"O" ring
Dalboy04/05/2023 20:46:54
1009 forum posts
305 photos
I am making a hit and miss engine from plans and need to order some bits and pieces and while I am doing so I may as well get some of the other bits for it and make the order up.
Anyway to the question for the piston ring it says use a Buno-N "O" ring is this a nitrile one or is there a more suitable one to get.
The second option they say use is a quad seal "x" type ring.
It does state that the engine gets barely warm when running
Edited By Dalboy on 04/05/2023 20:47:36
JasonB04/05/2023 20:54:43
Viton O rings tend to be less affected by oil and that is what I use on my IC engines both liquid feuled and propane.
Fulmen04/05/2023 21:18:51
120 forum posts
11 photos
Buno-N is the same as nitrile/NBR.
Dalboy05/05/2023 10:49:13
1009 forum posts
305 photos
Thank you both for the information I can now order what I need
Bo'sun05/05/2023 11:02:40
754 forum posts
I think it's "Buna N".
Martin Johnson 105/05/2023 13:00:45
320 forum posts
I would go with Viton as it has a higher temperature tating and better oil resistance than nitrile (or Buna N). In addition to perceived engine temperature you have higher temperature at the piston head plus local friction at the O ring to allow for.
Martin
Dalboy05/05/2023 17:09:50
1009 forum posts
305 photos
Posted by JasonB on 04/05/2023 20:54:43:
Can I ask where you get yours from as the place I was ordering other things do not do Viton O rings only Nitrile
Edited By Dalboy on 05/05/2023 17:10:38
noel shelley05/05/2023 17:26:54
2308 forum posts
33 photos
Try HAYLEY BEARINGS, or PM me with the sizes you need ! Noel
JasonB05/05/2023 18:26:26
I usually buy metric but I expect the Farmboy wants imperial so Simplybearings should have what you need if you know the BS number just enter that on their site
Dalboy05/05/2023 21:15:25
1009 forum posts
305 photos
Thank you both have sent a PM noel
