Here is a list of all the postings Yngvar F has made in our forums. Click on a thread name to jump to the thread.
Thread: I'm always asking about imperial threads |
16/10/2022 11:44:38 |
1/4-26 on newish(70’s) 077 and much older 311.
Thread: Four Index Thread Indicator |
21/06/2022 19:55:46 |
Thread: Book on lathe operation ? |
18/06/2022 22:59:35 |
This one is the Atlas version of how to run a lathe. |
Thread: Boxford AUD/BUD single phase conversion |
11/05/2022 17:41:04 |
This is the minimalistic approach. Original switches with a potentiometer added on the side. Edited By Yngvar F on 11/05/2022 17:41:51 |
Thread: Moving a Bridgeport |
10/01/2022 13:36:38 |
Thread: Boxford ? |
15/10/2021 15:00:26 |
15/10/2021 14:54:48 |
Check the gear train The lever on the left must be in the up or down position. |
Thread: Limp Probe |
03/07/2021 08:46:01 |
Hi There is a plastic ring that must be removed. Right over the probe. yf |
Thread: Huanyang VFD help please |
08/11/2020 20:34:52 |
A resistor in series with the switch would do this, but is quite limiting compared to a potmeter. |
Thread: Grafton tools (who?) - rotary table |
17/06/2020 09:15:10 |
Don`t know anything about Grafton, but that drill press looks very much like a Atlas. Maybe some badge engineering? |
Thread: Topslide vice for Boxford lathe |
06/06/2020 08:53:29 |
There is a small piece of metal rod under each screw. Remove the screw and Get some thin oil in there. |
Thread: Non standard taps - what are they ? |
03/06/2020 19:42:52 |
Posted by Andrew Cox 3 on 03/06/2020 17:07:05:
although relatively unusual in the wider world, finds widespread use in the old Citroen cars I dearly love.
Only come across them on old Vespas. Not the 1,1 version. |
Thread: boxford model c |
10/05/2020 21:47:25 |
Grease for the spindle bearings and oil for everything else I think. |
Thread: Tool holder. What to do |
03/05/2020 07:34:49 |
Made one that hangs over the edge of the top slide.
Thread: Boxford Tailstock Accessories |
14/04/2020 17:05:53 |
The Boxford book is very good. A classic how to book is The amateur`s lathe Link .
14/04/2020 14:16:26 |
You are right , it is a model C made in 1958. Your lathe has the same rear drive as the original South Bends. Most later Boxfords had the motor inside the stand, or a under drive UD.
Edited By Yngvar F on 14/04/2020 14:16:58 |
Thread: Hello! young'un from Devon here |
17/12/2019 08:54:44 |
Welcome. That is a great looking workshop. The placement of the vdf is not so clever though. |
Thread: Stevensons original collet blocks & Arc Euro 6" grinder |
14/12/2019 20:37:45 |
ER collets have to be snapped into the nut. I did not do this when i first got a mill and was very dissapointed with the chuck`s runout.
Thread: My Lathe Dog |
30/05/2019 09:51:49 |
Show us your cat`s head too |
Thread: kerry super 8 bench drill |
26/05/2019 11:56:14 |
The spring goes into the slot,you wind it up by turning the lid with two hands and secure it with your third hand when it`s thight. |
