petro1head | 14/04/2023 08:27:50 |
![]() 984 forum posts 207 photos | Have not seen the done to many Warco milling machines and have wanted to do this for a while. After I decided to replace the Nema 23 on the Z axis with a Nema 34 stepper motor I then had a spare Nema 23 and Controller for the Y axis project. So, you need a Name 23 Stepper Motor, I am using the 3Nm one and the controller bought from Stepperonline --HERE-- I already have a power supply, 48v so going to use that. You will also need a PWM like this --HERE--, a change over relay, a double pole double throw on/off/on switch to control forward and reverse of the motor, a on/off power switch, a LED light (Optional) and some sort of limit switch. I decided to go with 1 to 1 ratio pulleys and belt which I bought from CNC4U. So everything would fit I bought the 10mm pulleys. Here is where I am up to today, I am awaiting the PWM and a replacement belt and the one I got was too short (Schoolboy error) |
SillyOldDuffer | 14/04/2023 09:56:18 |
10668 forum posts 2415 photos | Very good, and I'm tempted to copy it. I'm doing a fair amount of milling on my plain WM18 at the moment and working for more than a couple of hours on it has rubbed my nose in its shortcomings. The machine a little low for my height, which gives me backache, and cranking the handles slows progress down and is physically tiring, leading to silly mistakes. If the session is less than about an hour, which is usual for me, I don't feel the need for power assist, or get backache. Any longer than that, and motorising the mill would pay off. And it needs to be raised an inch or two. Dave |
Michael Gilligan | 14/04/2023 10:51:11 |
![]() 23121 forum posts 1360 photos | Nice project ! I’m happy to accept that it’s a trick of the light, if you say so … but those timing pulleys look rather rough. MichaelG. . Ref. __ https://www.cnc4you.co.uk/Pulleys-Pre-drilled-with-Grubscrew Edited By Michael Gilligan on 14/04/2023 10:56:18 |
petro1head | 14/04/2023 11:04:22 |
![]() 984 forum posts 207 photos | Posted by SillyOldDuffer on 14/04/2023 09:56:18:
Very good, and I'm tempted to copy it. I'm doing a fair amount of milling on my plain WM18 at the moment and working for more than a couple of hours on it has rubbed my nose in its shortcomings. The machine a little low for my height, which gives me backache, and cranking the handles slows progress down and is physically tiring, leading to silly mistakes. If the session is less than about an hour, which is usual for me, I don't feel the need for power assist, or get backache. Any longer than that, and motorising the mill would pay off. And it needs to be raised an inch or two. Dave I have raised mine for the same reason, stout wooden blocks under neath raises it about 5" |
petro1head | 14/04/2023 11:04:49 |
![]() 984 forum posts 207 photos | Posted by Michael Gilligan on 14/04/2023 10:51:11:
Nice project ! I’m happy to accept that it’s a trick of the light, if you say so … but those timing pulleys look rather rough. MichaelG. . Ref. __ **LINK** Edited By Michael Gilligan on 14/04/2023 10:56:18 Crap phone photo. They are nice |
Michael Gilligan | 14/04/2023 11:12:44 |
![]() 23121 forum posts 1360 photos | Thanks … I am relieved MichaelG. |
petro1head | 14/04/2023 11:17:48 |
![]() 984 forum posts 207 photos | Got the belt this morning and its the correct size this time, YAY |
John Haine | 14/04/2023 11:41:10 |
5563 forum posts 322 photos | As a matter of interest what is the reversing switch doing? It should NOT be in the wires to the motor because if the motor is energised (even if stopped) and you throw the switch the inductive kick from the coils may blow the driver. Reversing should be done by changing the logic state on the DIR input of the driver which only needs a simple one-pole changeover switch, or an on/off plus a pullup resistor. |
Rockingdodge | 14/04/2023 14:57:34 |
![]() 396 forum posts 111 photos | Y axis? surely you mean the X axis which is the right and left travel? |
petro1head | 14/04/2023 14:58:20 |
![]() 984 forum posts 207 photos | Posted by John Haine on 14/04/2023 11:41:10:
As a matter of interest what is the reversing switch doing? It should NOT be in the wires to the motor because if the motor is energised (even if stopped) and you throw the switch the inductive kick from the coils may blow the driver. Reversing should be done by changing the logic state on the DIR input of the driver which only needs a simple one-pole changeover switch, or an on/off plus a pullup resistor. Its done via the PWM As this is my second stepper power feed, i know what i am doing this is the wiring The push switches on the frequency generator board were removed and wires soldered to the points shown. Edited By petro1head on 14/04/2023 15:21:00 Edited By petro1head on 14/04/2023 21:38:25 |
petro1head | 14/04/2023 15:24:27 |
![]() 984 forum posts 207 photos | Posted by Rockingdodge on 14/04/2023 14:57:34:
Y axis? surely you mean the X axis which is the right and left travel? Nope Y I have the supplied Warco power feed on the X axis Edited By petro1head on 14/04/2023 15:25:27 |
petro1head | 14/04/2023 17:01:23 |
![]() 984 forum posts 207 photos | Wohoo, just finished the wiring and done a quick test, it works |
John Haine | 14/04/2023 17:17:17 |
5563 forum posts 322 photos | Posted by petro1head on 14/04/2023 14:58:20:
Good. |
petro1head | 14/04/2023 21:41:41 |
![]() 984 forum posts 207 photos | Fished control unit wiring All i need to do is tidy up the external cables etc |
petro1head | 12/05/2023 11:13:08 |
![]() 984 forum posts 207 photos | Just an update. So far its been excellent. The only mods since the build is I replaced the toggle switch with a rocker one as i sometimes caught the toggle with my coat and the cover. Edited By petro1head on 12/05/2023 11:18:45 |
Speedy Builder5 | 12/05/2023 12:29:52 |
2878 forum posts 248 photos | I assume you have a DRO on the Y axis and that is why the dial is obscured? Can you disengage the stepper motor and if so, how did you do that please? Bob |
john fletcher 1 | 12/05/2023 13:18:11 |
893 forum posts | That looks good, neat and tidy, perhaps it could be a future article in MEW in a manner to which Carl ?? did for the rotary table. John |
petro1head | 12/05/2023 14:51:55 |
![]() 984 forum posts 207 photos | Posted by Speedy Builder5 on 12/05/2023 12:29:52:
I assume you have a DRO on the Y axis and that is why the dial is obscured? Can you disengage the stepper motor and if so, how did you do that please? Bob Yes DRO fitted x, y and z. No, i dont dissengauge the handwheel
Edited By petro1head on 12/05/2023 14:52:29 |
petro1head | 12/05/2023 14:58:41 |
![]() 984 forum posts 207 photos | Posted by john fletcher 1 on 12/05/2023 13:18:11:
That looks good, neat and tidy, perhaps it could be a future article in MEW in a manner to which Carl ?? did for the rotary table. John Well i am happy to provide infor but hopeless at writing |
John MC | 12/05/2023 15:29:31 |
![]() 464 forum posts 72 photos | Posted by Michael Gilligan on 14/04/2023 10:51:11:
Nice project ! I’m happy to accept that it’s a trick of the light, if you say so … but those timing pulleys look rather rough. MichaelG. . Ref. __ **LINK** Edited By Michael Gilligan on 14/04/2023 10:56:1 Finish has that faceted look associated with hobbed teeth, gears and sprockets like these.
