Power Cut Proofing
Clive Foster07/10/2022 16:55:05
3630 forum posts
128 photos
The official unofficial kid sister has decreed that she is visiting for December and January so I've been instructed to figure out what is needed to ensure essentials in her house keep going during any power cuts.
Absolute essentials are a CCTV system and internet access so she can keep an eye on things up in Manchester whilst she is down here in Sussex. Looks like you can get boxes with a battery, charger and several 12 volt outputs with sufficient power to run a CCTV system and router wi-fi unit. Presumably a turn key supplier able to supply both box and CCTV set-up will make sure the internet link is wired and direct from the control box.
It would be desirable to keep the gas boiler, central heating system and controller gubbins (think she may have Nest stuff) up and running too. Presumably a small pure sine wave inverter, battery and suitable float charger would handle that. I guess if that is practical the 12 volt supply for the CCTV system and router might as well come off that too. Logically you could run off that all the time once its installed.
Comments, suggestions and (if I'm really lucky) contact details of someone in Manchester who can set things up for her.
Thanks.
V8Eng07/10/2022 17:10:54
1826 forum posts
My CCTV runs off mains power converted to 12v for the system and everything (incl router) automatically restarts after power is restored.
Sounds to me as though you are trying to make a UPS it might be more reliable to get a commercial UPS set up installed, but might be expensive.
I stand to be corrected by the more knowledgeable folk on here though.
Edited By V8Eng on 07/10/2022 17:16:42
Clive Foster07/10/2022 17:19:02
3630 forum posts
128 photos
V8Eng
UPS was where I started looking. But a bit of delving into the specifications made it clear that the run time on battery was far too limited. The domestic affordable (£100 - £300) systems usually don't give you any figures but similarly rated commercial units make it clear that such are short term only devices. Typically to run electronics gubbins for 10 to 30 minutes whilst you safely shut things down.
Seriously big batteries and several hours run time are ££££ and generally far too big for this job.
V8Eng07/10/2022 17:29:27
1826 forum posts
I suspect that you might need something quite substantial to keep it all going reliably thorough a power cut of unknown duration.
Have any consumption figures been obtained?
We used to have simple battery back up emergency lighting (big box 2 batteries in it flood light on top) at work which would run for a few hours so I guess unsophisticated stuff might work.
Ian Parkin07/10/2022 18:03:40
1174 forum posts
303 photos
I have recently acquired a large UPS system..its big on wheels and has 8 large lorry sized battery’s inside and control gear and a inverter..its a 3kw system
its perhaps 700mm square and 900 mm tall
i know nothing much about it but you can have it cheap..
its a AEC S1030 (power station)
looks as it could be good for anyone who has a solar system too?
Tony Pratt 107/10/2022 18:42:09
2319 forum posts
13 photos
How about a helpful neighbour?
Tony
Clive Foster07/10/2022 18:56:31
3630 forum posts
128 photos
Initial handwaving suggests power needs aren't too unreasonable.
Swann run their 4 camera CCTV systems off two 12 volt 2 amp wall warts. One for the cameras and one for the recorder / control box. My BT Home Hub also has a 12 volt 2 amp wall wart which I assume is pretty typical. So thats a theoretical 6 amp demand from the simple 12 volt CCTV and router idea. I imagine there is some margin between the wall wart output and what the kit actually uses when running flat out. I also suspect that in passive daytime watching mode the CCTV draws rather less than when recording at night with the IR illuminators on.
Approaching a couple of hours from the 9 amp hour float batteries often found on alarm systems is probably not unreasonable.
My boiler specification says 60 watts power draw, the heating pump needs 50 watts maximum and the other control gubbins soak up around another 30 watts or so. Given the various inefficiencies in battery to inverter conversion calling the boiler et al demand 180 watts is probably in the ball park. So nominal 30 amps draw from the 12 V battery for the heating when its running.
But in "frost protection plus a bit more" mode the heating won't be running all that much. If its 10 % duty cycle then a 30 amp hour battery ought do for about 10 hours.
A 100 Amp Hour leisure battery can be got for around £100 and would likely be enough to run both the heating in "frost protect plus a bit more" mode and the 12 V CCTV et al stuff for a 10 hour (ish) power cut. Which ought to be enough.
Another £200 should cover a small pure sine wave inverter (500 W) and decent quality battery maintenance charger so it all looks somewhat doable without spending silly money.
But its certainly something I'd prefer set up by "folk who know" rather than me working 'undreds of miles from base.
Edited By Clive Foster on 07/10/2022 18:59:34
Edited By Clive Foster on 07/10/2022 19:05:28
Clive Foster07/10/2022 19:04:01
3630 forum posts
128 photos
Ian
Thanks for a splendid offer but, having found some data online, that system is way, way overkill for this job. Also seems to be intended to support large loads for a short time whilst things are closed down rather than smaller load for longer.
Tony
She gets on well with her neighbours but there are limits. Keeping an eye on the place for a long weekend or short week is fine but a couple of months is pushing it. Regardless of many bottle of the favourite tipple are on offer.
Speedy Builder507/10/2022 19:58:23
2878 forum posts
248 photos
Just to add a bit of security on top of a UPS, there are apps for smart phones (Quite old ones) that monitor the charger input. They can send an SMS to another phone to indicate power on and power off. I use one for our freezer when on holiday. If the power goes off for a long time, I ring my neighbour.
Bob
Michael Gilligan07/10/2022 20:21:30
23121 forum posts
1360 photos
Going off at a slight tangent [ Who, Moi ?! ] … I was looking at this video, about a solar kit, a few days ago:
You could probably use that, or just parts of it, to good effect
… it’s all pretty modular
Edited By Michael Gilligan on 07/10/2022 20:25:24
Tim Stevens07/10/2022 20:48:16
1779 forum posts
A trendy solution, nowadays, is to add to a domestic system a lithium battery and an inverter, not primarily to cover power cuts, but as a way of using stored solar energy during the night. But such a system would meet your needs, too. It would be an advantage if you had a night-store tarriff, or were thinking of adding solar panels.
It should not be impossible, either to find a converter to drop the 50 colts DC in the llithium battery to 12v to feed lap-tops etc.
hope this helps
Cheers, Tim
Clive Foster07/10/2022 21:12:07
3630 forum posts
128 photos
Bob
Interesting to hear about that power monitoring app for phones. Having been told about it I'm not surprised its out there but there is so much stuff for phones that normal old farts like me can't begin to keep up.
Michael
Interesting video but I'm really, really trying to avoid serious engineering on my part. The bit about portable battery and inverter power systems at the end caught my eye but those integrated units are rather expensive when needing to supply the power for this sort of job. I'll be unsurprised if we are on the cusp of a big drop in price per unit power tho'.
Tim
Big battery unit to go on my solar power set-up to exploit the unused half (ish) of the power my panels generate is very much on my personal radar.
No solar panels at her ladyships place so not appropriate for her.
I think it likely that running much of the household load via big batteries with off peak and, if you have panels, solar charging will soon be a mainstream thing. If they ever stop mucking about and design smart meters properly the grid efficiency gains from widespread, accurate load / demand optimisation at the individual level look potentially impressive.
Edited By Clive Foster on 07/10/2022 21:13:24
Paul Lousick07/10/2022 22:43:29
2276 forum posts
801 photos
A battery backup system is an expensive option to run all of the electrical appliances for an emergency situation that may or may not happen. And for how long will the power be out.
A much cheaper option is to get a petrol powered generator.
The CCT, router, hearer control, etc would have to be dis-connected from the house power and connected to the generator which may need to be modified by an electrician. If a big enough generator is installed, you could run the house lights, refrigerator, etc. (Note: must be run outside of the house, carbon monoxide)
Edited By Paul Lousick on 07/10/2022 22:47:25
duncan webster07/10/2022 22:59:50
5307 forum posts
83 photos
Connecting up and starting a genny from 200 miles away is a challenge. I know it could be permanently connected and auto start but I think we're getting into overkill territory. Difficult to remotely top up the fuel, and very tempting for the light fingered brigade, who would soon work out that the house was unoccupied
Ady107/10/2022 23:28:16
6137 forum posts
893 photos
A box of candles and some matches saw us through Ted Heaths blackouts
Everyone gathered at the nearest neighbour who had a gas cooker for teatimes
First world problems eh?
I remember my dad covering his tropical fish tank with hot water bottles and a duvet to try and keep them going, but to no avail
Edited By Ady1 on 07/10/2022 23:30:55
V8Eng07/10/2022 23:39:19
1826 forum posts
Posted by duncan webster on 07/10/2022 22:59:50:
I think the genny would be gone in short order especially if plenty of power cuts were occurring.
Ady107/10/2022 23:59:09
6137 forum posts
893 photos
We didn't even have enough food in the fridge to worry about it getting spoiled
Nowadays our fridge freezers are jam packed with assorted yummys
Paul Lousick08/10/2022 04:36:27
2276 forum posts
801 photos
I missed the point that it was her house while she was visiting elsewhere that had the problem. Therefore best option is a UPS as used for computers, etc that will kick in when the power goes down. Just need a system with enough capacity for the duration of the blackout. It will automatically re charge the battery when the power is restored.
pgk pgk08/10/2022 05:15:32
2661 forum posts
294 photos
A search for 'camping power packs' on amazon etc give a host of offerings and I believe for added capacity some can be daisy-chained It comes down to whether a couple of hundred WH is enough and where to keep the thing. I'd be cautious about lithium batteries unattended in a house.
pgk
Paul Lousick08/10/2022 05:47:05
2276 forum posts
801 photos
A camping power pack although a cheaper option will not cut-in automatically when the power goes down. Uninteruptable Power Supplies (UPS) have electronics that will.
See computer supply accessories. Also lots available on ebay, etc.
