Weight driven clockwork roasting spit
ANDY CAWLEY18/11/2022 16:48:03
190 forum posts
50 photos
beb40ed4-cd68-4470-a876-2844075e8a8f.jpegThis is a photo of a weight driven clockwork spit (somehow or other it got up loaded on its side, sorry,) that I have a mind to make. The speed regulating “fly?”is driven by a helical wheel engaging an appropriate spiral pinion.
This has come out on its side😠 as well.
The pitch of the spiral is about 5/16”, it’s major diameter is about 5/8” and the minor diameter5/16”.
My guess that the spit is 18th century and might be French, these are only guesses.
All of the other pinions are lantern pinions and I can get my head round those but how is a spiral, if that is the right word, made.
Does anybody out there have any ideas an if necessary correct my terminology as my Google searching has been fruitless. I have found many pictures of clockwork spits but no information about manufacturing a spiral pinion.
Edited By SillyOldDuffer on 18/11/2022 17:48:24
Michael Gilligan18/11/2022 17:12:12
23121 forum posts
1360 photos
It doesn’t answer the question of ‘how to make’ … but I think you will have better luck searching for worm and worm-wheel … because ‘loose’ as it may be, that’s what you have.
Edit: __ it hasn’t evolved very far from Leonardo’s design
Ref. __ https://link.springer.com/content/pdf/10.1007/978-1-4020-5599-7_2.pdf
Edited By Michael Gilligan on 18/11/2022 17:25:58
david bennett 818/11/2022 20:24:23
245 forum posts
19 photos
I should think the one you pictured was sawn /chiselled /filed. Finer examples, as in music boxes, were spiral milled.
( It might be worth asking on a blacksmith  forum )
dave8
Edited By david bennett 8 on 18/11/2022 20:27:34
ChrisLH18/11/2022 20:48:35
111 forum posts
7 photos
Curiously OD of the worm has a double taper - but in the wrong direction if you were hoping to maximise worm/wheel contact. So maybe they were trying to minimise the w/w contact so that pitch mismatch wouldn't stop the job ?
ANDY CAWLEY18/11/2022 21:57:42
190 forum posts
50 photos
Michael Gillian, thank you for the worm thought, why didn’t I think of that🤔✅.
Chris LH, the unusual feature of this device is that the worm is driven whereas in most applications the worm is the driver.
Michael Gilligan18/11/2022 22:26:31
23121 forum posts
1360 photos
A very interesting machine, Andy … do please keep us advised of your progress !
Michael Gilligan18/11/2022 23:11:23
23121 forum posts
1360 photos
You might enjoy browsing this lot, Andy
https://www.pinterest.co.uk/pin/spit-jack-to-rotate-the-spit-on-which-meat-cooks--319896379756119734/
Ref. __ https://www.abebooks.co.uk/9782701302188/objets-vie-domestique-Ustensiles-fer-2701302188/plp
… Ouch !!
Edited By Michael Gilligan on 18/11/2022 23:20:00
Bazyle18/11/2022 23:33:48
6956 forum posts
229 photos
Probably easier to make on a treadle lathe with a very slow speed. Wrap a piece of string around it to mark the spiral, mark with paint that will go into the gaps in the turns of string. Follow the path with a file hand forming a rough groove. As you get some definition for the groove the file will follow it under power. Just a version of hand chasing a thread.
Dick H18/11/2022 23:49:32
141 forum posts
Am I daft,? in order to get this to run you need to spin the "fly" by hand, and when it stops spinning the spit will stop rotating.
Mike Hurley19/11/2022 10:53:44
530 forum posts
89 photos
No Dick you aren't daft, this is bugging me as well! It doesn't appear to work like a clock escapement but the rotation of the 3 armed fly would control the overall speed. But if you have to rotate this manually - what's the point? It would be easier to have a peasant with a crank handle attached to the ox or whatever?
ANDY CAWLEY19/11/2022 10:55:07
190 forum posts
50 photos
Posted by Dick H on 18/11/2022 23:49:32:
I haven’t actually operated it yet but my understanding is that it runs powered by a weight on a rope wrapped round the wooden drum. The fly is there to keep the speed down presumably by air resistance. There is a neat arrangement that rings the bell when when the. Rope is nearly all run off the drum thus warning the cook to rewind the rope.
Circlip19/11/2022 11:10:38
1723 forum posts
And don't forget the nay sayers that state a worm cannot be driven by a wheel.
Regards Ian.
noel shelley19/11/2022 11:14:04
2308 forum posts
33 photos
Like Dick and Mike I fail to see how it can work, unless the fly is turned , UNLESS the helix angle can impart some power to the fly ? Looks more to me like a striking train ? Noel.
roy entwistle19/11/2022 11:26:19
1716 forum posts
I've seen one of these working but sorry I can't remember where.
Edited By roy entwistle on 19/11/2022 11:26:58
Circlip19/11/2022 12:03:04
1723 forum posts
Probably in a BIG kitchen. Stately homes springs (?) to mind.
Regards Ian.
ANDY CAWLEY19/11/2022 12:08:25
190 forum posts
50 photos
Posted by Circlip on 19/11/2022 12:03:04:
Regards Ian.
This one’s actually in my shed! I can see I’ll have to cobble up some method of getting it working😉
ChrisLH19/11/2022 12:47:21
111 forum posts
7 photos
Noel S,
Fly mechanism driven by a fast worm is common in music box clokwork where it's self starting. Less crude construction and finish though.
Michael Gilligan19/11/2022 13:21:45
23121 forum posts
1360 photos
Posted by Circlip on 19/11/2022 11:10:38:
Regards Ian.
dont know
But the nay-sayers don’t understand, and therefore generalise too much.
duncan webster19/11/2022 16:13:15
5307 forum posts
83 photos
lots of early automotive back axles had worm/wheel. They backdrive fine as long as the ratio isn't too high. I'm aware of several narrow gauge locos that use 5:1 worms as final drive, no problem
ChrisLH19/11/2022 16:39:11
111 forum posts
7 photos
And rear wheel drive Peugeot cars up until they went FWD, don't know how many start worms though.
