Thinning a parting blade?
First newbie project on a DC Merlin diesel
Tim Hooper09/12/2022 20:35:49
10 forum posts
Hi all!
For my first lathe project, I'm making a new ali cylinder head for a .75cc DC Merlin diesel engine.
I've succeeded in cutting a workable thread so it screws into the crankcase quite happily. The next step is boring out the interior to accept the cylinder liner.
My question regards the subsequent cutting of the external cooling fins, and luckily I have a spare cylinder head to copy. I'm guessing that a thin (1mm) blade is used to remove material, and I'm wondering whether it's safe to take a 'standard' parting blade (3mm wide), and simply grind it down to size?
I understand that some relief on the sides of the blades is necessary.
Just wondered what the accepted method is?
Thanks,
Tim
Roderick Jenkins09/12/2022 21:36:52
2376 forum posts
800 photos
Tim,
I have done what you suggest without problems. Don't make the thinned bit longer than it needs to be.
An alternative is to use a HSS hacksaw blade in a holder:
Rod
Ramon Wilson09/12/2022 22:32:23
1655 forum posts
617 photos
Tim,
Always good to hear from someone doing something on 'diesel' enginesyes
I've done quite a few heads now using home ground parting blades ground from old cutter shanks - mainly FC3 throw away cutters. The big thing to be aware of is rubbing of the blade in the slot and the consequent build up of the ali on the tool so plenty of paraffin for lubricant - you can use WD 40 but the fumes given off can prove quite nasty to the respiratory system.
096.jpgI hold the cutters in short lengths of rectangular mild steel as tool holders. The good thing with using this method is unlike grinding away a costly decent parting tool the tool can be rotated in the holder to give good clearance.
Hope that's of help.
Tug
Ramon Wilson09/12/2022 22:43:02
1655 forum posts
617 photos
Further to Rod's post about using a hacksaw blade I remembered I have these images doing a special head for an ETA 15d
I also did a scaled up to 5cc version of the above and used another cutter ground from a 1/4" dia FC3 cutter shank to do these very deep fins.
Best - Tug
Edited By Ramon Wilson on 09/12/2022 22:44:14
Tim Hooper09/12/2022 23:08:04
10 forum posts
Thank you, gents!
Since my initial post, I've ordered a 1.5mm blade to grind down a tad, but I do like the idea of recycling an old hacksaw blade.....
Tim
JasonB10/12/2022 06:57:15
You can also buy the blades in 1mm width from the likes of Eccentric Eng or if not too deep I use a 1mm insert that will do up to 6mm deep.
Emgee10/12/2022 10:59:01
2610 forum posts
312 photos
Cutting the 0.6mm gaps in EN16 to leave fins on a Whittle cylinder, tool is ground HSS and did 9 cylinders without regrinding. Youtube video link below.
Emgee
Grizzly bear10/12/2022 16:59:22
337 forum posts
8 photos
Emgee,
I enjoyed that video, nice camera work too.
Bear............
Emgee11/12/2022 09:50:55
2610 forum posts
312 photos
Posted by Grizzly bear on 10/12/2022 16:59:22:
Emgee,
Bear............
Hi Bear
Thanks for your positive comment about the video.
Emgee
ega11/12/2022 10:02:52
2805 forum posts
219 photos
Roderick Jenkins' post included an extract from L C Mason's "Using the Small Lathe".
I don't know whether this is still in print but those who do not know the book would do well to get hold of it.
SillyOldDuffer11/12/2022 10:18:55
10668 forum posts
2415 photos
Posted by Tim Hooper on 09/12/2022 23:08:04:
Thank you, gents!
Tim
It's a good tip, well worth a try, but don't be surprised if it doesn't work. Hacksaw blades, especially modern ones, are unlikely to be solid HSS. Very cheap blades are usually Carbon Steel - hard, but easily overheated, chipped and blunted. Top-end blades usually have HSS teeth bonded to a tough soft-steel backing; they're less brittle and have extra hard teeth compared with solid HSS blades, where the metallurgy is backed off somewhat to reduce breakages. And there are mid-range blades made like the top-end type, but for cheapness with ordinary HSS teeth on a mild-steel backing strip. Very cheap blades handled gently will work, and so will solid HSS if they can be found, but many posh brands and mid-range blades may not hold an edge because the backing strip is made of soft metal.
Michael Gilligan11/12/2022 10:25:50
23121 forum posts
1360 photos
Posted by SillyOldDuffer on 11/12/2022 10:18:55:
Thank you, gents!
Tim
It's a good tip, well worth a try, but don't be surprised if it doesn't work. Hacksaw blades, especially modern ones, are unlikely to be solid HSS. […]
Good point, Dave yes
To the best of my knowledge Starrett Red Stripe blades are still solid HSS
Roderick Jenkins11/12/2022 11:21:05
2376 forum posts
800 photos
Mason's splendid little book has been reprinted by TEE https://www.teepublishing.co.uk/books/lathes-other-machine-tools-and-how-to-use-them/using-the-small-lathe/
Plenty of "all hard" HSS hacksaw blades available from Eclipse **LINK**. I have a good stock of broken hacksaw blades! And if they have broken they are probably solid HSS.
Rod
Edited By Roderick Jenkins on 11/12/2022 11:26:39
ega11/12/2022 12:06:39
2805 forum posts
219 photos
I see that TEE also have his Building a Small Lathe but, seemingly, not A Man and His Lathe - possibly on the grounds of political correctness!
Hopper11/12/2022 12:26:42
7881 forum posts
397 photos
Posted by ega on 11/12/2022 12:06:39:
Being revised as "A Person and Their Latte" for the modern generation of froth sippers.
Nick Wheeler11/12/2022 13:02:14
1227 forum posts
101 photos
Posted by Hopper on 11/12/2022 12:26:42:
Being revised as turned into "A Person and Their Latte" for the modern generation of froth sippers.
Fixed that for youyes
Roderick Jenkins11/12/2022 13:11:19
2376 forum posts
800 photos
Sorry to spoil the anti-woke taunt frown
ega11/12/2022 13:35:51
2805 forum posts
219 photos
Posted by Roderick Jenkins on 11/12/2022 13:11:19:
Thanks for the correction. Sparey sits next to Mason on my bookshelf, hence my confusion of the two.
Jon Lawes11/12/2022 15:38:49
1078 forum posts
Encourage or disparage.
Tim Hooper11/12/2022 22:39:25
10 forum posts
Again, thank you for the positive feedback, gents!
It just so happens that I have a couple of Starrett red blades in stock, so it looks like the one currently in use will be making the ultimate sacrifice quite shortly.devil
Tim
