old mart | 22/10/2022 21:04:11 |
4655 forum posts 304 photos |
HOWARDT | 22/10/2022 21:23:36 |
1081 forum posts 39 photos | Fixture component suppliers are a source, such as WDS, not cheap but it is proof machined. Used to use a lot of their sections over the years. |
HOWARDT | 22/10/2022 21:25:38 |
1081 forum posts 39 photos | Alternative would be to use steel and Turcite the way surfaces. |
peak4 | 22/10/2022 21:28:27 |
![]() 2207 forum posts 210 photos | You could try United Cast Bar in Chesterfield Bill |
Jelly | 22/10/2022 21:58:04 |
![]() 474 forum posts 103 photos | Best bet would be to ring commercial stockholders and ask them to process you the blank you need from a standard size product like 150*150 square; a big stockholder who carries lots of CI will hopefully carry rectangle sections in suitable size, saving you some hassle and cost. But for what you pay in cutting fees, you offset not buying the additional 5" of thickness on that bar so it's always worth pursuing that. If they're regularly selling CI or Special Steels this kind of thing should be pretty normal for a stockholder...
Edited By Jelly on 22/10/2022 22:08:01 |
Paul Lousick | 22/10/2022 22:09:50 |
2276 forum posts 801 photos | Have another cast at a foundry. Make a simple pattern out of wood that is slightly bigger than the 18" x 6" x 1" thick shape. Tell the foundry that it is for a museum and not needed immediately and they may make it for the cost of material when they are pouring something else. |
Pete. | 23/10/2022 07:15:43 |
![]() 910 forum posts 303 photos | Have you thought about bronze tig or mig? I've had pretty good luck experimenting with it on cast iron, if it's just that little crack in your cross slide it wouldn't be a huge amount of work. |
DC31k | 23/10/2022 08:03:41 |
1186 forum posts 11 photos | Is the projecting part at the other end to the circular slot simply for attaching the taper turning attachment? If so, could it be made of a separate piece bolted on, thus reducing the overall size of the stock? Perhaps mill away the entire outer dovetail, replace it with a steel ring, bolted in place and remake the dovetail. It is not a high speed sliding surface and steel is better able to resist the tensile force induced by the wedging action of a dovetail bolt. A better repair than the underslung splint, and one that has the potential to apply force to close the crack might be to mill out a bow-tie shaped part in the top and glue in a spline piece (just as woodworkers do for repairing cracks). You make the spline slightly small and heat it up before inserting into its pocket. As it cools, it shrinks and pulls the crack together. |
Ady1 | 23/10/2022 10:10:50 |
![]() 6137 forum posts 893 photos | Agree with the welding option, tig best, mig possible To my eye, it doesn't look like there is enough meat there to begin with, and that's why it cracked Presumably it's a non-loading point |
ega | 23/10/2022 11:19:14 |
2805 forum posts 219 photos | old mart: I enjoy your posts and wish you well with your search for CI. My own wish is to know which museum you invariably refer to. Might you put it in your profile? |
Pete. | 23/10/2022 18:26:13 |
![]() 910 forum posts 303 photos | Just out of curiosity could you tell us what's wrong with the bracing piece you've put on? Is it not working sufficiently? Or just not keen on the look of it? |
old mart | 23/10/2022 19:49:51 |
4655 forum posts 304 photos | The design is basically weak, but does allow the tailstock to be closer to the spindle than my bolt on repair. If I were to make a replacement, it would be stronger by design, even if made from the same type of cast iron. The outer curve could be at a larger radius, with its centre to the left of the original, leaving the width at the centre the same. This would add more material to the ends of the curved section. The thickness of the outboard curved section in a vertical plane could be greater, the extra underneath would not restrict the tailstock or the movement, which is about 7" total. I have no idea when the damage was done, or whether it was caused by overtightening the two compound holding bolts, or crashing into the tailstock. The reinforcement was accompanied by doubling the bolts to 4 and not tightening them as much. The lathe was due for scrapping when it was donated to the museum. Thanks for all the suggestions and links, I will be finding out I agree about the length, I had originally contemplated making the rear end a separate add on part to reduce the radius, but below 11" rad would reduce the length of the dovetail length more than I would like. |
Pete. | 23/10/2022 21:54:59 |
![]() 910 forum posts 303 photos | It's hard to be completely sure from looking at those photos, but I get the impression the radius overhang is weak, what I'd do is use a die grinder to carve out the crack enough to fill with bronze, then make two little gussets with some scrap cast iron and braze those in place underneath to support the overhang. Some experimenting with bronze cast Iron repairs. |
Pete. | 28/10/2022 23:27:19 |
![]() 910 forum posts 303 photos | Did you ever find a solution to this? If you can't find a cost effective solution I'll bronze braze it for you FOC, you'd need to cover the postage and send a couple of small bits of cast iron that could be used as gussets, I'd imagine some bits of scrap from anything would do . |
