I need a relay as a dip switch while they are switched on, and another relay to flash the maijn beam at any time.headlamps.
Tim Stevens | 15/11/2022 21:08:55 |
![]() 1779 forum posts 1 photos | The system was working, but untidy, and I took it apart without noting exactly how the two microswitches, and relays, were connected. The two relays are simple ON/ON switches, each switch operated by a tiny solenoid (as normal). The control lever operates two microswitches, each with C, NO, and NC, one at each end of its travel. And it worked well, but the wiring was untidy (and all the same colour), so I thought I would improve it. But in the six years since I built it I have forgotten how it should be connected. Thje dip switch must only work when the headlamps are on, and gives two positions, main and dip beams. The flasher switch turns the main beam on at all times when the car is in use, and when Flash is operated with dip on, the dip beam goes out while the main flash is on. Two relays - one for dip fed from the fused headlamp switch, the other for flash fed from the ignition switch via a fuse. A sketch would be ideal, and saves a lot of writing - Can you help, please? Regards - Tim I am avoiding use of the term 'simple' as it has me foxed. And sorry for the untidy headline - I can't edit it. Edited By Tim Stevens on 15/11/2022 21:10:43 |
bernard towers | 15/11/2022 21:24:28 |
1221 forum posts 161 photos | Why not look at an inline wiring diagram? |
Howard Lewis | 15/11/2022 21:52:26 |
7227 forum posts 21 photos | It seems to me that the "Dip / Main" relay needs to function as a single pole changeover switch, with the stationary "Common" contact fed from the Headlamp circuit. The Dip Switch would feed current to the relay coil, presumably only when "Main" is selected, so that the "Common" contact then feeds current to !Main" filament circuit.through the "Normally Open" contact.. If the Relay can be of the latching type, the coil would only be enrgiswed to change fro Dip to Main, or vice versa. The capability to flash the headlamps can be accommodated by the "Flash" Relay coil being fed through the "Flash" switch, from an ignition live point (Assuming no need to flash the lights when the engine is dead) If the "Flash" facility is needed at all times the relay coil feed would need to be from a constantly live point. The stationary contact of the "Flash" Relay would be fed from the same point, with the "Normally Closed" contact being strapped to the "Main" contact on the "Dip / Main" relay... HTH Howard |
noel shelley | 15/11/2022 22:22:05 |
2308 forum posts 33 photos | What you describe is a standart type of dip/main beam circuit what vehicle is it ? I can send you a copy of my peugeot diagram if that will help. Noel. |
Tim Stevens | 16/11/2022 10:31:38 |
![]() 1779 forum posts 1 photos | For Noel: the vehicle is a 1928 Lea Francis, and it came from the factory with a system which is no longer legal or sensible. That's why I did not mention it. For example, charging control was by turning the dynamo on or off - no other choice. For Howard: thanks - I think you have solved it, and I will go and play with wires. You may be interested to know that the idea of ball-ended supports for taper turning (etc) is explored in my book 'Workholding for Machinists'. Regards, Tim Stevens |
Tim Stevens | 16/11/2022 17:03:17 |
![]() 1779 forum posts 1 photos | Cancel my last message as regards Howards solution. I'm sorry, but I am still stuck. If anyone is still there ... ? ... please re-consider my question - thanks. And if anyone- including Howard - can draw me a diagram of Howard's version, I will reconsider that, too. Regards, Tim |
SillyOldDuffer | 16/11/2022 19:07:56 |
10668 forum posts 2415 photos | I'm having a think Tim. Sacrifice a virgin and watch this space! |
mark costello 1 | 16/11/2022 19:27:35 |
![]() 800 forum posts 16 photos | Virgins are too costly and scarce anything cheaper? |
SillyOldDuffer | 16/11/2022 19:52:09 |
10668 forum posts 2415 photos | Tim, Does one of the relays have a change over contact, or are they both on/off only? Dave |
noel shelley | 16/11/2022 20:16:08 |
2308 forum posts 33 photos | It very much depends on what micro switches and relays you have as to how it was wired up. The simple answer would be to use a dip switch of the floor mounted type used in the 60s/70s ! fused side light circuit NO fuse on a headlight circuit, panel switch to dip switch and 2 wires to each bulb, no micro switches and NO relays. Each bulb wired to chassis. Flasher - ignition live to flash switch then to coil and other coil connection to chassis. Fused live from battery or light switch to moving contact main beam filaments to NO contact.use a 20A relay If using auto motive relays then connection 31 is ground/chassis Noel. |
Robert Atkinson 2 | 16/11/2022 20:33:04 |
![]() 1891 forum posts 37 photos | Tim, Robert.
SillyOldDuffer | 16/11/2022 20:49:26 |
10668 forum posts 2415 photos | Posted by noel shelley on 16/11/2022 20:16:08:
It very much depends on what micro switches and relays you have as to how it was wired up. The simple answer would be to use a dip switch of the floor mounted type used in the 60s/70s ! fused side light circuit NO fuse on a headlight circuit, panel switch to dip switch and 2 wires to each bulb, no micro switches and NO relays. Each bulb wired to chassis. Flasher - ignition live to flash switch then to coil and other coil connection to chassis. Fused live from battery or light switch to moving contact main beam filaments to NO contact.use a 20A relay If using auto motive relays then connection 31 is ground/chassis Noel. Having drawn a partial truth table, the hard part is the last entry: If the headlights are On AND Dipped, then Flash has to turn the Dipped Beam off and the Main beam on. I think it's easy if a change over relay is available, but I've not spotted a way of doing it with a simple on/off relay. Dave |
Tim Stevens | 16/11/2022 20:57:40 |
![]() 1779 forum posts 1 photos | Dave, Robert: The relays are identical, and both have two contacts for the solenoid, and three for the contacts. The headlamps are switched on separately (as a pair, but not the same switch as the dip) using the original Side-tail, and Head, switch. Within reach in the dip-switch box is a fused live feed and a non-fused ignition-on feed. A futher main switch disconnects everything overnight. The dip control lever has three positions, much like a 1960-1990 car, with, in order towards you, mainbeam, dip, and flash. Main, or dip, stays where you put it, while flash is spring loaded to OFF. Each of the microswitches is operated by the control lever, at each end of the lever movement, and both have on-A & on-B positions. It is not a simple matter to change to a foot dip switch, as it is complicated enough driving with a central throttle pedal, (and a right side gear stick on a RH Drive car). And incidentally, the headlamps and side, tail, etc are all LEDs, because the max output from the dynamo is 8 amps (and only then when pressing on). The reason I don't want Dip to stay on when I use the Flash is that the Headlamps are old fashioned, each in their own small space, and the bulbs in each are cooled with an integral fan. As the volume is small I hope to avoid overheating in there if both 'filaments' are on (but perhaps I am fussing over nowt). Hoping this helps your cogitating. PS I would send you a circuit diagram but (of course) I haven't worked out what it looks like yet.(!) Regards, Tim |
Michael Gilligan | 16/11/2022 20:58:40 |
![]() 23121 forum posts 1360 photos | Posted by SillyOldDuffer on 16/11/2022 20:49:26: […] If the headlights are On AND Dipped, then Flash has to turn the Dipped Beam off and the Main beam on. I think it's easy if a change over relay is available, but I've not spotted a way of doing it with a simple on/off relay. Dave . For the purpose of ‘flashing’ … I suspect that it would do no great harm to have both filaments briefly lit Happy to be wrong, but it would seem to be a simple [and possibly safer] solution. MichaelG. . Edit: __ Sorry, Tim … that appears to have crossed with your own post. Edited By Michael Gilligan on 16/11/2022 20:59:52 Edited By Michael Gilligan on 16/11/2022 21:26:08 |
Tim Stevens | 16/11/2022 21:11:13 |
![]() 1779 forum posts 1 photos | SoD: As you will have seen (I hope) both the relays are on-A and on-B. This is the same option set as the two microswitches, which incidentally operate at the two extreme positions for the dip control. And an oversight - along with live and ignition feeds in the dip switch area, there is a 'both headlamps feed' from the lighting switch. (I don't suppose it matters, but the identity colours are green, white, and blue in the order bold above. In line with the relevant British Standard) Cheers, Tim |
John Doe 2 | 17/11/2022 07:23:32 |
![]() 441 forum posts 29 photos | Here is a starting point, the top circuit will not kill the dipped beams when flashing the mains, but otherwise it will work. Where I have written head lights top left, is the supply from the battery, the switch next to it is the headlight on/off switch. Ignore the bottom diagram - it won't work: as soon as the high beams come on the upper relay coil will relax and switch them off !! Black terminals on the relays are the normally closed, resting position. The coils are the relay operating solenoids. I am still thinking about it - and couldn't get to sleep last night ! I now know the two micro switches are SPDP, so I might be able to improve the circuit. Can you give us a truth table as to which stalk action operates which micro switch. Sorry about the very rough diags - no time to improve them for a couple of days.
Edited By John Doe 2 on 17/11/2022 07:31:19 Edited By John Doe 2 on 17/11/2022 07:32:18 |
Tim Stevens | 17/11/2022 08:30:51 |
![]() 1779 forum posts 1 photos | Thanks, John Doe 2, but I have - I'm sorry - already got that far. But don't be put off - the answer is out there somewhere. Regards, Tim |
SillyOldDuffer | 17/11/2022 10:15:10 |
10668 forum posts 2415 photos | For review: I think Tim's lights obey the following logic:
I suggest this circuit, which assumes a relay with a Normally Closed contact. The relay disconnects the dip lamps whenever the main beam is on. Comment: strictly speaking only one switch is needed in the Dip/Main selector. But the circuit shown allows dip to go OFF just before main comes ON, and vice versa. I've not tested the circuit. Dave |
Tim Stevens | 17/11/2022 10:20:06 |
![]() 1779 forum posts 1 photos | I think i have worked out my own 'solution' - but first I must work out how to add a picture. Keep your fingers crossed. It might be the same as SoD's version, but I have combined the switches in a way that stops main and dip being on together, however hard you try ... Cheers, Tim |
noel shelley | 17/11/2022 10:24:31 |
2308 forum posts 33 photos | Dave Flash now only works when the headlights are on, so no daylight flash ? Noel. |
