it is not D10
Jeff Swinburn | 16/05/2023 16:08:57 |
![]() 5 forum posts 5 photos | Hi have just got a steam model D 10 , all casings are bronze the disk wheel is steel the bed plate is ally and brass fabricated . Edited By JasonB on 17/05/2023 10:19:09 |
JasonB | 16/05/2023 17:10:23 |
![]() 25215 forum posts 3105 photos 1 articles | I don't think there are any castings in that model, looks like it was scratch built and based around the Stuart D10 design |
Jeff Swinburn | 17/05/2023 09:41:31 |
![]() 5 forum posts 5 photos | Hi thanks for your reply , I did see a set of castings in the Stuart tuner catalog 1924 was called s v .slide valve vertical. all the castings where gun metal and the flywheel was steel. |
Circlip | 17/05/2023 09:48:21 |
1723 forum posts | Have a look at old 'Reeves' designs, Cylinder base castings look a bit like 'Warrior' Regards Ian. |
noel shelley | 17/05/2023 10:06:38 |
2308 forum posts 33 photos | Not a D10 ! bore and stroke about right and the top cylinder covers look ok but the rest ? Looks a nice model. Noel |
JasonB | 17/05/2023 10:18:34 |
![]() 25215 forum posts 3105 photos 1 articles | It's not done with the Progress SV castings as they are only 1/2" bore, You can also see a joint line where the valve block is fitted to the curved cylinder and the shape of the A frames is arrived at by turning. Only thing SV and warrior about it is the use of square flanges at the top of the A frame to cylinder joint. Not sure what base castings Ian can see by looks all bar stock to me, two rectangular rails onto a bit of plate Edited By JasonB on 17/05/2023 10:22:19 |
Jeff Swinburn | 17/05/2023 10:20:24 |
![]() 5 forum posts 5 photos | Hi thanks I have had a look at reeves Worrior it looks like its the same will take some measurements thanks Ian Will let you know later when get in work shop thanks Jeff. |
Circlip | 17/05/2023 11:10:57 |
1723 forum posts | CYLINDER base Jason? Regards Ian. |
JasonB | 17/05/2023 13:11:27 |
![]() 25215 forum posts 3105 photos 1 articles | |
Jeff Swinburn | 17/05/2023 13:32:38 |
![]() 5 forum posts 5 photos | Hi I have had a little look at the reeves Worrior . a lot of the measurements are the same but the bed plate is fabricated , I have made a new crank has the old one was beyond respire. the warrior had a 5/8 " stroke and 3/4 bore the new crank I made is 3/4 stroke and 3/4 bore . but it runs ok on very little air , I will up load video when I have done some more bits to it . thanks Jeff |
Roderick Jenkins | 17/05/2023 19:36:31 |
![]() 2376 forum posts 800 photos | Those standards are pretty distinctive
Jeff Swinburn | 19/05/2023 09:24:01 |
![]() 5 forum posts 5 photos | Hi I think the model is made from reeves castings with a scratch built bed plate , thank you all for your help on identifying the model , I can now get on with making it look better thanks again Jeff
