pgrbff | 15/10/2022 10:49:45 |
261 forum posts 31 photos | I have Record 077 bullnose plane, I'm mainly a woodworker, but I have mislaid a screw that holds the nose on. As I'm in Italy I cant pop out and try different screw sizes as everything is metric. 1/4" BSW 20 will only start to screw in. M6 x 1 will screw in but is far too lose. What other 1/4" options are there? Would 1/4" 28 be close to M6x1?
Edited By pgrbff on 15/10/2022 10:51:44 |
HOWARDT | 15/10/2022 10:55:17 |
1081 forum posts 39 photos | Record plane, have a look here, 7/32-20 BSW, I think that’s what it says. |
pgrbff | 15/10/2022 10:58:05 |
261 forum posts 31 photos | Posted by HOWARDT on 15/10/2022 10:55:17:
Record plane, have a look here, 7/32-20 BSW, I think that’s what it says. I did have a look on there but I didn't find the screw size. I'll have another look. Thanks |
Paul Lousick | 15/10/2022 11:03:31 |
2276 forum posts 801 photos | This is a link for Record planes that was recently posted on MEW. The bolt that holds the front knob is 7/32"- 20Tpi Whitworth (beat me to it ! But i doubt that you will find a metric screw that fits. 7/32" = 5.56mm)
Edited By Paul Lousick on 15/10/2022 11:10:39 |
pgrbff | 15/10/2022 11:06:02 |
261 forum posts 31 photos | Posted by Paul Lousick on 15/10/2022 11:03:31:
Can't get link to work |
Andrew Johnston | 15/10/2022 11:35:05 |
![]() 7061 forum posts 719 photos | If a M6 screw is loose then a 7/32" screw will be even looser. Try 1/4" BSF, at 26tpi it is close to the 1mm pitch of M6 screws. Andrew |
pgrbff | 15/10/2022 12:12:48 |
261 forum posts 31 photos | One 1/4" x 3/8" posted to Italy, £16. |
Hopper | 15/10/2022 12:41:34 |
![]() 7881 forum posts 397 photos | Try finding someone in Italy who works on or sells bits for old British motorbikes or cars. They all used BSF. |
pgrbff | 15/10/2022 12:52:54 |
261 forum posts 31 photos | Posted by Hopper on 15/10/2022 12:41:34:
Try finding someone in Italy who works on or sells bits for old British motorbikes or cars. They all used BSF. It's hard to explain but culturally Italy is very different on many levels, there really isn't a DIY culture. Italians even have special agencies that apply for driving licences and passports. No-one would apply for their own driving licence. |
ALLAN QURASHI | 15/10/2022 13:05:42 |
24 forum posts 4 photos | pgrbff, I hope this post will display a link to my favourite very comprehensive go-to Thread size chart for you. According to this chart...7/32" BSW would be 24TPI...emphasis on the S for standard. Paul, that's a great link to the Record Plane details, and they do only say 7/32 x 20 witworth form, i.e. not standard. I suggest you do oversize, very slightly to 1/4", but being such small increase in diameter, stick with the 20 TPI options so you can 'stay in the groove' as the disk jockeys say. 1/4" UNC should be easy to get a tap and a bolt for. Good luck, Allan
Clive Foster | 15/10/2022 13:08:12 |
3630 forum posts 128 photos | Normally with these almost 1/4 BSF, almost M6 issues on British made things the culprit turns out to be OBA. Same nominal diameter as M6, same thread pitch for all practical purposes but different thread form. Touch smaller than 1/4 BSF, screws in just fine but pullout force is about 1/4 of what it should be! Clive |
peak4 | 15/10/2022 13:13:05 |
![]() 2207 forum posts 210 photos | One of the above links to the article about Record planes seems to be dodgy; this one works OK Part 2 amongst other things , refers specifically to the No.12-20 thread |
Michael Gilligan | 15/10/2022 14:21:54 |
![]() 23121 forum posts 1360 photos | Posted by pgrbff on 15/10/2022 11:06:02:
Can't get link to work . Perhaps unsurprising … Unfortunately, Paul has linked to his F drive : . . MichaelG. |
ega | 15/10/2022 17:02:17 |
2805 forum posts 219 photos | I think you mean the 077A which has the removable front and adjustable mouth. From memory, my screw is 1/4 BSF. PS Just checked only to be reminded that my plane is the similar 311 combination version; FWIW, its screw is indeed 1/4 BSF. Edited By ega on 15/10/2022 17:23:59 Edited By ega on 15/10/2022 17:42:20 |
File Handle | 15/10/2022 18:05:46 |
250 forum posts | i have often wondered why the plane makers used the thread sizes that they did, especially the none standard sizes. Sadly I suspect that like the reasoning behind number drill sizes the reasoning has been lost to history. Don't always assume that sizes given are the same now, with an old plane someone could have retapped to replace a lost screw with a more common size. Something that I have done myself to get a tool quickly back in use. Having said that whenever I get the chance I add to my collection of different sized nuts, bolts and screws. |
duncan webster | 15/10/2022 18:30:06 |
5307 forum posts 83 photos | I've got a tin full of 1/4 bsf screws, I'd happily post one to you, but since Brexit that is not at all easy, all sorts of customs issues. Can't send anything to my nieces in Germany, and believe me I've tried. |
Roderick Jenkins | 15/10/2022 21:16:40 |
![]() 2376 forum posts 800 photos | I've got one of these. I've had it from new. Here's the screw: Note the wear at the tip - the diameter varies from 6.02mm to 6.14mm towards the head. An M6 screw is very loose in the plane hole but a 1/4" BSF goes very stiff after about 5 turns. The screw, like the plane is plated. Anyway, the image is here if anybody fancies a bit of photgrammetry. Rod Edited By Roderick Jenkins on 15/10/2022 21:23:11 |
Michael Gilligan | 15/10/2022 21:43:42 |
![]() 23121 forum posts 1360 photos | Posted by Roderick Jenkins on 15/10/2022 21:16:40:
[…] Anyway, the image is here if anybody fancies a bit of photgrammetry. Rod
. Nice straight image, Rod This should be enough to get people started: . . Just print it, and get to work with the measuring-stick and calculator MichaelG. |
Michael Gilligan | 16/10/2022 10:17:25 |
![]() 23121 forum posts 1360 photos | Looking at the wear on that screw, and noting Rod’s comment about BSF going tight … I wonder if the tapped hole is tapered My guess is that the plane-maker didn’t use a bottoming tap. MichaelG. . Edit: __ My own example of that plane [also purchased new] was quite poorly made in some areas Edited By Michael Gilligan on 16/10/2022 10:23:16 |
Yngvar F | 16/10/2022 11:44:38 |
75 forum posts 54 photos |
1/4-26 on newish(70’s) 077 and much older 311.
