CAD for beginners
advice needed
David Heath16/04/2023 23:35:58
2 forum posts
Could anyone recommend an affordable CAD software for beginners
Thor 🇳🇴17/04/2023 07:23:05
1766 forum posts
46 photos
Hi David,
If you want to try 3D CAD you might try FreeCAD, Fusion360 has a free version and you might check out Solid Edge CE. It has been discussed on the forum before, a couple of links:
***Link***
***Link***
Thor
Edited By Thor 🇳🇴 on 17/04/2023 07:27:30
Baz17/04/2023 07:46:27
1033 forum posts
This subject has been done to death in the last few months, you might be best using the search bar above.
Gary Wooding17/04/2023 07:53:02
1074 forum posts
290 photos
Hi David. Because you have also started a thread about 3D printing I assume you want to create 3D model;s for printing.
There are quite a few CAD systems from which to choose, but no matter what you finally decide on, be prepared for a very steep learning curve. I've tried the three big players: Solidworks, SolidEdge, and Fusion 360, and reckon the easiest one to learn is F360. Solidworks is very expensive and there is no free version, so you will probably skip it. The free version of SolidEdge is very powerful but can be rather difficult to learn. F360 is just as powerful but holds all your models in the cloud. Some people object to this, but it works fine for me. It's very easy to save your models to your own disks, but I don't really see the point. Being in the cloud means that you can access your models from any computer that has installed F360, anywhere in the world.
I haven't tried any other free system, but, because of the steep learning curves, it's not really practical to to switch.
Did I mention the steep learning curves? Whatever you choose, be prepared to spend months learning it. You can learn the basics in a few days, but that's just the beginning. Don't despair and give up.
Nealeb17/04/2023 08:00:26
231 forum posts
Do you have any CAD or draughting experience? Do you have access to anyone locally or otherwise who can give you help? Particularly if you are starting with 3D CAD, where some of the concepts and ways of approaching it are not necessarily intuitive, getting some of those initial ways of thinking under your belt would save a whole lot of grief and pain! For evidence, just look at some of the recent threads on the subject...
As it seems that you want to get started with 3D printing, you are going to need 3D CAD. Personally, I reckon that Fusion 360 has a lot going for it. Very good for 3D printing. I also use Solid Edge but decidedly over the top for 3D printing. There will be plenty of other suggestions; I've only mentioned things I use personally.
IanT17/04/2023 09:07:10
2147 forum posts
222 photos
Hi David,
When I first purchased a 3D printer, a friend recommended that I use Open SCAD to make the fairly simple 'designs' I needed. It worked very well for me and has a very easy learning curve. You can do complex work with it and I believe it is capable of some things (mathmatically) that would not be possible with traditional CAD. If you have a logical mind then it may suit you. Previous progaramming experience is NOT required. One of the best aspects of SCAD to my mind is that the simple text files can easily be exchanged via cut 'n paste from Forums (including this one) that don't have file system as such. SCADs can also be designed to be customisable (e.g one basic design, many versions). As an example, here is a T-Slot "filler" I designed using Open SCAD
Same 'Code' - different variables. Here's the code, you can just copy it and paste into SCAD
// T-Slot Filler - IanT
L = 75; // T-Slot Length
HR = 1.5; // Hole Radius
BW = 14; // Bottom (of Slot) Width
TW = 8; // Top (of Slot) Width
BH = 4; // Bottom (of Slot) Height
TH = 9; // Top (of Slot) Height
difference () {
union () {
cube ([L,BW,BH], center=false);
translate ([0,(BW/2-TW/2),0])
cube ([L,TW,TH]); }
translate ([L/2,BW/2,0])
cylinder (TH,HR,HR);
You can download SCAD here...
Open SCAD
I now use Solid Edge which required a great deal more effort to learn than SCAD but I needed dimensioned drawings of some of my work and SCAD doesn't provide them. But for a simple way to get into 3D Print it's brilliant. There are also a lot of useful SCAD desings that you can download (and modify) on Thingiverse.
IanT
IanT17/04/2023 09:23:09
2147 forum posts
222 photos
Here's another one to try. I purchased a 220V DC motor that didn't have a foot (just two threaded holes) so needed a mounting. This design could be changed to mount any round object on a flat plane though...
// Sadddle for DC (220V) Motor
// IanT
BL = 107 ; // Base Length
BW = 60 ; // Base Width
BD = 20 ; // Base Depth
ML = 107 ; // Motor Length
MR = 39 ; // Motor Radius
HD = 25 ; // Hole Depth
HR = 3.1 ; // Hole Radius (Clearance)
D1 = 20 ; // First Hole Distance
D2 = 70 ; // Second hole Distance
difference () {
translate ([0, -(BW/2), 0])
cube ([BL, BW, BD]) ;
translate ([0, 0, (MR + 6)])
rotate ([0, 90, 0])
cylinder ( ML, MR, MR) ;
translate ([D1, 0 ,0 ])
cylinder ( HD, HR, HR) ;
translate ([D2, 0, 0])
Give it a try, SCAD is good fun and most importantly you can get simple things done on your first evening with it - it's pretty simple to get started with....
IanT
JasonB17/04/2023 09:42:32
As you asked about affordable CAD I's say Alibre's Atom3D, can be had for a one off payment or you can pay for regular updates.
Couple of things recently drawn that I shared with people who wanted to print
SillyOldDuffer17/04/2023 09:59:20
10668 forum posts
2415 photos
Always best to start with what CAD will be used for by the owner!
For 3D printing and single parts I mostly use FreeCAD, which really is completely free. Downside, it covers a lot of different CAD methods, they're all a bit experimental (crashes occasionally), and not necessarily compatible with each other! However, for 3D printing and Mechanical Engineering the FreeCAD "Parts Design" Workbench works well and does all the basics. I wrote a 'Get Started' thread in 2019 which can be followed to get a feel for how Part Design works without getting entangled with the rest. Good for 'Solid Model' objects like this, which can be metalworked or 3D printed:
FreeCAD also has a Technical Drawing workbench which creates dimensioned first angle or third angle projections from 3D parts: these are important when the part is made manually rather than CNC or 3D-printed/
Blowlamp has recently drawn our attention to MOI (paid for, not too expensive), which seems fairly easy to drive. (But beware, CAD tools aren't simple.). Judging by Blowlamp's videos MOI can do much the same as FreeCAD Part Bench, but not I think, produce dimensioned technical drawings on paper. MOI has good 'Surface Model' support which is important for producing curvy objects like like this:
Fusion 360 works in a similar way to FreeCAD but is slicker, mostly consistent, and more complete. The completeness includes Assembly, that is models consisting of multiple jointed parts:
I found it easiest to learn, perhaps because it works in a similar way to FreeCAD, which I already knew. However, Fusion is a cloud product, which has privacy and control implications, for example AutoDesk applied a 10 open file restriction to the hobby version. Not a show-stopper but quite annoying.
For that reason I switched to Solid Edge. Like Fusion, SE is also 'full function', able to do Surface Modelling, Sheet-metal, and Assembly, but it's an older product and the interface isn't quite so slick. The product also works in two modes, which is confusing. Ordered Mode is like Fusion and FreeCAD, that is the model is the end result of a step by step history. So if a hole needs to be moved, the operator finds where it was created in the history, alters it, and the change ripples forward through the model. All good unless the new hole breaks something else on the way! Synchronous avoids that by allowing the hole to be moved in the current model: it's very natural. However, it destroys the history, which can cause trouble too. Mostly though, Synchronous is preferred to Ordered, unless it doesn't work! SE works very well, and Synchronous is hot stuff, but I found it harder to learn than Fusion.
This is a 3D-printed engine in SE, an assembly of many individual parts with joint constraints. The model animates without parts colliding, but the real one doesn't because friction is high and the plastic bends. Apply enough compressed air to overcome piston stiction and it twists off the conrod and hits the ceiling. I think a metal version might work.
I'd recommend sticking with Fusion, SE, FreeCAD, or Alibre (covered in a MEW series) because several forum members use them and can answer questions.   We have a member struggling with TurboCAD at the moment, and part of his problem is only one other member knows TC well enough to give good answers.
Edited By SillyOldDuffer on 17/04/2023 10:00:52
Edited By SillyOldDuffer on 17/04/2023 10:05:37
lee webster17/04/2023 10:04:10
383 forum posts
71 photos
I am not too sure if this is still true, but there used to be a "student" version of Solidworks. When I started out in the world of cad about three years ago I sent Solidedge a cheeky email asking if they had a hobby version I wouldn't have to pay for. They emailed back saying yes! I had a link to where I could download the software from and they also emailed me the code to activate it. My computer failed on the download, so I emailed them to say I would have to give it a miss because of the download speeds in my area. Their reply was "no problem, give us your home address and we'll send you the installation discs". Less than a week later the DVDs turned up all the way from America. I installed and used the software for several months before I began to wonder what would happen if they pulled the plug at some point. That's when I turned to FreeCAD, and then to Design Spark Mechanical. Both free. I do miss Solidworks though. I still have the DVDs in case I can re-install one day.
Ady117/04/2023 10:21:40
6137 forum posts
893 photos
Our main Alibre thread is here
Various other threads too
Bazyle17/04/2023 10:48:14
6956 forum posts
229 photos
I recommend you at least start by looking at SillyoldDuffer's (SOD) tutorial he linked above as it is free and a gentle introduction.
One thing that frightens people about FreeCad is that there are lots of 'workbenches' that seem like there are lots of different programmes. However actually there is just the one programme and the workbenches are only different sets of toolbars being displayed for convenience because an architect wants different tools to an engineer. You can actually customise the display to add or subtract those toolbars if you wish but it is easier to just click to flip to a different workbench for a few minutes and back again. It doesn't hurt your drawing.
John Doe 217/04/2023 11:03:09
441 forum posts
29 photos
I use Shapr3D because I wanted something to run on an Apple iMac or iPad - most of the other CADs are Windows only.
Shapr3D is good for quickly drawing a shape to be 3D printed. I am still a CAD beginner so I don't know how it gets on with models with interacting parts, e.g. axles or hinges.
Plumbing tool holder:
Edited By John Doe 2 on 17/04/2023 11:09:18
blowlamp17/04/2023 11:40:39
1885 forum posts
111 photos
Dave.
MoI does have dimensions. You can't print directly from MoI, but you can save to a PDF and print from there, as I've shown in the video.
Martin.
blowlamp17/04/2023 12:03:19
1885 forum posts
111 photos
The more unusual, but versatile, Rail Revolve tool in MoI.
Martin.
SillyOldDuffer17/04/2023 13:24:22
10668 forum posts
2415 photos
Posted by blowlamp on 17/04/2023 11:40:39:
Dave.
MoI does have dimensions....
Martin.
It does, but not on technical drawings generated from the solid. (I believe?) Say I create a 3D object like the base of a 4-way tool-post:
And I want a formal First Angle or Third Angle drawing so a machinist can make it:
The 2D-CAD drawing is automatically generated from the 3D model, using a template with a title block and other control goodies.
It's drawn to scale and because the Techdraw workbench 'knows' what all the 3D dimensions are, the user can add them to best effect by clicking on lines or points etc. The workbench can also do sections, details, balloon annotations and cosmetic stuff.
MOI isn't a good choice if producing formal 2D projections is important. But it's true that for many purposes labelling the 3D object as demonstrated in your video is 'good enough'. Fusion, SE and Alibre can also generate formal 2D technical drawings.
blowlamp17/04/2023 14:36:55
1885 forum posts
111 photos
Dave.
I don't think MoI is aimed at being a complete drawing office. It's designed to be as easy and as fluid as possible to use, without a huge learning curve. It doesn't have assemblies, constraints, or auto dimension, but it is pretty straightforward to use and will make drawings every bit as precise as any other CAD we are likely to use. MoI also has a few tools that allow it to do things that other CAD apps struggle with. Its primary focus is to create the drawing model, as it is always possible to export to another app for added tweaks.
Martin.
Peter Cook 617/04/2023 15:10:46
462 forum posts
113 photos
Another +1 for MoI. I don't have a technical drawing background and found my brain simply did not get on with the "standard" CAD software paradigms.
MoI I found very easy and intuitive, and is excellent for creating models for 3D printing. I do use blowlamp's approach (PDF's) to produce hard copy to take to the workshop, but I only draw on the dimensions I want rather than producing formal third angle drawings - which I struggle to read anyway.
Gary Wooding17/04/2023 15:58:40
1074 forum posts
290 photos
Just one plus point for F360. It has a facility called T-Splines, which is, as far as I know, unique to F360. It allows you to create non-planar 3D surfaces which are easily converted into solid models. A T-Spline is rather like a linear spline, but applied to a surface rather than a line. This can be very useful for creating creating complex shapes such as these..
