Member postings for Jeff Swinburn
Here is a list of all the postings Jeff Swinburn has made in our forums. Click on a thread name to jump to the thread.
Thread: can any one help me identify this model
19/05/2023 09:24:01
Hi I think the model is made from reeves castings with a scratch built bed plate ,
thank you all for your help on identifying the model , I can now get on with making it look better
thanks again Jeff
17/05/2023 13:32:38
Hi I have had a little look at the reeves Worrior . a lot of the measurements are the same but the bed plate is
fabricated , I have made a new crank has the old one was beyond respire. the warrior had a 5/8 " stroke and 3/4
bore the new crank I made is 3/4 stroke and 3/4 bore . but it runs ok on very little air ,
I will up load video when I have done some more bits to it .
thanks Jeff
17/05/2023 10:20:24
Hi thanks I have had a look at reeves Worrior it looks like its the same will take some measurements
thanks Ian
Will let you know later when get in work shop
thanks Jeff.
17/05/2023 09:41:31
Hi thanks for your reply , I did see a set of castings in the Stuart tuner catalog 1924 was called
s v .slide valve vertical. all the castings where gun metal and the flywheel was steel.
16/05/2023 16:08:57
Hi have just got a steam model D 10 , all casings are bronze the disk wheel is steel the bed plate is ally and brass fabricated .
the bore is 3/14in the stroke is 3/14in
I can not find any information on the inter net , the only picture's I nan fined are the one I got of eBay ,and the same one on
a sale room site . Stuart turner site said it is not one of there models img_20230516_142955248.jpg1000001714.jpgimg_20230516_143015272.jpg
Edited By JasonB on 17/05/2023 10:19:09
