Dell | 04/10/2022 13:25:24 |
![]() 230 forum posts 44 photos |
not done it yet | 04/10/2022 13:34:39 |
7517 forum posts 20 photos | I think it best if you measure the tpi and then repair that feed screw nut. |
Andrew Johnston | 04/10/2022 14:18:22 |
![]() 7061 forum posts 719 photos | On my Pultra 1750 all the dials are marked 0 to 100 and the screws are 6mm diameter and 1mm pitch. Possibly 0BA as other threads and screws are BA. I doubt spares are available, but shouldn't be difficult to make a new one. Andrew |
Dell | 04/10/2022 16:34:37 |
![]() 230 forum posts 44 photos | Thanks for replying both, my Pultra 17/70 crosslide is imperial, I have measured the screw and it’s 0.246” and 40 tpi and the grub screw threads are 6 BA and yes I could make one if I could use the crosslide . Dell |
Michael Gilligan | 04/10/2022 18:10:04 |
![]() 23121 forum posts 1360 photos | Forgive me asking at this late stage, Dell … Is it the screw or the nut that you need to make, or both ? Thread title and text seem at odds with the photos Incidentally, that nut appears to be engraved D.2,5 Can’t get at mine at the moment or I would check whether it’s a common feature. MichaelG. |
Dell | 04/10/2022 18:35:43 |
![]() 230 forum posts 44 photos | Thanks Michael Please forgive am oil man it’s the nut but I understand that both should be changed as a set but if I can find or get a nut made that would be better than nothing, I thought about the D .25 but I would have thought it would have been D .250 and I should have said the the dial is 0 to 25 so 25 thou per revolution , so that points to 1/4” X 40 tpi. Dell Edited By Dell on 04/10/2022 18:38:42 |
Michael Gilligan | 04/10/2022 18:52:16 |
![]() 23121 forum posts 1360 photos | Posted by Dell on 04/10/2022 13:25:24:
. More guessing from me … I reckon there might just be enough wall thickness there to bore it out and insert a 40tpi bush retained with some Loctite 638 or similar. MichaelG. . Edit: __ Taps seem very reasonably priced: https://www.tracytools.com/1-4-x-40-tpi-me Edited By Michael Gilligan on 04/10/2022 19:01:02 |
Dell | 04/10/2022 19:24:22 |
![]() 230 forum posts 44 photos | I have already ordered a couple of taps and a 9/32” end mill as I am going to sleeve it ( the same as when I bush a clock plate and re tap it then if is works I can then make a new one.. thanks Dell |
JohnF | 04/10/2022 19:35:23 |
![]() 1243 forum posts 202 photos | Dell, it may be too late but I would advise purchasing the HSS taps rather than the carbon steel, the HSS are made to a better standard IMO. I have had both from Tracytools
Dell | 04/10/2022 20:55:08 |
![]() 230 forum posts 44 photos | Hi John thanks for that but yes to late now but if it is the correct thread then I will order HSS to make a new one. |
not done it yet | 05/10/2022 08:14:42 |
7517 forum posts 20 photos | I am surprised. If you intend to repair that feed screw nut, why then make a new one? |
Dell | 05/10/2022 21:10:55 |
![]() 230 forum posts 44 photos | Posted by not done it yet on 05/10/2022 08:14:42:
I am surprised. If you intend to repair that feed screw nut, why then make a new one? Good question, although if I can sleeve it I am belt and brasses so a complete new one will make me happier, also I need the repaired one to make a new one using the crosslide, |
Dell | 06/10/2022 15:46:48 |
![]() 230 forum posts 44 photos | Well it was definitely 1/4” 40 tpi thread , I opened out the hole to 9/32” I couldn’t go any larger otherwise I was in danger of breaking through to other holes turned a bush up to be a very tight fit using a graver ( I couldn’t use the crosslide) ha , pressed it into hole, drilled hole to 5.5mm ,started tapping and promptly turned the bush out so a rethink was in order, as I already had some silver solder paste I cleaned everything up and smeared a small amount of the paste round the bush pressed it back in and heated until solder flowed that did the trick, finished cutting the thread cleaned everything and put crosslide back together, no play whatsoever. |
Michael Gilligan | 06/10/2022 16:09:30 |
![]() 23121 forum posts 1360 photos | Well done, Sir MichaelG. |
david bennett 8 | 06/10/2022 20:52:53 |
245 forum posts 19 photos |
Edited By david bennett 8 on 06/10/2022 20:56:58 Edited By david bennett 8 on 06/10/2022 21:23:00 |
david bennett 8 | 06/10/2022 21:35:03 |
245 forum posts 19 photos | P.S. use bronze for the nut. Dave. |
not done it yet | 07/10/2022 09:13:21 |
7517 forum posts 20 photos | I couldn’t use the crosslide Interesting! From that, I assume that lathe does not have a compound slide? |
Michael Gilligan | 07/10/2022 11:16:13 |
![]() 23121 forum posts 1360 photos | Posted by not done it yet on 07/10/2022 09:13:21:
I couldn’t use the crosslide Interesting! From that, I assume that lathe does not have a compound slide? . An interesting assumption ^^^ MichaelG. |
Dell | 07/10/2022 18:52:02 |
![]() 230 forum posts 44 photos | Posted by david bennett 8 on 06/10/2022 20:52:53:
Edited By david bennett 8 on 06/10/2022 20:56:58 Edited By david bennett 8 on 06/10/2022 21:23:00 That’s odd my nut is one piece and the dials are different, maybe the difference is yours are metric and my one is imperial. |
not done it yet | 07/10/2022 20:41:46 |
7517 forum posts 20 photos | Posted by Michael Gilligan on 07/10/2022 11:16:13:
I couldn’t use the crosslide Interesting! From that, I assume that lathe does not have a compound slide? . An interesting assumption ^^^ MichaelG. Dell, If the logic also escapes you, too, I can PM you to explain how simple it can be. |
