Dell | 14/01/2023 15:08:11 |
![]() 230 forum posts 44 photos | Well I have made a couple of lathe chuck keys for my Pultra four jaw chuck out of HT socket head cap bolts and happy with the finished product, my problem was or is that I started off using the crosslide but the finish was rubbish ( more like a super fine thread than a smooth finish) I tried using indexable carbide and HSS steel but no better, tried altering speed up and down, I ended up using the hand graver as I got a much better finish , I know I only have a small Pultra instrument lathe but I should be able to get a decent finish I must admit I very rarely use the crosslide because most of what I make for antique clocks is small and I much prefer using the graver, what am I doing wrong? |
Dave Halford | 14/01/2023 15:32:50 |
2536 forum posts 24 photos | You need the tool tip width to be greater than the 'thread' that you can currently producing. Slow down your cross slide winding hand or use a broader tool tip. Bolt steel is extra stringy stuff and gives a torn finish unless tools are very sharp. |
JasonB | 14/01/2023 15:51:20 |
![]() 25215 forum posts 3105 photos 1 articles | You don't say what inserts you use. I'd suggest some **GT ones worked well for someone a month or so back I suggested it to wanting a good finish on Titanium using a Sherline lathe |
Georgineer | 14/01/2023 15:51:44 |
652 forum posts 33 photos | Dell, May I politely request that you use a meaningful thread title? That way, you are more likely to get the help you are asking for. George |
Speedy Builder5 | 14/01/2023 15:54:19 |
2878 forum posts 248 photos | check tool centre height Check saddle / top slide gibs are nipped up so that tool height doesn't change when cutting load comes on. Check cutting speed for tool / work material. Use correct lubricant if using HSS tooling.
Dell | 14/01/2023 21:56:38 |
![]() 230 forum posts 44 photos | Thanks for the replies I have both indexable HSS and carbide I can’t remember what the designation is but they are both this pattern https://littlemachineshop.com/products/product_view.php?ProductID=3574&category= with glanze holders, I have checked and adjusted the gibs, used a lubricant , haven’t rechecked if bit on centre as it was previously but will check also will try slowing feed down although I thought I was doing it slowly. George point taken. Dell |
Michael Gilligan | 14/01/2023 22:07:00 |
![]() 23121 forum posts 1360 photos | I don’t know whether such things are available as inserts [but I suspect Jason could advise] … If you could grind, or find, a ‘shear’ tool … that would better-approximate the cutting action of the graver. MichaelG. . Edit: __ You may like the toolholder design that I linked in this previous thread: https://www.model-engineer.co.uk/forums/postings.asp?th=132573&p=1 Edited By Michael Gilligan on 14/01/2023 22:12:30 |
david bennett 8 | 15/01/2023 01:37:10 |
245 forum posts 19 photos | If you are sharpening your hss tools to look like gravers ( ie with a sharp point ) that could be your problem. You need a radius on the cutting tip dave8 |
Michael Gilligan | 15/01/2023 06:40:27 |
![]() 23121 forum posts 1360 photos | Posted by david bennett 8 on 15/01/2023 01:37:10:
If you are sharpening your hss tools to look like gravers ( ie with a sharp point ) that could be your problem.[…] . For clarity … this is the shape of insert that Dell told us he was using: **LINK** https://littlemachineshop.com/products/product_view.php?ProductID=3574&category= MichaelG. . Edit: __ and here is someone using a graver properly, on blue steel: Edited By Michael Gilligan on 15/01/2023 07:03:12 |
JasonB | 15/01/2023 07:22:50 |
![]() 25215 forum posts 3105 photos 1 articles | Big inserts for a small lathe, I would suggest something like this which is the same overall size but has a smaller 0.2mm tip radius, sold in twos.**LINK** |
Hopper | 15/01/2023 08:14:39 |
![]() 7881 forum posts 397 photos | HT socket head cap screws are often a cow to machine to a nice finish. No idea why. They just often are. Plus you are using a very small, not very rigid lathe on some very tough steel. Not a good combination. Try on some mild steel of known grade and see how it compares. If the finish on that is acceptable using the same tools and methods, the problem lies in the material. |
Martin Connelly | 15/01/2023 08:37:21 |
![]() 2549 forum posts 235 photos | Hopper, the steel used for a SHCS is chosen for its toughness and is then heat threated to upset and form the head followed, after it is cooled, by roll forming the thread. The steel is never really chosen to be easy to machine and it has a lot of its internal grain structure distorted by the forming and rolling processes. This produces a quality socket head cap screw that is fit for purpose as long as that purpose is not (as many of us know) to be raw material for something else. Martin C
old mart | 15/01/2023 17:04:39 |
4655 forum posts 304 photos | With a small lathe and difficult material, you should expect to have to hand finish the keys. You only make them once, and your normal work is very different and more suited to your machine. |
david bennett 8 | 16/01/2023 02:29:21 |
245 forum posts 19 photos | Michael, as I read it, he ended up using the inserts after an unsatisfactory finish. dave. |
Michael Gilligan | 16/01/2023 07:12:47 |
![]() 23121 forum posts 1360 photos | Posted by david bennett 8 on 16/01/2023 02:29:21:
. Then I think we must ask Dell to describe each of the attempts he made, in a little more more detail … as I read it: he ended up using a hand graver [with which he is familiar] to get a decent finish. MichaelG. |
Les Jones 1 | 16/01/2023 09:04:16 |
2292 forum posts 159 photos | I don't understand why a good finish is required on a chuck key. If you wanted a polished finish why not just use emery paper ? Les. |
Dell | 16/01/2023 13:07:51 |
Here is a picture of my setup but please bear in mind that I have set it up with the finished product, as I turned it down prior to milling the square, the first picture is the HSS bits I used and the carbide were the same pattern. |
Michael Gilligan | 16/01/2023 13:12:40 |
![]() 23121 forum posts 1360 photos | Thanks for the photos, Dell … they appear to support my original reading MichaelG. |
JasonB | 16/01/2023 13:13:32 |
![]() 25215 forum posts 3105 photos 1 articles | That's a smaller size insert than your previous link, so you would want something like this for a CCGT option. From the picture I would have the tool at right angles to the lathe axis, the more you angle it the more "pointed" the tool is. |
Dell | 16/01/2023 17:12:05 |
![]() 230 forum posts 44 photos | JasonB i had to have it at that angle otherwise it didn’t clear the live centre when turning down the end where the square is , also I moved the fixed steady near to where I was trying to cut . thanks for replies, as I said it’s not something I will need to do very often, the next time I need to do something similar I will try the advice. most of my work is with a graver IE making small screws, arbors, and other clock related parts. many thanks Dell |
