Boiler Bri | 23/12/2022 18:03:14 |
![]() 856 forum posts 212 photos | Does anyone know where to source 1.2mt long 20mm x 10mm I beam in Brass? Bri |
File Handle | 23/12/2022 18:05:41 |
250 forum posts | Curious of its intended use? |
JasonB | 23/12/2022 18:18:15 |
![]() 25215 forum posts 3105 photos 1 articles | Eileen's Emporium do some brass sections but their site is down for maintenance at the moment so can't check sizes as your need may be a bit large. is soldering Tee section together an option? |
DiogenesII | 23/12/2022 18:19:31 |
859 forum posts 268 photos | ?Curtain track - though uncertain if you will get the right dimensions, you might get close... Hunter & Hyland might be 8.5x19.. Edited By DiogenesII on 23/12/2022 18:23:07 |
John Beresford | 23/12/2022 19:01:05 |
25 forum posts 11 photos | I believe Eileens Emporium have sadly ceased trading as of this month. They will be sadly missed! |
Nigel Graham 2 | 23/12/2022 19:11:34 |
3293 forum posts 112 photos | I think curtain track is not symmetrical, at least not the ones I have seen. Is the 1200mm the full length of the finished item or the total stock requirement? If the finished work is lots of short pieces, and depending on exterior appearance, it may be possible to make each piece by slitting a length of square tube into two and soldering them back-to-back. Or better, if available, brass channel of appropriate size. Distortion might be a problem though, unless heated very evenly. I used something like that principle to make the H-section beam front axle for my steam wagon, but that is of larger section, steel, and welded. The stock was folded channel. |
Boiler Bri | 23/12/2022 19:29:09 |
![]() 856 forum posts 212 photos | It’s not actually for me. A friend is making a Norfolk Wherry and he needs it in the length. If it had been shorter I could have made it up but he really needs the length. Thank you for the replies. I will investigate them all. Bri |
peak4 | 23/12/2022 19:41:03 |
![]() 2207 forum posts 210 photos | Posted by John Beresford on 23/12/2022 19:01:05:
I believe Eileens Emporium have sadly ceased trading as of this month. They will be sadly missed! According to Facebook, that appears to be the case, but I've no confirmation |
DC31k | 23/12/2022 20:29:48 |
1186 forum posts 11 photos | Posted by Boiler Bri on 23/12/2022 19:29:09:
If it had been shorter I could have made it up but he really needs the length. What is preventing you making it in that length? If it is the travel on your machine not being long enough, some creative fixturing that allows you to cut a section, slide it along and then cut another section will overcome that. As it is brass, it can be cut with a 6mm or 1/4" carbide end mill held in a trim router. For the authentic rolled section look, use one with a corner radius. |
Dave Smith 14 | 24/12/2022 14:28:37 |
222 forum posts 48 photos | Very Sadly Eileens Emporium have gone into administration. This was posted on a number of modelling associated websites on December 11th. I am very sorry to have to tell you that Russan Limited, trading as Eileens Emporium has ceased trading and appointed liquidators.We have done our best to send out all the stock we have for pre-paid orders. I am sorry that we were not able to complete all of them. Any clains against the business should be sent to: Christine Vaines, Begbies Traynor, Suite C 11 Kingsmead Square, Bath, BA1 2AB | T: 01225 316 040 | Email [email protected] |
