 29/05/2023 18:16:06 |
1486 forum posts 105 photos | Posted by Puddleglum on 29/05/2023 18:03:03:
4mm thick is miles too heavy. My high-level shelving is made from 40x40x1.6mm thick and it spans 2m+. It's loaded up to the nines with no sign of distress Does this have supports in the middle, or just the ends? Supported either end, cross-bars between the front and rear spans every couple of feet just to support the chipboard shelf. If you want to know about deflection for 200kg load just get a piece of the steel, span it across and get two chunky people to hang on it in the middle. |
Puddleglum | 29/05/2023 18:23:57 |
23 forum posts | Posted by Pete Rimmer on 29/05/2023 18:16:06:
Peter Cook 6 | 29/05/2023 18:50:56 |
462 forum posts 113 photos | There are several free beam calculators on the internet that will let you do deflection calculations. You can test out various materials and cross sections without risking your box section - or the bodies you hang from it! |
Maurice Taylor | 29/05/2023 19:08:29 |
275 forum posts 39 photos | Hi,Have you considered using 4 x 2 timber ,I’d use 3 pieces of 4 x2 to span the garage and put a piece of 18mm plywood on the top of it . Cheaper and easier than steel. Maurice
Puddleglum | 29/05/2023 19:13:19 |
23 forum posts | Posted by Peter Cook 6 on 29/05/2023 18:50:56:
Puddleglum | 29/05/2023 19:15:50 |
23 forum posts | Posted by Maurice Taylor on 29/05/2023 19:08:29:
DC31k | 29/05/2023 19:22:31 |
1186 forum posts 11 photos | What is above the proposed shelving? If there is a way to support it midspan, that will help a lot. Could be as simple as a piece of rope tied to the ridge timber. --- The 4" x 2" timber and plywood has a structural depth of over 100mm. That might be a consideration if headroom is limited. --- The 200kg person hanging on the middle will give a conservative over estimate of the deflection as the 200kg load is distributed evenly over the 3m x 0.6m area, and shared between more than one support. |
John Doe 2 | 29/05/2023 19:45:46 |
![]() 441 forum posts 29 photos | I am having difficulty visualising this. For medium loads, I put supports every 700-800mm. and use 18mm thick plywood sheeting cut in strips. |
JA | 29/05/2023 20:22:10 |
![]() 1605 forum posts 83 photos | My only comment is that the shelving will be rather high up. OK when you are young and middle aged. I now find all my high shelving, above 65", slightly difficult to reach. I put a shelf above one garage door and have not been there for years. JA |
martin haysom | 29/05/2023 20:39:22 |
![]() 165 forum posts | could put more than one beam from side to side to increase load capacity |
